    [Plugin] [Re]Scene v1.0.7
    39 Posts 10 Posters 22.3k Views 10 Watching
    • renderizaR
      renderiza
      @cadfather said:
      ..you forgot to put cadfather? 😆 but you did all the work... if you only knew how much time you saved me! 👍 😄
      Yes I forgot but its all fixed now. 😳 😆
      Anyways, like I said before ideas are an important part of plugins development and so it brings me joy to say this was a collaboration instead of saying it was all done by me.
      Cheers! 👍
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • renderizaR
        renderiza
        New Update Released v1.0.4
        This update is all about making sure [Re]Scene complies with all the requirements of SketchUp 2013 is Extension Warehouse. The plugin was submitted and is awaiting revision to ensure everything is running well. If you don't like to wait until then please download in now from SketchUcation.
        Cheers!
        • renderizaR
          renderiza
          New Update Released v1.0.5
          New Features:
          • [Re]name - Allows you to rename multiple scenes at the same time.
          • [Re]order - Will reorganize all scenes by alphabetical order.
          New Web-Dialog:
          http://s15.postimg.org/ycqlsebaj/dlg_1.jpg
          Hope you enjoy this new features!
          • renderizaR
            renderiza
            Detected a BUG that will freeze plugin if you push [Re]Name or [Re]Order button and there is no pages(scenes) on you SketchUp.
            Please don't download v1.0.5 because I will fix this bug very quickly and post v1.0.6
            Cheers!
            • renderizaR
              renderiza
              New Update Released v1.0.6
              Now if you click [Re]Name or [Re]Order Buttons without any scenes on you model it will not freeze the plugin.
              Cheers!
                JuanV.Soler
                Hi Renderiza , it seems it does not works well in version 2.013 , do not close neither changes styles .
                No mores sounds ? 😞
                keep it up , I think it is a great plugin .
                • renderizaR
                  renderiza
                  I will fix this problem as soon as possible!
                  Thanks for reporting bug!
                  • renderizaR
                    renderiza
                    I think is fixed now, try downloading it again.
                    About the sounds I guess I will integrate them again soon but with an option to turn them off. 👍
                      JuanV.Soler
                      Ok, it does work now 👍
                      • renderizaR
                        renderiza
                        Does this plugin work on Mac?
                        I don't have one so I can't make tests.
                        Thanks,
                        Renderiza
                        • renderizaR
                          renderiza
                          On Extension Warehouse I read a comment saying this plugins doesn't work on MAC and I recently made few changes on code to see if this can be solved. I personally don't own a MAC so I can't test it myself and will be very grateful if someone can let me know if it works.
                          Thanks,
                          Renderiza
                          • G
                            glro
                            I was looking for a plugin to NOT record the camera position in all scenes
                            too little to match
                            • onzkiO
                              onzki
                              Amazing amazing plugin, thanks so much! I like how this plugin quickly rename /renumber all my scenes in sequence. By the way, is there a way to rename selected scenes only, in bulk? For example, I select scenes 1-10 and rename them to something else, like "Ground floor scenes_xx"? Thanks!
                              [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                db11
                                Four years and a bit later, yes it works on a Mac... but for some reason the web dialog load time is insanely long. At first I thought it wasn't working at all, as the dialog remained blank. I did some other stuff and came back to SU and it was populated. From that point on everything seemed to work fine.
                                I just did a test and it took almost 3 minutes for the dialog to load, so something's not right.
                                The plugin itself is great and a major time saver otherwise.
                                • renderizaR
                                  renderiza
                                  It's been a long time since I've updated any of my plugins, but I want to make a comeback so I am currently working on some of them which I hope to make available in the near future.
                                  At the moment I am creating a framework to make my plugin's GUI be drawn directly on SketchUp's viewport so I can avoid using web-dialogs altogether. This is taking little longer than expected but ones its ready then updating my plugins should be faster.
                                  Thanks for the feedback and I'll start working on this plugin sooner than later. 👍
                                  • onzkiO
                                    onzki
                                    Hi, has anyone tried this in 2026? I’ve noticed that the [Re]Name button has a glitch. On the first click, it produces strange 3- or 4-digit scene names like Scene 625, Scene 626, Scene 627. When you click the [Re]Name button again, the second time it corrects itself and gives the expected sequence, such as Scene 1, Scene 2, Scene 3, and so on.
                                    • 2 / 2
