    Safe place to store user-defined parameters
    114 Posts 9 Posters 24.4k Views 9 Watching
      @fredo6 said:
      1. The temp directory has the small drawback that it can be erased. I use it already for transient files (like .html) and all log files. But here I am talking more of script parameters that are set up by the users to remain persistent (like which icon are visible in toolbars).
      If it's persistent files then the temp folder would not be fit. As TIG mention, under Windows the appdata folder would be appropriate. Out of sight from users. Not quite sure about OSX...
      • danielbowringD
        danielbowring
        Maybe something like:
        def appdata_dir()
            dir = ENV['LOCALAPPDATA'] || ENV['APPDATA'] || '~/Library'
            return dir if File.directory?(dir)
            return Sketchup.find_support_file('plugins')
        Just remember make a (unique) directory for yourself.
        def author_appdata_dir(author_name, make=true)
            dir = File.join(appdata_dir(), author_name)
            Dir.mkdir(dir) if make && !File.directory?(dir)
            return dir
        • Dan RathbunD
          Dan Rathbun
          @fredo6 said:
          1) On Windows, most commercial applications precisely create a folder in the directory pointed to by ENV["HOME"].
          **NOT TRUE
          Why? Because %(#BF00FF)[%HOME%] is NOT defined under Windows.**
          I have installed so many versions of MS Office, on so many machines I've lost count.
          Never have I seen MSO create directories in the user's root dir.
          Always down in the AppData path, or in the Common Files path.
          Just because some software does it incorrectly (such as SketchUp,) does not mean WE should.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            I like DanielBowring's ideas EXCEPT I'd rather the paths be set as constants in some suitable namespace, so they can be mixed into author namespaces.
            Something like:
            SuPath::APPDATA SuPath::TEMP
            If the Trimble TEam were to add them into the API code, then likely the constants would be defined within :
            Sketchup::Path submodule nesting.
            SO like:
            Sketchup::Path::APPDATA Sketchup::Path::TEMP..., etc.
            Then we could mixin the constan ts into our local submodules if we wished to...
            module Author
              module SomePlugin
                include(Sketchup;;Path)
                # all Sketchup;;Path module's constants are now accessible
                @@dir = File.join( APPDATA, "Author_SomePlugin")
                unless File.directory?( @@dir )
                  File.mkdir( @@dir )
              end # module SomePlugin
            end # module Author
            πŸ’­
            • fredo6F
              @dan rathbun said:
              **NOT TRUE
              Correct. I have one PC where it is not defined, and one where it is defined. So it is not reliable.
              Likewise, I have one PC where Microsoft folders are both in Document and Local, and one where it is only in Local. Camtasia seems to use both locations (AppData is used for autosave)
              It seems that ENV["LOCALAPPDATA"] is always defined and this directory would be OK.
              However, I don't know what it corresponds to on OSX.
              More generally, Sketchup should make provision of a data folder where it is advised that scripts put their persistent data, so that
              • it can be safely stored without roblem of access rights
              • it is user related.
              I observe that Trimble is now paying more attention to scripts and that may be a suggestion for a next maintenance release or version.
              This thread is just about discussing how script writers should be collectively organized.
              • Dan RathbunD
                Dan Rathbun
                @tig said:
                On a PC there will be lots of app-specific folders made in
                C:/users/username/appdata/local
                FYI
                SketchUp saves the user's " %(#8040BF)[session.dat]" file to the %APPDATA% path (not the %LOCALAPPDATA% path.)
                ie:
                XP(Win 5.1😞 C:\Documents and Settings\*<username>*\Application Data\SketchUp\SketchUp 2013\SketchUp
                Win 6+: C:\Users\*<username>*\AppData\Roaming\SketchUp\SketchUp 2013\SketchUp
                πŸ’­
                BUT... The main reason that these paths have not yet been exposed in the SketchUp Ruby API.. is that on Windows if the username contains unicode characters... Ruby 1.8.x cannot handle them with the standard String class.
                This is why we had hoped (in vain, it seems,) that this next SU version would have Ruby 1.9.x or 2.0.x
                • Dan RathbunD
                  Dan Rathbun
                  Again, sorry.. not exactly correct.
