    [Plugin] MatrixProximity Update v1.9 20110708
    40 Posts 9 Posters 32.0k Views 9 Watching
    • B
      Bertier
      salut Pilou sur mon clavier c'est : "Alt Gr + é" mais il faut le faire "é" fois et effacer une instance...
      comment c'est sur le tien ?
        http://en.wikipedia.org/wiki/Keyboard_layoutCapture.PNGCapture1.PNGCapture2.PNGCapture3.PNG
        • GaieusG
          Also mine... 😄
            or like this but I don't remember how to make the Shortcut U + 007E 😳 😳 😳
            (alt + u + 07E don't works 😞
              You type the Unicode '007e' then 'Alt+X'..... BUT it only works in MicroSoft tools like Word etc, and NOT in Sketchup!
                yes but what is the key for start Unicode?
                If I use Alt+.... it's finally open some shortcuts menu! 😳
                (I just try with the NotePad and WordPad )
                It's not vital 😉 As the more simple is copy past from the post here 😄
                And I have it on my keyboard 😄
                  Alt+0126 writes a tilde [~]...
                  Into Sketchup Text objects and any dialog text-fields etc - the symbol appears when you release the Alt key 😄
                  Here's a useful list of all of the PC's 'Alt codes', used to get special symbols into your text... http://www.alt-codes.net/
                  Some are more useful than others like...
                  degrees Alt+167/248/0176 º°°
                  half Alt+171 ½
                  plus/minus Alt+241 ±
                  divide Alt+246 ÷
                  squared Alt+253 ²
                  cubed Alt+252 ³
                  bullets Alt+7/8/9/10 •◘○◙
                  cent Alt+0162 ¢
                  euro Alt+0128 €
                  French "" Alt+174/175 « »
                  Spanish inverted-qu'/ex'mark Alt+168/173 ¿ ¡
                  BUT ☺♪♫☼↨‼
                    Ah ok I must tranform hexa 7e in decimal! 💭 ☀ 😳
                    so 7E = 126 😒
                    Now all works fine 👍
                    Seems ALT + 126 ~is sufficient~
                      rachmatrf
                      Thank you very much TIG..... You Rock!!
                        JackB
                        What a great tool! Really intuitive and exactly what I needed. Thanks.
                        • K
                          kaas
                          hi TIG,
                          Recently I did a project with lots of (high-polycount) trees and several camera positions. I really was missing some kind of LOD system. For instance, in one view some trees were very near and I wanted to use the high res version, in another view they were more in the distance and a low poly version would have speeded up the export of the views.
                          So I looked for an LOD system for sketchup and Google turned up your 'old' plugin. I tried it in Sketchup 8 (the clients preferred version) but I can't get it to work. See attached file (all the components should be saved inside). What am I doing wrong??
                          Regards, Max
                          proximity.skp
                            @kaas said:
                            hi TIG,
                            Regards, Max
                            You example SKP only contained instances that were called 'doos'.
                            If they had been named 'doos+' or 'doos-' or 'doos~' the Proximity WILL work.
                            So Select all of the 'doos' and use the context-menu option in the Components-Browser to replace all selected with 'doos-' ...
                            Run the tool and, depending on your settings and the instances distance from the camera, you'll get 'doos+' or 'doos-' or 'doos~' for each appropriate instance...
                            • 2 / 2
