    Reload component script - anyone have one
    21 Posts 13 Posters 3.4k Views 13 Watching
      Importing an external component: model.definitions.load http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load
      Position the component: Entities.add_instance(definition, transform) - just copy the transformation of the instance you replace.
      @martinrinehart said:
      I don't know how to find the component to delete. Do you have to cruise through entities looking for Component and then check name. Any less tedious way?
      If you have it's name, then it's easy: model.definitions['definitionName']
      I think the code would be something like this:
      newDef = model.definitions.load(path_to_new_component)
      oldDef = model.definitions['definitionName']
      oldDef.instances.each { |old_inst|
        t = old_inst.transformation
        ents = old_inst.parent.entities
        ents.add_instance(newDef, t)
        old_inst.erase!
      • honoluludesktopH Offline
        honoluludesktop
        This is a great plugin, especially for landscape visulization.
          Moved this topic to the Developer section of the forum.
            sahi
            It is my experiment.
            Prompt me if that not so.
            1. we choose a file (this will be a folder )
            2. We enter the name of component
            3. we choose a component in which and will replace
            Attention!!!! Attention!!!! Attention!!!! before the use backup folder
            menu "Plugins >> reload_component"
            reload_component2.rb
              SLOf1Fan
              For some reason I have recently found that right-clicking a residence model in my site model to update the revised component does not work. I get the usual pop-up stating the component has been added and asks if I'd like to replace, however when I click yes, nothing happens. It used to open the file folder so I can select the replacement folder. Please help.
                Technical Ben
                Sorry to post in an old thread. But I'm looking for something similar to this.
                Just a hobby project, but I would really like a tool that checked for updates to components for me.
                So, I have a large file separated into separate components, these are save in a folder (such as Floor 1, Floor 2, Floor 3 etc). These are constructed into one big model (Such as "House"). I would like a script that automatically loaded up the components from file, when I opened the main project. I thought Sketchup did this automatically, but I have to click "reload" and each component separately. 😞
                  honoluludesktop
                  Select Window > components, right click the component you want to change in the component's window, then "select instances", again right click the component in the component's window, and "reload", "yes", and find the .skp you want.
                    My old XrefManager does do this BUT you need to have added the items as an 'Xref'... It is long overdue an update, but does list components that have changed externally and then allows you to reload them...
                      Technical Ben
                      Thanks honoluludesktop.
                      I'll have to do that, and force myself not to amend objects in the wrong file.
                        BigAl
                        I'm using Thom Thom's lines of code below to batch replace a series of proxy components with hi-res versions.
                        old_inst.erase!
                        To speed this process up I'd like to add a conditional test before this code such that the code to replace Component A with Component B only runs if Component A already exists within the model. Otherwise skip to the next component in the list.
                        Does such code or similar already exist somewhere?
                        Any help greatly appreciated.
                        • Dan RathbunD Offline
                          Dan Rathbun
                          It looks like it already does that.
                          Meaning ComponentA's defintion's instances collection is iterated, and the statements within the curly delimited block are run if the collection has any references pointing at instances that have been placed within the model.
                          IF the instances collection is empty, then the iteration loop is exited without running the block.
                          I'm not here much anymore.
                            BigAl
                            Thanks Dan,
                            I hadn't noticed that behaviour before. Initially being only interested in getting a couple of components into the model it wasn't an issue and I would always have the proxies in the model to check that the swap worked ok.
                            Looking at this again it looks like the components are all loaded into the file in turn. When I repeat ThomThom's text as below only Comp4 gets deleted if not required to replace comp3 (being the last to be loaded). Comp2 get left behind.
                            newDef = model.definitions.load("J:/Comp2.skp")
                            oldDef = model.definitions['Comp1']
                            oldDef.instances.each{|old_inst|old_inst.definition=newDef
                            old_inst.erase!
                            newDef = model.definitions.load("J:/Comp4.skp")
                            oldDef = model.definitions['Comp3']
                            old_inst.erase!
                            • 2 / 2
