    [Plugin] PanoScene v1.0.0
    10 Posts 5 Posters 12.2k Views 5 Watching
    • renderizaR Offline
      renderiza
      [pre:to4637uw]Authors:: Renderiza
      Plugin Name:: PanoScene
      Version:: 1.0.0
      Date:: 7/20/2013
      Cost:: Free[/pre:to4637uw]
      PanoScene
      Create panoramic scenes so that you can then export them and use image stitching software to merge them. To make it easier to export scene I recommend using another plugin called [SUCh v1.0.2.]
      http://s22.postimg.org/4qsrbrk9d/pano_icons.png
      Available at
      sketchUcation
      pluginStore
      click here
      ______________________________________________________________________
      Extension Warehouse
      click here
      Note: If the latest version is not yet available at Extension Warehouse that means it is still awaiting to be approved by the quality assurance team to make sure extension meets the technical and security requirements.
      Recommended Plugins :
      [SUCh v1.0.2]by Renderiza- This plugin has a feature to export all scenes as image files.
      ElevTag v1.0by TIG- This will place tags to create elevation scenes.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • olisheaO Offline
        olishea
        not had chance to try it yet but this looks like an awesome plugin!! Does it take zenith and nadir shots?
        oli
          renderiza
          Not sure what zenith or nadir is...can you post some example image links? Since I don't even know what they are its unlikely they can be done with this plugin but will certainly give it a try for next update.
          • TIGT Online
            Zenith = the highest point
            Nadir = the lowest point
            Presumably in this context, meaning the 'top looking down' and the' bottom looking up', respectively ?
              renderiza
              I kinda get it now... Right now there is only control over the X,Y degrees but maybe for next version a Z degrees control can be added as well.
              Note: here is a video that mentions zenith and nadir shots...
              Here is a pretty cool example of the capabilities of Pano2VR (Not Panoscene).
              VRAY+PANO2VR制作360度全景效果图 - SketchUp资源库 - SketchUp吧 - SketchUp中文门户网站
              (www.sketchupbar.com)
              Here is also a video intro of Pano2VR which is pretty cool!
              Lots of cool ideas in that last video that would be cool to implement! 👍
              • olisheaO Offline
                olishea
                Sorry, Zenith is directly above and Nadir is directly below. So imagine taking a photo looking directly up and then directly down, respectively.
                This means you can make full 360 degree panoramas if you include it. Although you may need to to take a couple of nadir and zenith shots because we don't have a fisheye lens in sketchup. Normally I only need to to take 1 zenith and 1 nadir with a fisheye. 👍
                oli
                  renderiza
                  I wonder if merging multiple nadir and zenith shot will work the same as 1 shot with fisheye lens.
                  • olisheaO Offline
                    olishea
                    Yes it works, this is how you make a pano without a fisheye. I think you may need 3 nadir shots and 3 zenith shots to compensate.
                    oli
                    • cottyC Offline
                      cotty
                      Not tried it yet, but reminds me of cubicpanoout, which creates 6 scenes for a cubic panorama projection...
                      my SketchUp gallery
                        Macker
                        I don't understand how to operate this. It just creates two scenes (Default and a_-180░) then does nothing.
                        Check out my blog @ http://macviz.blogspot.co.uk
