    Safe place to store user-defined parameters
    114 Posts 9 Posters 24.4k Views 9 Watching
      BUT...
      No one has still answered my question... 😕
      What is wrong with using the container folder for the ENV for the OS's user's 'Temp' folder?
      That is easily found for either OS and is writable, like the Temp folder itself...
      Once you have the path to the user's 'Temp' folder we can then make an app-specific subfolder to hold our temporary files...
      AND from File.dirname(Temp) we can get the container-location into which we can make an app-specific subfolder to hold our 'permanent' files...
      I do it without problems on all OS's - the rest of you seem to obsessed with finding 'the exact right folder that we must use', when in truth there are several valid possibilities, and my earlier posts cover much of this too... KISS ?
        driven
        @tig said:
        BUT...
        No one has still answered my question... :?
        I thought Steve had answered when he gave his brief lesson on why temporary directories exist?
        Your 'trick' of hiding your 'cookie' from my computer maintenance routines works a treat for now, but may not after the next release of Safari [in beta] or Mavericks [dev release available].
        The writings on the wall, Apple doesn't like Plugins or Cookies and if you recall, they weren't to fond of Flash.
        Apples allows and even encourages 'Extensions', but they are meant to fully contained within their Parents 'approved' structures that include the ENV[TMPDIR] and or /tmp depending on what your doing. There are also approved external paths for any launch daemon's, browser cookies or cache's that the Parent app and or it's extensions may require. All these additional paths are meant to be in an info.plist so they can be easily removed at any point in time.
        Is there a reason to think your cookie [for example] won't work from File.join(File.dirname(__FILE__), "/Data/.Cookie_Jar/.My_cookie.dat")?
        I know the path works, is the problem checking it's the contents from your own Plugins sub-directory?
        From a general user perspective that is hidden >> inside a hidden folder >> inside your NameSpaced Plugins Folder >> inside the Parent apps 'Plugins' >> inside the normally hidden ENV[HOME]/Library/....
        Is there a need to look for anything if your plugin KNOWs where it is.
        When your User decides to remove it, the Parent.app or better still, your Plugin only needs to trash the one folder and there are no lurking remains hidden, inappropriately scattered around the system/usr folders.
          slbaumgartner
          @tig said:
          BUT...
          One last try and then I will shut up. Your suggestion is what we used to call a "bad hack". It is a hack because it uses an unofficial trick to work around an issue. It is bad because it is only works today due to oversights and mistakes on the part of the OS developers. The fact that the parent directories of temp locations are writable is an oversight, not by intent. They simply never considered that programmers would do what you suggest, so they didn't bother to lock the gate or sweep the floor. They could decide to secure their house at any time, at which point this technique will fail. Do you really want your plugin users to plague you with support calls when Windows 9 or Mac OS X 10.9 changes the rules? Why not look for an OS-endorsed and stable technique rather than take this risk?
          Steve
            The parent-folder of Windows 'Temp' folder - 'Local' - IS clearly intended to be written to...
            Many applications already make their own subfolders in it to store data more permanently that the Temp folder itself would allow...
            If the MAC-guys don't want you writing to the user's 'T' folder's parent-folder, then they have never said so, and to make it non-writable would be straightforward for them...
            I don't consider my Windows suggestion a 'hack' at all... the MAC side is less documented, but to date has always worked too...
            @driven
            The Plugins directory is NOT always writable by the user - this is always the possibility on a PC and before v2013 so it was on a MAC too.
            So we can't confidently write any of our folder/files there - in fact we are now full circle because Fredo started this thread trying to find where to save data outside of this potentially limited tree...
            Your ENV[HOME] is MAC only, BUT I agree it could be used for that OS by reconstructing the other tree elements from /Library/ - but then who can be sure they'll also remain 'constant' too ?
            The equivalent for the PC is actually ENV["HOMEPATH"], but then returns say ' C:/Users/TIG', from which we'd need to construct the upwards tree towards /AppData/Local/XXX etc... This is more easily got working downwards from TEMP or TMP and makes no assumptions about paths ! It does expect Local and Temp to be writable - which is their purpose...
            There are many places we cab write folders and files, knowing that the users will assuredly have permission - like their documents folder, their desktop, their 'temp' folders etc...
            With the likes of Fredo's folder/files he wants it somewhere discreet and unnoticed...
            The 'cookie.dat' file you refer to was originally written to an app specific subfolder inside 'Temp' or 'T' but the potential for it getting purged led me to move it into the container 'parent-folder' - on a PC that is expected to be written to...
            • fredo6F
              @TIG,
              Your suggestion is interesting on Mac.
              Actually, my problem is not so much to find a place where to write freely, but also a place:
              • whose path is stable across time
              • which is not erased without the user deciding
              On Mac, with the convoluted name of the ENV["TMPDIR"] path, it remains to check it its parent remains stable through time.
                driven
                VERSION AGNOSTIC MAC PATH... vain attempt...v2013
                any_mac_or_SUv_path =
                 File.dirname(File.expand_path(Sketchup.find_support_file("Shortcuts.plist"))) << ('/.MY_NAMESPACE/.my_hidden_file.*')
                Returns:
                ` */Users/johns_iMac/Library/Application Support/Google SketchUp 6/SketchUp/.MY_NAMESPACE/.my_hidden_file.
