    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      Please read this...
      http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
      Can I recommend that first you learn to use the SCF Search functions - you'll be amazed what you might then learn...
        alio
        Thanks for the information.
        • P
          panda_ska8er
          Thank you very much!
            JLspeeddragon
            Great Plugin! I cant get enuf of how easy and fun it is.. Dont forget to DL the weld and Progress plugin if you are trying this for the first time
            • V
              Vic12
              Hi -
              I've downloaded and installed both shape bender and progressbar.rb
              I can see shape bender checked in my extensions folder - so it should be active
              I can also see progressbar.rb in my plugins folder - although can't find it anywhere on screen - but assume it is there (is there a way to check that?)
              but I cannot find shape bender (or Chris Fullmer's tools) anywhere in my toolbar
              any suggestions on how to activate/use?
              thanks
                Progressbar.rb is the helper that adds a progress-bar to the status-bar when you are using ShapeBender plugin.
                That 'script' doesn't 'appear' anywhere else otherwise...
                You haven't completed your User-profile details so we don't know your OS or SUp version...
                If you can see the ShapeBender plugin's Extension and check it, then it should add the Toolbar option to the View > Toolbars list
                Unless perhaps you have somehow mis-installed the plugin's files and moved some of them from their subfolder into the main Plugins folder?
                How did you install the plugin?
                There are several 'foolproof' ways of doing this - with 'AutoInstallers' etc...
                Manual installs are prone to have problems...
                Do you have FULL security permissions to your Plugins folder?
                Is there a 'Compatibility Files...' link/button on the Explorer window's top bars - a sure sign of limited rights...
                Fix the permissions to be FULL for all users etc...
                • V
                  Vic12
                  Help-
                  I've downloaded and installed both progressbar.rb and shape bender - progressbar is in my plug-in folder and shape bender shows up as checked in my extensions -
                  but I cannot find it in my toolbar anywhere
                  what am I doing wrong-
                  what am I not activating?
                  thanks
                  • V
                    Vic12
                    Hi TIG - sorry missed your first post-
                    I installed both shape bender and progressbar manually
                    library - applications support - sketchup 8 - plugins
                    but I think I might have moved the shape bender rb out of the folder it came in - when it first wasn't showing up -
                    maybe that's the problem- just moved back in and I'll restart and see if that helps?
                    I'm on MAC OS 10.7.5 and running SU 8
                    or do I need to uninstall and re-install?
                    • V
                      Vic12
                      when I unzip the file - I get a folder
                      clf_shape_bender_v055
                      inside the folder is another folder w/ clf_shape_bender and the ruby script clf_shape_bender_loader.rb
                      I took the ruby out of the folder and placed it in my plugins folder
                      HD-library-applications support-google8-SU-plugins
                      then shape bender showed up in my extensions - checked-
                      but nowhere in my toolbar -
                      when I put the rb back in the folder it came in then the extension went away-
                      thanks - Victoria
                        Victoria, your screen shot shows you haven't installed Shape Bender correctly. Move the two files in the far right column into the Plugins folder directly. Then restart SketchUp. If you installed it with the SCF Plugin Store you wouldn't have this problem.
                        • V
                          Vic12
                          got it working thanks - but it hasn't solved my problem like I thought it would
                          I'm trying to create a curved ramp and cannot solve the complex curve
                          I'm uploading the file - with the desired curve - and the desired ramp
                          I'm thinking there's a drape tool?
                          or??
                          thanks
                          (macos su8)
                          complex curved ramp.skp
                            This is not the plugin for that as the starting form. 😞
                            There are several other approaches... πŸ˜„
                            Look at Fredo's CurviLoft to extrude the profile along the paths
                            Or say my Extrude tool's EEbyRails.
                            Or FredoScale on a simple PushPulled slab?
                            It's an 'extrusion of a bent form' issue, not really a 'bending of an extruded form' issue...
                            [mod=:160kk3hv]EDIT: TIG
                            I see you have posted this in another thread and got similar answers from others.
                            Use their examples...[/mod:160kk3hv]
                            • BurkhardB
                              Burkhard
                              You can simple do it with shape bender.
                              For better results, you' need some better preparations.
                              http://www.ia-plus.de
                                smganeles
                                after using the shape bender plugin to bend a fairly complex shape to a specified curve, some random edges of the rendering were left out and dissapeared
                                otherwise it seemed to work fine (besides making sketchup not respond for a while because i am on a slow and old computer)
                                these were not in the original rendering before the object was bent
                                what could have gone wrong and is there any way to fix this
                                pictures of both before and after the bending are attached
                                before
                                before
                                after
                                after
                                  SketchUp [and OpenGL] have problems creating facets if they are very very tiny.
                                  Your steel-beam has some very small segments to its rounded edges.
                                  You could probably make a much simpler version with far fewer facets.
                                  When ShapeBender [or other tools like FollowMe etc] try to 'extrude' these tiny facets they can fail to form some faces simply because they are now so very tiny.
                                  To overcome this...
                                  Scale the steel/curve/line x100.
                                  Do the ShapeBending etc...
                                  Then Scale down x0.01.
                                  These tiny facets can exist, BUT it's the creating them that is an issue...
                                  This is the known problem and it's fix.
                                  Depending on the facets' "tininess" you can scale x10, x100 or x1000 and then back...
                                    smganeles
                                    thank u
                                    i will try this
                                      draftprint3d
                                      When I am bending a shape, it goes a lot faster when Netflix is playing fullscreen in front. I have no explanation but that is what I observe.
                                        Odd... but it might be that the full screen app in front disable UI functions in SketchUp that would otherwise slow things down.
                                        • Z
                                          Z Donk
                                          Hey, I just loaded this up and am trying to use it for the first time. Got it in my Plugin folder etc.. I'm trying to do exactly what chris did in his first example video and running into a wall: Once i have the simple group selected, as commanded, the "select a single line on the red axis" is the next command. Try as I might, I can't get the selection to take. It highlights blue, It's on the red axis, its a single line. The next command for selecting a curve does not come.... Tried it as a group, as an exploded group, etc. -The line is selected then the grid doesn't show and the commands stop there.. Bear in mind, I'm an intermediate sketchup user but even recreating Chris's simple example I hit a wall.
                                          (Ultimately, I'm trying to bend a 3d geometric rectangle plate along 3 different angles)
                                          • Z
                                            Z Donk
                                            Hi moderator, I found the problem, I didn't know I had to have the entire file in my plugins folder.. Off and running.
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 63
                                            • 64
                                            • 57 / 64
