    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      menes
      Thanks TAK2HATA
      You put me in the right way 😍 thank you!
      My values were different
      Main Detail
      type : leaf top jitter :8
      Density: 60.000 width jitter: 19
      Max n. :60.000 stiffness jitter : 50
      length :1 valid distance: 0,000
      rootwidth : 0,200 direction (x): 0,000
      stiffness : 1 direction (y): 0,000
      divide :2 direction (z): 1
      force (x):0
      force (y):0,000
      force (z):-30
      now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
      • thkian92T Offline
        thkian92
        Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
          mwm5053
          Great plugin 👍 I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
            tak2hata
            Hi,Walt.
            I will test it on Mac.
            Please wait.
            Thanks.
            by TAK2HATA
              mwm5053
              2011 iMac
              V2 Twilight
                tak2hata
                Hi,Walt.
                I tested on mac.
                Screen shots here.
                files in plugin folder
                work fine on mac.
                I think the problem is folder.
                The webdialog lost the sight of "JS" folder or "CSS" folder.
                But I think no problem about the non-alphabetical character file names on mac.
                So please tell me your plugin folder.
                Thanks.
                by TAK2HATA
                  mwm5053
                  Path can be seen at bottom of screen shot.
                  2011 iMac
                  V2 Twilight
                    tak2hata
                    I think there is no problem.....
                    The problem becomes the mystery.
                    I will create test code for you.
                    Please wait.
                    by TAK2HATA
                    • Z Offline
                      Zacchia
                      Hi tak2hata
                      Many thanks for your wonderful plugin! See attached an idea, hope you can understand 😒 It is just an idea.
                        tak2hata
                        Hi,Walt.
                        I create the test ruby for you.
                        test ruby
                        It shows the folders for fur and Test Slider on Webdialog.
                        Select from menu bar.
                        Plugins -> Fur Test For Walt
                        It will show like this.
                        Show like this
                        Hi,Zacchia.
                        I understand your idea.
                        But It will add new many properties.
                        They take long time.
                        Wait for Fur v3.0.
                        Now I must sleep soon for tomorrow.
                        Thanks.
                        by TAK2HATA
                          mwm5053
                          Here we go still no slider.
                          2011 iMac
                          V2 Twilight
                          • thkian92T Offline
                            thkian92
                              No existing randomize size of elements, Components? 😲
                                tak2hata
                                Ummm...
                                It is difficult.
                                I consider well.
                                Please wait.
                                Hi,Pilou.
                                In Fur webdialog,
                                TopJitter(%) will randomize the size of placing component.
                                Or Use Crowd Dialog.
                                Hi,thkian92.
                                I tested on Sketchup13.It works well.
                                I have some questions.
                                Was the error mesasge show on starting sketchup?
                                Does fur Toolbar exits on your sketchup.
                                Did you install fur correctly?
                                Sketchup V8,too?
                                Thanks.
                                by TAK2HATA
                                  Tested on V7 😉
                                  Very cool! 😎
                                  Does exist something for avoid "collisions" of volumes?
                                  And seems Preview positions of the crowd don't gives the good result?
                                  Number is good but not the position! 😲
                                  Does it possible in the Crowd Menu to have something who gives random size
                                  but not a rotation ?
                                  What the "Stand Up" (Yes / No) is supposed to do ?
                                    tak2hata
                                    Hi,Pilou.
                                    This tool is fur tool.
                                    To interference solids will make too many raytest checks.
                                    So it will be too slow to use.
                                    The purpos of preview is chechking the styles.
                                    The show full preview will too slowly to use fine.
                                    I limit the number of fur in previwe to make it fast.
                                    So preview position is not same to generating.
                                    Sorry for my poor technology.
                                    Hi,Walt.
                                    This is last test.
                                    Please open Ruby console in sketchup.
                                    (menu bar -> windows -> ruby console)
                                    And copy and paste this line.
                                    wdlg=UI;;WebDialog.new( "Fur TEST", true, "T2H_FUR_DIALOG", 300, 680, 150, 150, true);wdlg.set_url("http://jqueryui.com/slider/");wdlg.show_modal
                                    like this picture.
                                    2013.06.30screenshot1
                                    And press enter key to run the script.
                                    Webdialog will be shown.
                                    The right state of display is here.
                                    2013.06.30screenshot2
                                    I am not able to solve this problem when there is no slider.
                                    If the slider is shown,I think the prbolem caused to "CSS" folder.
                                    Thanks.
                                    by TAK2HATA
                                      Thanks for the infos! ☀
                                      No problem! It's yet a truelly very cool plugin! 👍
                                        mwm5053
                                        Thanks or all the help tak2hata this what I get with a slider.
                                        2011 iMac
                                        V2 Twilight
                                        • thkian92T Offline
                                          thkian92
                                          Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
                                          How did you install version 2.0.6 in order to get it to work?
                                            DavorP
                                            Hi Takuji,
                                            Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
                                            There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
                                            • 32
                                            • 33
                                            • 2 / 33
