VRay Problem - undulating reflections
Hello everyone!
I have a little problem with renderami in Vray, there are strange undulating reflections, how to get rid of?
Try this:
IR Map: Min rate -6, Max rate -1, HSph. Subdivs 80
Light Cache: Subdivs 80 or 90
DMC Sampler: Amount 0.85, Noise threshold 0.008
these are the most important parameters when something is not good you can achieve much in these settings.
try a little.
sometimes helps if you the Subdiv in materials raise to 22 or 32.
Thank you very much "reymond", but still the same ....
can you share your scene?
I mean your sketchup model
My model weighs too much. I threw VRay settings - during the day and at night.
change your output file type to png or something other than jpg. It may just be an image compression artifact
No, because the render also it shows
did you try it?
I understand that after I finished render save the file as a .png or .tif? Unfortunately, on the same ....
ok, I guess it's some setting then.
dkendig says it correctly. it's the image format.
it is probably in connection with your light.
I could see no light source in the kitchen cabinets. where does that light?
used a square with a Emitter material as light source and a ies light.I think your patch in the stored image has to do with the light.
in connection with the reflection of the materials.you Need try ...... but put the light sources as noted.
and try for the high-gloss surface a standart plastic material.I had a thearender issue with a similar problem. and there were the light sources the Problem.
None of this I do not understand ... I put it anywhere else light source?
over 200 times has been viewed this question .
out of dkendig and me no one has an answer?I think many do not understand the term "forum"!!!
have you tried upping the shadow subdivs on the lights?
I'm sorry, I'm a beginner. How to set it up?
Right click on the light group and go to the bottom of the context menu. It should say VRay light with a fly out arrow. the click on edit light. A dialog box should appear with a section for shadows
One problem (as shown in 2.jpg) have eliminated by changing Material - Reflection - Glossiness - Treat glossy as GI of Allways the GI rays only and increasing subdivs as written reymond and dkendig.
The problem (as shown in 1.jpg) is likely to eliminate possible options Material - Reflection - Glossiness - Hilight and Reflect.
Still unfortunately undulating reflections appear (shown in 3.jpg) and do not know how to get rid of them. They appear most often on the walls next to the items that reflect.