                [/Users/johns_iMac/Library/Application Support/Google SketchUp 7/SketchUp/.MY_NAMESPACE/.my_hidden_file.*
                /Users/johns_iMac/Library/Application Support/Google SketchUp 8/SketchUp/.MY_NAMESPACE/.my_hidden_file.*
                /Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp/.MY_NAMESPACE/.my_hidden_file.***`
                All mac users can write shortcuts... Shortcuts.plist may be dynamic but these are common fresh standard instal at that same path, so could be used as well or instead... "Autosave" "OldColors"
                  @tig said:
                  The equivalent for the PC is actually ENV["HOMEPATH"], but then returns say 'C:/Users/TIG', from which we'd need to construct the upwards tree towards /AppData/Local/XXX etc...
                  Problem occur if the user has non-ASCII names - then it will fail.
                    Non-ASCII characters in file names/paths cause issues with some of Ruby's File commands [in the flavor of Ruby shipped with PC SketchUp].
                    So you will get a false ' false' result if you test for its existence, even when the folder actually exists:
                    So if you test for its existence, and then hope to make it if it doesn't exists, e.g.:
                    Dir.mkdir('C:/Users/Usersname/AppData/Local/XXXé') unless File.exist?('C:/Users/Usersname/AppData/Local/XXXé')
                    you will crash and burn because of the false false that results from the é !
                    The way to do this safely is...
                    begin Dir.mkdir('C:/Users/Usersname/AppData/Local/XXXé') rescue end
                    Which will make the folder, BUT if it does exists there's a silent error because it exists already...
                    Either way you'll get the specified folder !
                    This is not ideal but ca trap for some false false File test issues...
                      But that doesn't help anything. You cannot write to that folder in any way.
                      • danielbowringD
                        danielbowring
                        @tig said:
                        BUT...
                        The temp directory is easy to get ( require 'tmpdir'; Dir.tmpdir) but only useful for temporary files.
                        If you're writing something to the temp directory with the intention of reading it later, you're doing it wrong™. The temp directory is for files that have no consequence if they are removed at a later date. The temp directory is for writing, and reading only when you've been explicitly told to.
                        The "correct" place for persistent data for an application that is not part of the installation is the appdata location. These directories are separate for each user and guaranteed to be readable/writable for the associated user. This is normally were things like plugins/extensions would exist, also.
                        A good example of this (if you have it installed) is Sublime Text. (On windows) it is installed to %PROGRAMFILES%/Sublime Text, which contains all required binaries and application defaults. Then in %LOCALAPPDATA%/Sublime Text/ (or %APPDATA%/Sublime Text 2/ for st2 user level information is available, including plugins, settings, key configurations, ...
                        Driven has posted what appears to be the MAC equivalent of LOCALAPPDATA || APPDATA.
                        So, the search order for a path to write to should be: (keeping in mind I'm no MAC expert)
                        %LOCALAPPDATA% (win)
                        %APPDATA%      (win)
                        ~/Library/???/Sketchup/  [or similar] (MAC) ["~" -> "/Users/<username>/"]
                        Sub-directory in SketchUp directory [plugin-data or similar] (if writable)
                        temp directory (last resort)
                          But as I mentioned - Ruby 1.8 cannot handle non-ASCII characters. Usernames might include Unicode characters and then all file operations on the user directory will simply fail.
                          • fredo6F
                            I will release the new versions of LibFredo6
                            • with ENV["LOCALAPPDATA"] on Windows
                            • with TIG's method on Mac, that is the parent directory of the ENV["TMPDIR"] folder. I think using ENV["HOME"] with some hidden subfolder would have been considered too intrusive.
                            These will be root folders into which I will create the LibFredo6 subfolders for persisting data.
                            I think in both cases these folder won't contain non-ascii characters, as they are defined and created by the system itself.
                              On windows the Local path (ENV["LOCALAPPDATA"]) could return as say
                              f=ENV["LOCALAPPDATA"]) 'C:\Users\TIGé\AppData\Local'
                              which will return ' false' in a File.exist?(f) test when it actually exists, just because the user-name contains an accented character!
                              So use my 'safe' way [a few post ago] to make the folder, even if it exists already!
                              • danielbowringD
                                danielbowring
                                All the more reason to update the ruby installation. The provided order would still "work" if you checked each of the directories existed (because the check would "simply fail"), but it's certainly no supplement for the actual feature.
                                It seems to be reoccurring that the SketchUp ruby API will gives you "clipped wings". I'm excited to see where it can go, but also impatient with its shortcomings (even though this one isn't really SU fault).
