    [Plugin] [Re]Scene v1.0.7
    39 Posts 10 Posters 22.3k Views 10 Watching
    • renderizaR
      renderiza
      New Update Released v1.0.6
      Now if you click [Re]Name or [Re]Order Buttons without any scenes on you model it will not freeze the plugin.
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        JuanV.Soler
        Hi Renderiza , it seems it does not works well in version 2.013 , do not close neither changes styles .
        No mores sounds ? 😞
        keep it up , I think it is a great plugin .
        • renderizaR
          renderiza
          I will fix this problem as soon as possible!
          Thanks for reporting bug!
          • renderizaR
            renderiza
            I think is fixed now, try downloading it again.
            About the sounds I guess I will integrate them again soon but with an option to turn them off. 👍
              JuanV.Soler
              Ok, it does work now 👍
              • renderizaR
                renderiza
                Does this plugin work on Mac?
                I don't have one so I can't make tests.
                Thanks,
                Renderiza
                • renderizaR
                  renderiza
                  On Extension Warehouse I read a comment saying this plugins doesn't work on MAC and I recently made few changes on code to see if this can be solved. I personally don't own a MAC so I can't test it myself and will be very grateful if someone can let me know if it works.
                  Thanks,
                  Renderiza
                  • G
                    glro
                    I was looking for a plugin to NOT record the camera position in all scenes
                    too little to match
                    • onzkiO
                      onzki
                      Amazing amazing plugin, thanks so much! I like how this plugin quickly rename /renumber all my scenes in sequence. By the way, is there a way to rename selected scenes only, in bulk? For example, I select scenes 1-10 and rename them to something else, like "Ground floor scenes_xx"? Thanks!
                      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                        db11
                        Four years and a bit later, yes it works on a Mac... but for some reason the web dialog load time is insanely long. At first I thought it wasn't working at all, as the dialog remained blank. I did some other stuff and came back to SU and it was populated. From that point on everything seemed to work fine.
                        I just did a test and it took almost 3 minutes for the dialog to load, so something's not right.
                        The plugin itself is great and a major time saver otherwise.
                        • renderizaR
                          renderiza
                          It's been a long time since I've updated any of my plugins, but I want to make a comeback so I am currently working on some of them which I hope to make available in the near future.
                          At the moment I am creating a framework to make my plugin's GUI be drawn directly on SketchUp's viewport so I can avoid using web-dialogs altogether. This is taking little longer than expected but ones its ready then updating my plugins should be faster.
                          Thanks for the feedback and I'll start working on this plugin sooner than later. 👍
                          • onzkiO
                            onzki
                            Hi, has anyone tried this in 2026? I’ve noticed that the [Re]Name button has a glitch. On the first click, it produces strange 3- or 4-digit scene names like Scene 625, Scene 626, Scene 627. When you click the [Re]Name button again, the second time it corrects itself and gives the expected sequence, such as Scene 1, Scene 2, Scene 3, and so on.
                            • 2 / 2
