    Simple animation - rotation about an axis?
    24 Posts 6 Posters 7.1k Views 6 Watching
    • TK0001T
      TK0001
      @box said:
      Sounds like you need to use something like Sketchfab.
      You can upload the whole model and interact with it.
      ERROR: The request could not be satisfied
      (sketchfab.com)
      Woah, this may be a game changer. Thanks for sharing it. I will play around with this and see if it can do what I'm envisioning.
      I want to be able to highlight certain subsystems within the entire facility by graying out the rest of the model, and then be able to interact with those as well. I hope this is something that can be handled by sketchfab, because my alternative is to pay an animator big $ to do it!
      • TK0001T
        TK0001
        @dave r said:
        @tk0001 said:
        I also just tried to simply use Sketchup's animation using scenes, but the animation zooms in and out between scenes, and I want it smoother.
        It shouldn't do that unless you change camera positions and zoom when setting up the scenes. You can also set up Updating of scenes to not change or record camera setting parameters. The example I posted doesn't show any camera changes at all.
        That video is still available although I don't know why it won't run in the blog post. Try this link. Sorry about the ads. they are supposed to be disabled but they still show. πŸ˜’
        I'd do some of that animation stuff differently but the idea is there.
        Ah, thanks for the new link. Now that I see the example, I understand the theory. My issue is the model may be too big for this technique to effectively work (maybe I'm wrong).
        • BoxB
          Grabcad is another option you may want to explore if you are thinking along those lines.
          http://grabcad.com/workbench
          • TK0001T
            TK0001
            I'll look into this as well, but for now I'm looking for something simple that will give me the ability to spin the model on an axis and export the video. Do you know of a solid plugin that can accomplish this?
            • BoxB
              As I said in my first post to this thread, the normal SU tools will do that.
              Place your model centered on the origin and use the camera standard views (front, left, right.......) to set up four scenes to create a simple rotation and export the animation.
              You can export it as a vid or as images to create a gif
              • TK0001T
                TK0001
                Forgive me for being obtuse, but I need an elevated view, not just front, sides, and back. So I created my 4 ISO views and played it back, and the view "bounced" between each view. It was not a smooth, seamless orbit of the model.
                • TK0001T
                  TK0001
                  I believe Dave addressed my issue here, but I'm afraid I need a little more of an in-depth explanation in order to grasp it.
                    That's how I made this animation.
                      What do you need? If the camera remains stationary as it does in my lock stitch and sideboard animations, there won't be any zooming or anything. If you need to move the camera between scenes, you could establish specific points for the camera along a path. You could do that with the native Position Camera tool or use something like Bezier Flightpath. For simply making it appear as if an object is moving maybe you don't need to move the camera at all.
                      • BoxB
                        If you just want to move around and look at different parts of your site from different angles, you just need to set the scenes as you want them and in a sensible order.
                        I made this vid since your last post, with a little time you can make something very nice and neat with the built in tools.
                        [screenr:2mui69hz]6ImH[/screenr:2mui69hz]
                          Would this be close enough? Cycle through the scenes.
                          round and round.skp
                          • TK0001T
                            TK0001
                            Thanks for spending the time on this with me, guys. Unfortunately, the two examples you provided are not what I'm looking for. I know I can achieve this through setting up scenes in SU. I need a continuous orbiting view with no "bouncing" or hesitation.
                            What I have is a 3D model of a large parcel sortation facility (see attached image). The manager of the facility wants me to animate the model and have it displayed on a monitor. There is more to it, but essentially I need a tool that can record a video of a camera slowly orbiting the model. This will essentially be the "screensaver" mode.
                            There is a plugin I downloaded recently from the plugin store called "animation 2". It provides exactly what I need but I can't seem to record the animation and export it. But if you were to download this plugin, then go to Camera --> Animations --> Spin View, this is exactly what I'm looking for. It starts at the ground, then does a spiraling orbit around the model.
                            Sort Facility
                            • renderizaR
                              renderiza
                              Hi, if you want to record and export the animation from "animation 2" then I recommend you get "Fraps".
                              http://www.fraps.com/
                              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                              • BoxB
                                I don't know what you mean by Bouncing. But I think you are missing the point of the built in animation, you can set the scenes any way you want, change the frame rate, the scene delay, the scene transition...... in other words you build the animation you want rather than an automated setup.
                                • TK0001T
                                  TK0001
                                  Okay, I figured it out. In a test file, I got a the camera to orbit a small piece of equipment exactly like I wanted. The key was being able to position the camera...AND aim it at a common fixed point. I knew you could position the camera and create a scene, but I was not aware that you could click, then drag the view of the camera to a fixed point. That was the piece I was missing. Once I figured that out, everything fell into place. No plugins were necessary, as was mentioned.
                                  Thanks for the help, and if you were trying to get me to see the point above and I just missed it, my apologies.