                  %(#BF00BF)[%LOCALAPPDATA%] is defined only on Windows version 6 and higher
                  (which means not on XP which is version 5.1)
                  πŸ˜‰
                  So in Ruby (on Windows)
                  unless LOCALAPPDATA = ENV["LOCALAPPDATA"]
                    # evals false because it's nil, we must be on XP, so;
                    LOCALAPPDATA = File.join( ENV["USERPROFILE"], "/Local Settings/Application Data" )
                  # Otherwise on Windows ver 6+, and %LOCALAPPDATA% is defined, as;
                  # "C;\Users\<username>\AppData\Local"
                  ADD: It is smart to convert the backslashes to Ruby forward slashes with gsub("\\","/")
                  πŸ’­
                    @aerilius said:
                    What speaks against using an iterative search?
                    > # Find an existing and writable directory where to store user data.
                    > dir = [
                    >   ENV["LOCALAPPDATA"],                    # Windows ver. 6+
                    >   ENV["APPDATA"],                         # Windows
                    >   File.join(ENV["HOME"].to_s, ".local", "share"), # Free desktop standard
                    >   File.join(ENV["USER"].to_s, "Library", "Application Support"), # OS X
                    >   "."                                     # Fallback; exists always, where as ENVs may not.
                    > ].compact.map{ |path| File.expand_path(path) } # expands links and path separators
                    >  .find{ |path| File.exists?(path) && File.writable?(path) }
                    > DATA_DIR = File.join(dir, "MyPlugin")
                    I already posted something similar [but with a bigger choice of fall backs] for deciding on your 'TEMP' folder... AND on PC or MAC you can write subfolders/files one folder 'up the tree' from the TEMP folder, so you can put any custom-subfolder there...
                    I've never had a failure [yet πŸ˜‰ ].
                    Many programs have freely writable folders in these locations...
                    On a PC it's the 'C:/Users/Username/AppData/Local/' folder [which in turn contains your 'Temp' folder], on a MAC is a system generated 'seemingly-gobbledygook-folder-name-tree' [which in turn contains your 'T'[emp] folder]...
                    Here is some explanation of a PC's three 'User Folders'...
                    Roaming is the folder that would be 'synchronized' with a server if you had logged into a domain with a 'roaming profile' (enabling you to log into any computer in a domain and access your favorites, documents etc).
                    For example: Firefox stores its information here, so you could even have the same bookmarks between computers with a roaming profile.
                    Local is the folder that is specific to that computer.
                    Any information here would NOT be synchronized with a server.
                    This folder is equivalent in XP to C:\Documents and Settings\User\Local Settings\Application Data.
                    LocalLow is effectively the same as the Local folder... but it has a lower 'integrity level'.
                    For example: when 'protected mode' is 'on' IE8 can only write to the LocalLow folder.
                    • fredo6F
                      Anyone has an idea if ENV["LOCALAPPDATA"] is defined on Mac?
                        driven
                        %(#FF0000)[**# SU returns =>
                        ENV["LOCALAPPDATA"]
                        nil**]
                        • fredo6F
                          ENV["LOCALAPPDATA"]
                          nil**]
                          hanks
                          And what about ENV["APPDATA"] ?
                            driven
                            ENV["APPDATA"]
                            nil**]
                             ENV
                            {"PATH"=>"/usr/bin;/bin;/usr/sbin;/sbin",
                             "TMPDIR"=>"/var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/",
                             "SHELL"=>"/bin/bash", "HOME"=>"/Users/johns_iMac",
                             "USER"=>"johns_iMac",
                             "LOGNAME"=>"johns_iMac",
                             "SSH_AUTH_SOCK"=>"/tmp/launch-0β€’β€’β€’β€’β€’/Listeners",
                             "Apple_Ubiquity_Message"=>"/tmp/launch-RCcmJV/Apple_Ubiquity_Message", "Apple_PubSub_Socket_Render"=>"/tmp/launch-BeHprC/Render",
                             "DISPLAY"=>"/tmp/launch-HUlKie/org.macosforge.xquartz;0",
                             "IG_ROOT"=>"/Applications/SketchUp 2013/SketchUp.app/Contents/Resources",
                             "SHLVL"=>"14",
                             "PWD"=>"/",
                             "_"=>"/usr/bin/open",
                             "__CF_USER_TEXT_ENCODING"=>"0x1F5;0x08000100;0\n",
                             "COMMAND_MODE"=>"unix2003"}
                            • fredo6F
                              Thanks John.
