    Lad musician - Nagoya
    23 Posts 14 Posters 3.4k Views 14 Watching
      Incredible but where do you plug in the vacuum?
      • massimoM Offline
        massimo Moderator
        Thanks guys. πŸ˜„
        @large_black: indeed it was an unbiased engine (TR1). The materials settings are quite simple. The texture required a bit of work instead. I did it by mixing in PS a base texture with some overlayed images for each panel. Then was overlayed an image with the leaks. Here you have the structure of the two materials, the steel one was downloaded on Thea's forum. Just did some minor adjustments. πŸ˜„
        • massimoM Offline
          massimo Moderator
          Sorry Rich not sure to understand. ❓
            There's no electric socket for the vacuum cleaner
            • massimoM Offline
              massimo Moderator
              Oh, right. πŸ˜†
              • allanxA Offline
                allanx
                Wow, I like the color tones of the renders very artistic...well done massimo
                allanx
                Portfolio
                • pbacotP Offline
                  must be an architect
                    jpalm32
                    Very nice. Could you give the size of area?
                    Height & width.
                    • soloS Offline
                      Massimo, what can I say? you suck, give up SU and walk away you are embarrassing yourself!
                      Holy shit that's awesome.
                      • massimoM Offline
                        massimo Moderator
                        Thanks for comments guys. πŸ˜„
                        Height & width.
                        The interior is around 15x5x10 (height) m.
                        • alvisA Offline
                          alvis
                          Massimo, You are a Master of lighting!
                            johnsenior1973
                            You vacuum wood and concrete floors?
                            • massimoM Offline
                              massimo Moderator
                              Thank you Alvis. πŸ˜„
                              • olisheaO Offline
                                olishea
                                wow my kind of space!
                                perfectly executed massimo! textures are just lovely, love the patina. πŸ‘
                                oli
                                • massimoM Offline
                                  massimo Moderator
                                  Lovely space indeed. It's really nice what they did with just a box, three pieces of floor and three skylights. πŸ˜‰
                                  • tademaT Offline
                                    tadema
                                    Wow top notch stuff.
                                    John
                                    • massimoM Offline
                                      massimo Moderator
                                      Thank you John. πŸ˜„
                                      • hellnbakH Offline
                                        hellnbak
                                        Some of the best work I've seen on these forums! Well done, Massimo πŸ‘
                                        • massimoM Offline
                                          massimo Moderator
                                          Thanks for the kind words Steve πŸ˜„ .
