Truncated octahedron
This is the model, i am searching for. Thanks for your reply.
@dave r said:
[attachment=0:2jxchhn0]<!-- ia0 -->Oct.png<!-- ia0 -->[/attachment:2jxchhn0]
Like this?
Draw an octahedron. Or draw a pyramid, copy and flip it to make the other half.
Draw a face to cut where you want the truncation.
Select the geometry and run Intersect Faces>With Selection.
Delete the waste. -
Another similar solution: see this screencast...
Here's a quick and dirty way of drawing this type polyhedron.
SS
cotty, thanks for revealing screenr.
Carsten, that's great.
Scott, I like that your method, too. No plugins required.
A truncated Octahedron is a very simple structure if you know the trick. People struggle with the calculations of the angles involved, but they are pretty simple too when you know them. You only need to know 54.736 deg and 35.264 deg add up to 90 deg.
However, if you haven't had that particular bisection of 90deg drilled into you at birth, you'll find the simple split cube method easy to use and remember.Start with a cube of any size, cut through it on the diagonal mid points and remove one side, this will create one eighth of the shape which can then be rotated and flipped to make the rest.
No calculations, no head scratching no hair pulling.See vid for clarity.
[screenr:2owcfgcb]QkmH[/screenr:2owcfgcb]
How did u make one pyramid into octahedron? What option have you used to get exact alignment of pyramid to for octahedron. Can you please tell me ?
You don't need a plugin for this shape, only basic tools...
Screencast -
Is it not the shown shape in the screencast?
It is not. Please see that two adjacent facets are not same. One is rectangle and another one is trapezoid. There is a difference.
Thanks and regards,
Gangaiah -
Thanks for sending screen shot. But, it is only half of the structure. Making it full was little tricky. The similar way, I have also followed and partially succeed.
A better image would help more!
see if this is close
Can you please tell me how to draw, the model of the attached file. It is 2D image, similar to truncated octahedron. Kindly make a video and write what tool you are using in constructing such shapes.
Thanks and regards,
Gangaiah. -
Dear Cotty,
Can you please teach me, how to draw the shape attached herewith.Thanks and regards,
Ganagiah. -
Can any one help me in drawing this shape?
I want to know how to make some portion of an object porous?
