    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 243.9k Views 51 Watching
      @power67 said:
      What am I doing wrong?
      Could be several things. Without seeing your model it's impossible to tell for sure. Are the parts of your model made as separate groups or components?
        arystoteles
        I am trying to use the Eclate plugin in SU8 with no success.
        I made four dimple cubes and either get a bug splat window or after two dialog boxes nothing happens and I dont see the window with options to enter values... any idea why?
          Maybe try the Radial Move
          (first post)
          • Z Offline
            zezaia
            Aleluia!!! thank you Pilou, I want try a long long time to make this
              Give thanks also to CPlassais it's this guy who make the biggest part of codding! πŸ˜‰
                jimmyhopps
                a few more instructions would be fantastic. does not work for me. v3en
                  What do you mean it doesn't work for you? You have to give us some idea of what happens when you try to use it.
                  • E Offline
                    ebelg2000
                    What is the latest English version of this plugin?
                      Seems that is the last of the bottom list, (and there is a date on each item πŸ˜‰
                        trimguy66
                        I am hoping someone can help me.
                        I have downloaded the Eclate_Deplace RB file, and dropped it in to my plugin folder,Which I have attached a screen shot of, but the tool is not showing up within SU.
                        Any help would be greatly appreciated
                        Thank You,
                        Wayne
                          So are you saying that if you select a collection of components/groups and right click on them, you aren't finding Eclate_Deplace in the Context menu?
                            Time to launch SU...
                            Dave was more speed than me πŸ˜‰
                              trimguy66
                              Thank you gentlemen, found it, I was looking in Plugins.
                              This is a great tool, and a great forum.
                              Thanks again!!
                              Wayne
                              • guanjinG Offline
                                guanjin
                                V 0.3.1 version, did not see
                                  Really? Where were you looking?
                                  πŸ˜’
                                  • designerbursaD Offline
                                    designerbursa
                                    thank you
                                      samyell77
                                      Anyone getting bugsplats with this plugin? Love it and find it very useful but for some reason it is buggin out constantly on me - doesn't work at all! Can anyone help.....?
                                      Version numbers below... even tried downloading the current french version but no joy. Tried copying some parts out of my model into a fresh model and still got the bugsplat!
                                      Eclate Deplace - Version 0.3.2 rewritted by Fredo
                                      Radial Move - Version 0.3.2 rewritted by Fredo
                                      SU Pro 2016
                                      Dell Precision M4800
                                      PC Windows 10
                                      Intel Core i7-4900MQ @ 2.80ghz
                                      Nvidia Quadro K2100M
                                      16gb RAM
                                        samyell77
                                        Anyone??? Or is it just me...
                                        Can't get this to work at all for some reason, just crashes every time I try to use it.
                                        Any help or suggestions very gladly received πŸ˜„
                                        SU Pro 2016
                                        PC Windows 10
                                        16gb RAM
                                          I just downloaded and installed it and it works for me on SU2013. Perhaps you have some other plugin that is causing the conflict. Do you have the Vray or Podium plugins? You might try disabling other plugins and see if this one will run for you.
                                            samyell77
                                            Thanks DaveR, will try disabling some plugins and see. Hadn't thought of that - DOH!
                                            SU Pro 2016
                                            PC Windows 10
                                            16gb RAM
                                            • 5 / 9
