    βŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    Lad musician - Nagoya
    23 Posts 14 Posters 2.6k Views 14 Watching
    • massimoM Offline
      massimo Moderator
      A little store designed by Japanese studio General Design: "it consists of an enclosed concrete box with three skylights in the roof. The interior features three split levels and uses only three materials: concrete, oak and galvanized steel".
      Although it is a small and bare space, the way in which the light penetrates the volume and the internal partition give to it the monumentality of a church in my opinion. πŸ˜„
      Modeled in Sketchup and rendered in Thea.
      For lighting were used sun+physical sky (for the dusk shot, instead, was used a Peter Guthrie's HDRI), two recessed emitting tubes on floor's borders, IES lights for the projectors and a handful of recessed coloured spots with little omnilights inside.
      A slight saturation and contrast correction + diffusion in Magic bullet photolooks in post pro. The images were also resized.
      • Large_BlackL Offline
        Large_Black
        Hi Massimo,
        A few years ago I switched from using v-ray rendering engine to thea render, since that day the high quality of your work has become an example for me to follow, and a target to reach.
        As always, a wonderful job, the lighting is just great, and materials where excellent. The slight noise produced from the unbiased engine (I suppose) gives to the images an incredible photo-realistic touch.
        Some more info on the concrete and steel material settings?
        Veramente bravo!!
        Ciao πŸ˜„
          Piranese revival! β˜€
          • ken28875K Offline
            ken28875
            Wonderful renders, Massimo! πŸ‘ πŸ‘
            Have a great day. β˜€
            _KN
            Follow Your Dreams.
              Incredible but where do you plug in the vacuum?
              • massimoM Offline
                massimo Moderator
                Thanks guys. πŸ˜„
                @large_black: indeed it was an unbiased engine (TR1). The materials settings are quite simple. The texture required a bit of work instead. I did it by mixing in PS a base texture with some overlayed images for each panel. Then was overlayed an image with the leaks. Here you have the structure of the two materials, the steel one was downloaded on Thea's forum. Just did some minor adjustments. πŸ˜„
                • massimoM Offline
                  massimo Moderator
                  Sorry Rich not sure to understand. ❓
                    There's no electric socket for the vacuum cleaner
                    • massimoM Offline
                      massimo Moderator
                      Oh, right. πŸ˜†
                      • allanxA Offline
                        allanx
                        Wow, I like the color tones of the renders very artistic...well done massimo
                        allanx
                        [Portfolio](https://www.coroflot.com/designers/work-stream?id)
                        • pbacotP Offline
                          must be an architect
                            jpalm32
                            Very nice. Could you give the size of area?
                            Height & width.
                            • soloS Offline
                              Massimo, what can I say? you suck, give up SU and walk away you are embarrassing yourself!
                              Holy shit that's awesome.
                              • massimoM Offline
                                massimo Moderator
                                Thanks for comments guys. πŸ˜„
                                Height & width.
                                The interior is around 15x5x10 (height) m.
                                • alvisA Offline
                                  alvis
                                  Massimo, You are a Master of lighting!
                                    johnsenior1973
                                    You vacuum wood and concrete floors?
                                    • massimoM Offline
                                      massimo Moderator
                                      Thank you Alvis. πŸ˜„
                                      • olisheaO Offline
                                        olishea
                                        wow my kind of space!
                                        perfectly executed massimo! textures are just lovely, love the patina. πŸ‘
                                        oli
                                        • massimoM Offline
                                          massimo Moderator
                                          Lovely space indeed. It's really nice what they did with just a box, three pieces of floor and three skylights. πŸ˜‰
                                          • tademaT Offline
                                            tadema
                                            Wow top notch stuff.
                                            John
