    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    PluginStore Now Online!
    27 Posts 14 Posters 2.8k Views 14 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @tig said:
      It is a known serious issue with v2013. ๐Ÿ˜’
      And of course two docked toolbars can't occupy the same screen-space [which is something to do with quantum mechanics ๐Ÿ˜‰ ] ...
      I believe this is termed the "API Toolbar Exclusion Principle" ...
      ... which basically postulates that at any given time you can know whether (or not,) a toolbar exists, ... but not where it is located. ..and visa versa.
      ๐Ÿ˜†
      I'm not here much anymore.
      • sicksickisckS Offline
        sicksickisck
        new SU2013 is like new x-box ๐Ÿคฃ
          dammerel
          hi all
          plugin store (from SU) gives this error
          Connect Error (1049) Unknown database 'plugins'
          any ideas why??
          Andrew
            @dammerel said:
            hi all
            any ideas why??
            Andrew
            Try clearing your default browser's cache, and retry...
              deanlegg
              What do you mean, er how do you do it?
                Normally, Ctrl+F5
                  Since you haven't given us your OS details etc in your User-profile ๐Ÿ˜’ ... let's guess...
                  Webdialogs in SketchUp use your computer's default browser - which is always IE on a PC and Safari on MAC.
                  Sometimes when you have reloaded SketchUp tools that use webdialogs you might get older versions stuck in the browser's 'cache', and so the newer version doesn't appear... ๐Ÿ˜ฎ
                  To clear your browser's cache use its tools...
                  On IE it's:
                  Ctrl+F5 OR F12 then Ctrl+R... OK to apply...
                  On Safari it's :
                  Preferences > Advanced tab.
                  Select: Show Develop menu in menu bar
                  Now from the menu bar click Develop > Empty Caches...
                  Being able to clear your browser's cache is a very useful ability.
                  Not for use just with SketchUp... ๐Ÿ˜‰
                    deanlegg
                    ๐Ÿ˜ณ Ahem , profile updated
                    TIG I did the clear up and still get the same message
                    any ideas?
                      Have you got/installed the latest version from here ?
                      http://sketchucation.com/resources/plugin-store-download
                      This gives you the SketchUp based equivalent listings...
                      Your browser ought to access the SCF PluginStore site...
                      If it accesses other areas ?
                      Have you looked at your 'Internet Settings' to see if they block anything - like javascript ??
                        snk2525
                        the SCF plugin store is providing a plugin that is compatible with SU 8 but not Su pro 2013. I am getting error like >>
                        "Error Loading File SectionPropCalculator.rb
                        undefined method `GetString' for nil:NilClass"
                        can someone help me out, this one is an important plugin for me, I need it at any cost. it was working big time with SU 8 , but after I installed Su 2013 , I tried installing the same via SCF plugin to install it but
                        this is the plugin
                          I'm going to make a guess that you have less plugins installed for SU2013? And that Section Properties Calculator is using the LanguageHandler function in SketchUp without require 'langhandler.rb' defined - something it could get away with if another plugin loaded before it used. If now, under your new SU2013 installation this plugin is first to load then that would explain the error.
                          SU2103 does not have any difference in the Ruby API from SU8 - so plugins should be working a like on both versions. So this would be an error that crops up due to difference in environment or setup.
                            I will correct the missing 'requires' in this script and repost it in the PluginStore as v1.1a
                            Watch for an update...
                            v1.1a is now there http://sketchucation.com/resources/pluginstore?pln=SectionProp
                            • 2 / 2
