    Truncated octahedron
    22 Posts 9 Posters 3.4k Views 9 Watching
      gangaiah
      Can any one tell me how to draw truncated octahedron in sketchup?
        gangaiah
        Google Images
        Google Images. The most comprehensive image search on the web.
        (www.google.co.in)
        This is the model, i am searching for. Thanks for your reply.
        @dave r said:
        [attachment=0:2jxchhn0]<!-- ia0 -->Oct.png<!-- ia0 -->[/attachment:2jxchhn0]
        Like this?
        Draw an octahedron. Or draw a pyramid, copy and flip it to make the other half.
        Draw a face to cut where you want the truncation.
        Select the geometry and run Intersect Faces>With Selection.
        Delete the waste.
        • cottyC Offline
          cotty
          Another similar solution: see this screencast...
          my SketchUp gallery
          • S ShepherdS Offline
            S Shepherd
            Here's a quick and dirty way of drawing this type polyhedron.
            Screenr
            SS
            cotty, thanks for revealing screenr.
              Carsten, that's great.
              Scott, I like that your method, too. No plugins required.
              • cottyC Offline
                cotty
                Screenr
                SS
                my SketchUp gallery
                • BoxB Offline
                  A truncated Octahedron is a very simple structure if you know the trick. People struggle with the calculations of the angles involved, but they are pretty simple too when you know them. You only need to know 54.736 deg and 35.264 deg add up to 90 deg.
                  However, if you haven't had that particular bisection of 90deg drilled into you at birth, you'll find the simple split cube method easy to use and remember.
                  Start with a cube of any size, cut through it on the diagonal mid points and remove one side, this will create one eighth of the shape which can then be rotated and flipped to make the rest.
                  No calculations, no head scratching no hair pulling.
                  See vid for clarity.
                  [screenr:2owcfgcb]QkmH[/screenr:2owcfgcb]
                    gangaiah
                    How did u make one pyramid into octahedron? What option have you used to get exact alignment of pyramid to for octahedron. Can you please tell me ?
                    • cottyC Offline
                      cotty
                      You don't need a plugin for this shape, only basic tools...
                      Screencast
                      my SketchUp gallery
                      • cottyC Offline
                        cotty
                        Is it not the shown shape in the screencast?
                        my SketchUp gallery
                          gangaiah
                          It is not. Please see that two adjacent facets are not same. One is rectangle and another one is trapezoid. There is a difference.
                          Thanks and regards,
                          Gangaiah
                          • cottyC Offline
                            cotty
                            Does this screencast help as a start?
                            micro_thing_2.zip
                            my SketchUp gallery
                              gangaiah
                              Thanks for sending screen shot. But, it is only half of the structure. Making it full was little tricky. The similar way, I have also followed and partially succeed.
                              • ely862meE Offline
                                ely862me
                                A better image would help more!
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • rodrigonotorR Offline
                                  rodrigonotor
                                  Take a look at this page
                                  http://georgehart.com/
                                  and this
                                  http://www.software3d.com/Stella.php
                                  Regards
                                  • Sketchando.net • www.arqcad.net •
                                    rodrigonotor
                                    Maybe this can help
                                    http://sketchup.google.com/3dwarehouse/details?mid=9aa6ad14b2893e0971d2efc406c05747&ct=mdrm&prevstart=0
                                    http://en.wikipedia.org/wiki/Truncated_octahedron#Orthogonal_projections
                                    • mitcorbM Offline
                                      mitcorb
                                      see if this is close
                                        gangaiah
                                        Can you please tell me how to draw, the model of the attached file. It is 2D image, similar to truncated octahedron. Kindly make a video and write what tool you are using in constructing such shapes.
                                        Thanks and regards,
                                        Gangaiah.
                                          gangaiah
                                          Dear Cotty,
                                          Can you please teach me, how to draw the shape attached herewith.
                                          Thanks and regards,
                                          Ganagiah.
                                            gangaiah
                                            Can any one help me in drawing this shape?