                                Side-note: No unicode support seems strange for something coming out of japan 😛
                                • danielbowringD
                                  danielbowring
                                  ENV["LOCALAPPDATA"] may contain non-ascii characters, as it contains the current users username. Also, you should use ENV["LOCALAPPDATA"] || ENV["APPDATA"] so you can support XP at no extra effort 😄
                                  Bonus:
                                    Just to test things I created a user account "tæst" under Windows7. And ran some tests in the Ruby Console:
                                    ENV['HOMEPATH']
                                    \Users\t‘st
                                    ENV["LOCALAPPDATA"]
                                    C;\Users\t‘st\AppData\Local
                                    ENV["APPDATA"]
                                    C;\Users\t‘st\AppData\Roaming
                                    file = File.join( ENV['LOCALAPPDATA'], 'FooBar.txt' )
                                    C;\Users\t‘st\AppData\Local/FooBar.txt
                                    File.open( tempfile, 'wb' ) { |file| file.puts 'Hello world' }
                                    Error; #<Errno;;ENOENT; (eval);0;in `initialize'; No such file or directory - C;\Users\t‘st\AppData\Local/FooBar.txt>
                                    (eval)
                                    (eval);0;in `open'
                                    (eval);0
                                    ENV['TEMP']
                                    C;\Users\TST~1\AppData\Local\Temp
                                    tempfile = File.join( ENV['TEMP'], 'FooBar.txt' )
                                    C;\Users\TST~1\AppData\Local\Temp/FooBar.txt
                                    nil
                                    Interesting observations:
                                    Most ENV has some strange character replacements. Is this a Ruby thing?
                                    ENV['TEMP'] returned a path in the format of the old DOS 8.3 format. And this could be written to.
                                    ENV.each { |k,v| puts "#{k}\t#{v}" }
                                    ALLUSERSPROFILE	C;\ProgramData
                                    APPDATA	C;\Users\t‘st\AppData\Roaming
                                    CommonProgramFiles	C;\Program Files (x86)\Common Files
                                    CommonProgramFiles(x86)	C;\Program Files (x86)\Common Files
                                    CommonProgramW6432	C;\Program Files\Common Files
                                    COMPUTERNAME	ARC-CU-10-09
                                    ComSpec	C;\Windows\system32\cmd.exe
                                    FP_NO_HOST_CHECK	NO
                                    HOMEDRIVE	C;
                                    HOMEPATH	\Users\t‘st
                                    LOCALAPPDATA	C;\Users\t‘st\AppData\Local
                                    LOGONSERVER	\\ARC-CU-10-09
                                    NUMBER_OF_PROCESSORS	8
                                    OS	Windows_NT
                                    PATHEXT	.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
                                    PROCESSOR_ARCHITECTURE	x86
                                    PROCESSOR_ARCHITEW6432	AMD64
                                    PROCESSOR_IDENTIFIER	Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
                                    PROCESSOR_LEVEL	6
                                    PROCESSOR_REVISION	1a05
                                    ProgramData	C;\ProgramData
                                    PSModulePath	C;\Windows\system32\WindowsPowerShell\v1.0\Modules\
                                    PUBLIC	C;\Users\Public
                                    SESSIONNAME	Console
                                    SystemDrive	C;
                                    SystemRoot	C;\Windows
                                    TEMP	C;\Users\TST~1\AppData\Local\Temp
                                    TMP	C;\Users\TST~1\AppData\Local\Temp
                                    ULTRAMON_LANGDIR	C;\Program Files\UltraMon\Resources\en
                                    USERDOMAIN	arc-cu-10-09
                                    USERNAME	t‘st
                                    USERPROFILE	C;\Users\t‘st
                                    windir	C;\Windows
                                    The TEMP path seem to be the only one using this format.
                                    So, question is, is it possible to monkey-patch this so one can extract the user directory in DOS8.3 format and use that to replace the mangled paths of the other variables?
                                    And what does it return under other Windows versions? (Win8, Vista, XP)
                                    What about chineese/japanese types or characters - does the same thing apply?
                                      What folders does this yield on XP? Under Win7 it's both in the user directory.
                                      • fredo6F
                                        I will use the parent of ENV["TMPDIR"] only on Mac. Apparently, this directory has a long cryptic name, which I assume will only contain valid characters.
                                        On Windows, this is more of a problem is ENV["LOCALAPPDATA"] cannot be manipulated from Ruby dues to non Ascii characters. It's not only for creating subfolders there, but also to manage filepaths of files to be created and updated.
                                        The best I can do is to check if the username contains non-ascii characters and then simplify the name to Ascii, and create a folder with that simplified name in C:\users. This really becomes convoluted!!
                                        There must be a trick however, because when Sketchup installs, it sets the default file locations pointing to the "MyDocuments" folder, whose name also contains the username (something like C:\Userfiles\<username>\Documents\). But maybe these locations are not used from Ruby.
                                          Creating random folder directly in the location where user folders are? I don't think people would too happy about this. I'd like to explore if we can get the 8.3 filename for the appdata folder.
                                          Correct - SketchUp itself has no problems with Unicode paths. It's the Ruby 1.8 core.
                                          • fredo6F
                                            Actually as I use both, LOCALAPPDATA first and then APPDATA.
                                            For info, on WindowsXP, ENV["APPDATA"] is defined and uses the old Windows user directory in the form of C:\Documents and Settings\<username>\Application Data.
                                            • 5 / 6
