    Need advice on using Artisan
    15 Posts 7 Posters 1.5k Views 7 Watching
      here the link for examples with Artisan by Cotty
      • ely862meE
        ely862me
        Please attach the image ! See in the left side, down the Save draft button, Upload attachment !
        Elisei (sketchupper)
        Come and See EliseiDesign
        • K
          kaas
          If I may hijack this thread... I could need some advice on using Artisan too.
          I'm trying to model Roundstack by Stackstoves. I'm having trouble creating the proxy for the red part. The extruded front shape keeps messing up the vertical cylinder (very clear in renders or during walk throughs in LightUp).
          Also, I need to add lots of rounded edges already just to control the shape before pressing Subdivide & Smooth.
          Any tips for changes to the proxy??
          greetings, Max
          edit: changed the image to higher resolution
          • K
            kaas
            The image was there but I deleted it while I was editing my post and uploading a higher resolution file. Apparently you were reading my post at exactly the 20 seconds there was no image anymore..
            • K
              kaas
              Pilou, thanks for your reply.
              I'm wondering if this particular shape can be made with a simple proxy or that I should already put in a more rounded shape and just use Artisan to soften the result. The intersection between the 2 shapes keeps messing up the end result. I haven't found the right combination of edges and creases yet.
              I'm very curious though if a simple proxy is possible for this shape at all so I hope someone of the more experienced Artisan users can point me into the right direction...
              It's very much fun though, a great plugin!
              • K
                kaas
                Just finished the stove. I tried several strategies and had the best results with the lowest polycount by rounding the corners already before using Subdivide and Smooth.
                Still I'm curious if an experienced Artisan can achieve a good result with a simple proxy instead.
                • HieruH
                  Hieru
                  Kaas,
                  I think you would still get good results using your approach if you further reduced the number of circle and bevel segments.
                  Without using bevels and keeping the proxy as simple as possible, this is how I would tackle the shape:
                  Subdivision is done with 2 iterations.
                  The trick here is to use just enough segments and make sure that the block doesn't intersect with the tube along segment edges.
                  Artisan.skp
                  www.davidhier.co.uk
                    Seems you must deal with that πŸ˜‰
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/8983330_orig.jpg
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/494823496.png
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1056565_orig.jpg
                    • C
                      cymro
                      Sorry for the delay in thanking the above for their help.
                      The original outline was too complex, I have redrawn it and with you're help I am getting the results I am looking for.
                      Many thanks
                      Stephen
                      • K
                        kaas
                        @hieru said:
                        Kaas,
                        Hieru, Thanks for your reply and the trick you mention. I'm going to test it soon.