                              I m afraid I'll store default parameters in /tmp, which seems to be only safe place defined on Mac (TMPDIR does not look very stable across OSX session.
                                driven
                                TMPDIR is only cleared if coded to do so, /tmp is for temporary files and is purged on reboot....
                                SketchUp use /tmp for active tool log file , and TMPDIR for crash-logs [without a cap]
                                  Aerilius
                                  That is a temporary folder. We have to ask John how long temporary files stay there, but usually one cannot assume that temporary files stay until after a reboot. It is only exceptional for Windows that temporary files stay for "long" (I once found years old files).
                                    driven
                                    A lot of mac users never reboot, so for them they are semi-permanent, for the life of a software release or until SU 'bug-splatts'.
                                    however, most the files in there, overwrite themselves regularly... etc. they are meant to be momentary.
                                    Unfortunately for me, I learnt this the hard way by loosing my entire dev folder that I had in there at one point.
                                    now I use it for the images/files needed only during a session, even then I write backups to my 'Plugins' folder, which I only overwrite on next use of the tool.
                                    access, FIFO is meant to be faster, which is good for temporary logging, and image compositing.
                                      slbaumgartner
                                      Guys,
                                      Please forgive an old fart for a brief history lesson.
                                      The tmp, temp, and similar directories/folders came into being as a means for a program to create a working file during a run without concern for the physical location of the file. The intent was that the file would no longer be needed after the program exits and could be cleaned up by the OS at any time after the program closes. The fact that an OS may have a lazy cleanup policy that lets such files hang around for a long time is not a good excuse for ignoring the basic idea that these files are meant to be temporary! These are not reliable places to store persistent parameters. The policy could change at any time!
                                      Steve
                                      • fredo6F
                                        @slbaumgartner said:
                                        Guys,
                                        Steve
                                        I understand.
                                        But where can the persistent parameters be saved on Mac?
                                        What are other applications doing?
                                        Fred
                                          driven
                                          Apple applications must be self contained to meet the 'Approved' status that SU is attempting to gain.
                                          If they don't 90% of mac users will get a warning that 'SU' is 'unapproved' and 'potentially harmful', this puts a LOT of people off.
                                          That's why everything is moving back into SU's App Folder in the User space it's also why they added Extension Manager.
                                          As far as Apple are concerned Users should only ever need to access an app from within the app and should not be required to ever need to add anything externally.
                                          For it's Users. SU provides the all the paths you need to supply an SU Plugin to run on a mac, use them.
                                          If Users have move stuff around, that's their problem and SU and Apple are happy.
                                          If your developing on a mac, you can change permissions to get around some of the sandboxing and you can then compile and 'package' helpers so Uses can benefit from your workarounds, if your on a PC it's a nightmare to take alternate routes.
                                          If you keep all your files in your Plugins Directory and the SU at supplied external paths, I can't see a problem.
                                          SU and Apple are happy, you can be happy too.
                                            Aerilius
                                            That's very easy, if the OS vendor finger-points at the one who plays bad, then everyone has to try to play nice.
                                            User's personal data (settings on one side and user data (works, templates, user-managed plugins on the other side) belong to the user level also on other operating systems (of which Windows is only one special example, I even do not use Windows). Then there would not be permission problems. It has often enough been pointed out that plugins in the Windows version SketchUp are in the wrong place.
                                            The permission problem story on Windows has its origin that it was designed as a single user OS at a time when also security models where basic or non-existing. Microsoft decided to keep compatibility instead of "deprecating" older applications (or applications that don't follow the new rules), which lead to this inconsistency.
                                            • 1 / 6
