    Lad musician - Nagoya
    23 Posts 14 Posters 4.3k Views 14 Watching
      Piranese revival! β˜€
      • ken28875K Offline
        ken28875
        Wonderful renders, Massimo! πŸ‘ πŸ‘
        Have a great day. β˜€
        _KN
        Follow Your Dreams.
          Incredible but where do you plug in the vacuum?
          • massimoM Offline
            massimo Moderator
            Thanks guys. πŸ˜„
            @large_black: indeed it was an unbiased engine (TR1). The materials settings are quite simple. The texture required a bit of work instead. I did it by mixing in PS a base texture with some overlayed images for each panel. Then was overlayed an image with the leaks. Here you have the structure of the two materials, the steel one was downloaded on Thea's forum. Just did some minor adjustments. πŸ˜„
            • massimoM Offline
              massimo Moderator
              Sorry Rich not sure to understand. ❓
                There's no electric socket for the vacuum cleaner
                • massimoM Offline
                  massimo Moderator
                  Oh, right. πŸ˜†
                  • allanxA Offline
                    allanx
                    Wow, I like the color tones of the renders very artistic...well done massimo
                    allanx
                    Portfolio
                    • pbacotP Offline
                      must be an architect
                        jpalm32
                        Very nice. Could you give the size of area?
                        Height & width.
                        • soloS Offline
                          Massimo, what can I say? you suck, give up SU and walk away you are embarrassing yourself!
                          Holy shit that's awesome.
                          • massimoM Offline
                            massimo Moderator
                            Thanks for comments guys. πŸ˜„
                            Height & width.
                            The interior is around 15x5x10 (height) m.
                            • alvisA Offline
                              alvis
                              Massimo, You are a Master of lighting!
                                johnsenior1973
                                You vacuum wood and concrete floors?
                                • massimoM Offline
                                  massimo Moderator
                                  Thank you Alvis. πŸ˜„
                                  • olisheaO Offline
                                    olishea
                                    wow my kind of space!
                                    perfectly executed massimo! textures are just lovely, love the patina. πŸ‘
                                    oli
                                    • massimoM Offline
                                      massimo Moderator
                                      Lovely space indeed. It's really nice what they did with just a box, three pieces of floor and three skylights. πŸ˜‰
                                      • tademaT Offline
                                        tadema
                                        Wow top notch stuff.
                                        John
                                        • massimoM Offline
                                          massimo Moderator
                                          Thank you John. πŸ˜„
                                          • hellnbakH Offline
                                            hellnbak
                                            Some of the best work I've seen on these forums! Well done, Massimo πŸ‘
