    Follow-me tool along split path?
    20 Posts 6 Posters 2.3k Views 6 Watching
      [screenr:puavc98b]FZWH[/screenr:puavc98b]
        ...then you smash it 😎
        • BoxB
          One thing to note, if you create complex geometry, whether by plugin or manually, and it is repetitive you tend to over stretch the file size quickly.
          Try looking at you construction from a real world view and see how you can break it down into reusable components. One straight pipe with an angle curved corner can be flipped around in various directions to form many jointed corners. This allows you to work with easily editable sections and keeps you file size down.
          To look at it a simple way, using line to tube on 100 lines is easy but it uses resources, whereas those same 100 lines as component copies are tiny file size, easily modified automatically or easily made unique. It pays to plan ahead sometimes.
            Cool for the Blendy animation! πŸ‘ πŸ˜†
            In fact you can make the same inside Sketchup!
            Just use Artisan or Subdivide and smooth πŸ˜„
            Then Zorro 2 for cut your object
            • Close Holes
              and at the end
              SketchyPhysics! πŸ’š
            http://www.polyloop.net/attachment.php?attachmentid=32496&d=1348004456
            And in 2D physic simulation try Algodoo! (its free for pc & MAc , 5 $ for an ipad)
            You input your objects from sketchup by an PNG image with a transparent background !
            You can play with these ones! πŸ˜„
            http://s6.postimg.org/pqg6vhw0h/for_algodoo.png
              Soap Skin and Bubble gives a very cool result! πŸ˜„
              You have just to draw the 2 triangles External and internal as Shown in my post above!
              Not a big deal πŸ˜„
              In fact for each just one side of the triangle that you copy rotate by 90Β°! πŸ˜‰
              External : Division 30
              Internal division 20
              Pressure 150
              cubicsoap.skp
              • Bob JamesB
                Bob James
                Algodoo for an ipad is also free now πŸ˜„
                  Have you a link ?
                  Because I obtain that! 😲
                    More rustic than mine! πŸ˜„
                    But maybe the target! β˜€
                    • takesh hT
                      takesh h
                      Hi Bob,
                      I may be misunderstanding and it is far from a simple "one-click operation",
                      but... is this what you want to do? ❓
                      EDIT: "each tube is a group" should be an option of Lines2Tubes plugin. 😳
                      EDIT2: You don't have to start with a wireframe... could (or should?) be a simple cube.
                      • B
                        BobObba
                        I apologise for going AWOL, i posted this in work (while looking for the solution) and then went and took an extended weekend.
                        Anyway, you guys are incredible - Pilou, your method is perfect for a gentle column angle and Takesh h, your method of using the intersect curve from Round Corners.rb will prove perfect for more acute angles and Box, your advice about trying to take a component and re-use is well heeded. Your collective enthusiasm to help us mere mortals is inspiring.
                        I admit I was hoping for a quick fix plug-in (since I have about 25 unique geometry columns to model) but both your steps are very clear and reproducible so shouldn’t take too much time… as long as the scheme doesn’t keep changing like it did today πŸ˜•
                        Oh, and Rich O Brien, the Blender demo makes me wish we used something more advanced than SK in my office.
                        Cheers all!
