    VRay Problem - undulating reflections
    renderpluginsextensions
    24 Posts 8 Posters 4.6k Views 8 Watching
      Gwint
      My model weighs too much. I threw VRay settings - during the day and at night.
      404 Not Found
      (www4.zippyshare.com)
        Gwint
        My Scene: http://www68.zippyshare.com/v/5966419/file.html
        • dkendigD Offline
          dkendig
          change your output file type to png or something other than jpg. It may just be an image compression artifact
          Devin Kendig
          Developer
            Gwint
            No, because the render also it shows 😞
            • dkendigD Offline
              dkendig
              did you try it?
              Devin Kendig
              Developer
                Gwint
                I understand that after I finished render save the file as a .png or .tif? Unfortunately, on the same ....
                • dkendigD Offline
                  dkendig
                  ok, I guess it's some setting then.
                  Devin Kendig
                  Developer
                    reymond
                    dkendig says it correctly. it's the image format.
                    it is probably in connection with your light.
                    I could see no light source in the kitchen cabinets. where does that light?
                    used a square with a Emitter material as light source and a ies light.
                    I think your patch in the stored image has to do with the light.
                    in connection with the reflection of the materials.
                    you Need try ...... but put the light sources as noted.
                    and try for the high-gloss surface a standart plastic material.
                    I had a thearender issue with a similar problem. and there were the light sources the Problem.
                    Sketchup & Vray Trainer
                      Gwint
                      None of this I do not understand ... I put it anywhere else light source?
                        reymond
                        over 200 times has been viewed this question .
                        out of dkendig and me no one has an answer?
                        I think many do not understand the term "forum"!!! πŸ˜•
                        • ToboboT Offline
                          Tobobo
                          @gwint said:
                          Thank you very much "reymond", but still the same ....
                          have you tried upping the shadow subdivs on the lights?
                          Toby
                          Philippians 4:13
                            Gwint
                            I'm sorry, I'm a beginner. How to set it up?
                            • ToboboT Offline
                              Tobobo
                              Right click on the light group and go to the bottom of the context menu. It should say VRay light with a fly out arrow. the click on edit light. A dialog box should appear with a section for shadows
                              Toby
                              Philippians 4:13
                                Gwint
                                One problem (as shown in 2.jpg) have eliminated by changing Material - Reflection - Glossiness - Treat glossy as GI of Allways the GI rays only and increasing subdivs as written reymond and dkendig.
                                The problem (as shown in 1.jpg) is likely to eliminate possible options Material - Reflection - Glossiness - Hilight and Reflect.
                                Still unfortunately undulating reflections appear (shown in 3.jpg) and do not know how to get rid of them. They appear most often on the walls next to the items that reflect.
                                • andybotA Offline
                                  andybot
                                  This is something that usually happens when there is not enough light on a surface - there is not enough information in the render in those areas, hence the splotchiness. Try increasing the amount of lighting in your scene. You could also try the Brute Force (DMC) method in your Indirect Illumination settings (Primary Bounces) That will give you a more photographic (slightly grainy) transition in these problem areas. If you use irradiance map, you can increase your "hsph subdivs" to something like "90" instead of the default 50. Hope that helps.
                                    cuttingedge
                                    hey guys , had this similar problem and had not found solution. mine looks even worse..I posted this somewhere in this site but none was able to explain. Now Im thinking to shift rendering to another software because of this issue. Can anyone help please.
                                    reflection prob
                                    • jiminy-billy-bobJ Offline
                                      jiminy-billy-bob
                                      It's a sampling issue, either from the light or from the glass itself. Hard to know.
                                      Could you post the skp file so we can have a look?
                                      • chavinskeeC Offline
                                        chavinskee
                                        i think i found a solution for this as i have also experienced this with close up shots. you have to uncheck "use light cache for glossy rays" in the light cache rollout. i hope that this tip would help you out. πŸ˜„
                                        http://chavinskee.blogspot.com/
