    Simple animation - rotation about an axis?
    24 Posts 6 Posters 6.9k Views 6 Watching
    • BoxB
      The built in animation function of SU pretty much only moves the camera, so moving things around in 3d space makes no difference. therefore if you have a scene looking at something from the front, then rotate the object so you are looking at the side and create another scene, nothing will happen. But if you have the same front scene, then move the camera around to the side and create another scene then it will animate that movement.
      There are animation plugins that allow you to move things around within SU.
      Simplest way to do this, place your central object centred on the origin point. Then place the four other objects around it, use the Camera/standard views option to move the camera to, front then side back etc etc, creating a scene for each view. Then view the animation of those scenes and the four objects should rotate around the central one.
        I did this a long time ago showing how to animate something moving objects within SketchUp. It doesn't require any plugins.
        I used the same process to do this animation for Threads Magazine.
        • SimFonIA_teamS
          SimFonIA_team
          Hello CFish,
          I suggest you took a look at our plugin
          404 Not Found
          (sketchucation.com)
          Give life to your ideas : http://www.simfonia.fr/SAT/
          • renderizaR
            renderiza
            Hi, I also recommend SimFonIA Animation Tools for animating inside SketchUp. Here is one of my animations done with it...
            Cheers!
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • TK0001T
              TK0001
              I am in the same predicament. I have a large material handling/parcel sortation system which a client is requesting be displayed upon a large monitor in his lobby, where people can interact with it. All I want to do is spin the entire facility about a central axis, and control the speed of the rotation as well as the size of the exported video.
              Investigating different animation plugins is overwhelming. I want something very simple, but it seems that I need to invest a day immersing myself in a plugin just to learn the basics, and at the end of the day I don't know if it will do what I want without having to buy the entire package.
              I have tried Podium and SimFonIA, and both seem buggy (the documentation for the latter doesn't seem to be originally written in English, which compounds the issue). I also just tried to simply use Sketchup's animation using scenes, but the animation zooms in and out between scenes, and I want it smoother.
              I am willing to dive into a plugin, as long as I know it will do what I want at the end of the day, and I'm not spinning my wheels. That's why I need suggestions. I'd rather not spend a ton of money on it, since all I need is a simple rotation loop and all the other bells and whistles are unnecessary.
              Any assistance or input would be greatly appreciated.
              • TK0001T
                TK0001
                Also, this video doesn't seem to be active any more. I would love to view it, if you still have it.
                  It shouldn't do that unless you change camera positions and zoom when setting up the scenes. You can also set up Updating of scenes to not change or record camera setting parameters. The example I posted doesn't show any camera changes at all.
                  That video is still available although I don't know why it won't run in the blog post. Try this link. Sorry about the ads. they are supposed to be disabled but they still show. 😒
                  I'd do some of that animation stuff differently but the idea is there.
                  • BoxB
                    Sounds like you need to use something like Sketchfab.
                    You can upload the whole model and interact with it.
                    ERROR: The request could not be satisfied
                    (sketchfab.com)
                    • TK0001T
                      TK0001
                      (sketchfab.com)
                      Woah, this may be a game changer. Thanks for sharing it. I will play around with this and see if it can do what I'm envisioning.
                      I want to be able to highlight certain subsystems within the entire facility by graying out the rest of the model, and then be able to interact with those as well. I hope this is something that can be handled by sketchfab, because my alternative is to pay an animator big $ to do it!
                      • TK0001T
                        TK0001
                        Ah, thanks for the new link. Now that I see the example, I understand the theory. My issue is the model may be too big for this technique to effectively work (maybe I'm wrong).
                        • BoxB
                          Grabcad is another option you may want to explore if you are thinking along those lines.
                          http://grabcad.com/workbench
                          • TK0001T
                            TK0001
                            I'll look into this as well, but for now I'm looking for something simple that will give me the ability to spin the model on an axis and export the video. Do you know of a solid plugin that can accomplish this?
                            • BoxB
                              As I said in my first post to this thread, the normal SU tools will do that.
                              Place your model centered on the origin and use the camera standard views (front, left, right.......) to set up four scenes to create a simple rotation and export the animation.
                              You can export it as a vid or as images to create a gif
                              • TK0001T
                                TK0001
                                Forgive me for being obtuse, but I need an elevated view, not just front, sides, and back. So I created my 4 ISO views and played it back, and the view "bounced" between each view. It was not a smooth, seamless orbit of the model.
                                • TK0001T
                                  TK0001
                                  I believe Dave addressed my issue here, but I'm afraid I need a little more of an in-depth explanation in order to grasp it.
                                    That's how I made this animation.
                                      What do you need? If the camera remains stationary as it does in my lock stitch and sideboard animations, there won't be any zooming or anything. If you need to move the camera between scenes, you could establish specific points for the camera along a path. You could do that with the native Position Camera tool or use something like Bezier Flightpath. For simply making it appear as if an object is moving maybe you don't need to move the camera at all.
                                      • BoxB
                                        If you just want to move around and look at different parts of your site from different angles, you just need to set the scenes as you want them and in a sensible order.
                                        I made this vid since your last post, with a little time you can make something very nice and neat with the built in tools.
                                        [screenr:2mui69hz]6ImH[/screenr:2mui69hz]
                                          Would this be close enough? Cycle through the scenes.
                                          round and round.skp
                                          • TK0001T
                                            TK0001
                                            Thanks for spending the time on this with me, guys. Unfortunately, the two examples you provided are not what I'm looking for. I know I can achieve this through setting up scenes in SU. I need a continuous orbiting view with no "bouncing" or hesitation.
                                            What I have is a 3D model of a large parcel sortation facility (see attached image). The manager of the facility wants me to animate the model and have it displayed on a monitor. There is more to it, but essentially I need a tool that can record a video of a camera slowly orbiting the model. This will essentially be the "screensaver" mode.
                                            There is a plugin I downloaded recently from the plugin store called "animation 2". It provides exactly what I need but I can't seem to record the animation and export it. But if you were to download this plugin, then go to Camera --> Animations --> Spin View, this is exactly what I'm looking for. It starts at the ground, then does a spiraling orbit around the model.
                                            Sort Facility
