    [Plugin] [Re]Scene v1.0.7
    39 Posts 10 Posters 21.4k Views 10 Watching
    • CadFatherC Offline
      CadFather
      Thanks Rafael - it comes very handy!
      • renderizaR Offline
        renderiza
        CadFather you reminded me of something I forgot to add on the info section of the Extension!...I updated the downloads to add that important info to the plugin. 😉
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          JuanV.Soler
          one question Renderiza
          is it possible the undo option ? I can not make it and I think it would nice to have it so to see once and again the changes made
          thanks
            renderiza
            ::JuanV.Soler::
            I will look into this so I can respond to you if it is possible or not.
              JuanV.Soler
              no hurry
              best 👍
                CadFather
                ..you forgot to put cadfather? 😆 but you did all the work... if you only knew how much time you saved me! 👍 😄
                  renderiza
                  Yes I forgot but its all fixed now. 😳 😆
                  Anyways, like I said before ideas are an important part of plugins development and so it brings me joy to say this was a collaboration instead of saying it was all done by me.
                  Cheers! 👍
                    renderiza
                    New Update Released v1.0.4
                    This update is all about making sure [Re]Scene complies with all the requirements of SketchUp 2013 is Extension Warehouse. The plugin was submitted and is awaiting revision to ensure everything is running well. If you don't like to wait until then please download in now from SketchUcation.
                    Cheers!
                      renderiza
                      New Update Released v1.0.5
                      New Features:
                      • [Re]name - Allows you to rename multiple scenes at the same time.
                      • [Re]order - Will reorganize all scenes by alphabetical order.
                      New Web-Dialog:
                      http://s15.postimg.org/ycqlsebaj/dlg_1.jpg
                      Hope you enjoy this new features!
                        renderiza
                        Detected a BUG that will freeze plugin if you push [Re]Name or [Re]Order button and there is no pages(scenes) on you SketchUp.
                        Please don't download v1.0.5 because I will fix this bug very quickly and post v1.0.6
                        Cheers!
                          renderiza
                          New Update Released v1.0.6
                          Now if you click [Re]Name or [Re]Order Buttons without any scenes on you model it will not freeze the plugin.
                          Cheers!
                            JuanV.Soler
                            Hi Renderiza , it seems it does not works well in version 2.013 , do not close neither changes styles .
                            No mores sounds ? 😞
                            keep it up , I think it is a great plugin .
                              renderiza
                              I will fix this problem as soon as possible!
                              Thanks for reporting bug!
                                renderiza
                                I think is fixed now, try downloading it again.
                                About the sounds I guess I will integrate them again soon but with an option to turn them off. 👍
                                  JuanV.Soler
                                  Ok, it does work now 👍
                                    renderiza
                                    Does this plugin work on Mac?
                                    I don't have one so I can't make tests.
                                    Thanks,
                                    Renderiza
                                      renderiza
                                      On Extension Warehouse I read a comment saying this plugins doesn't work on MAC and I recently made few changes on code to see if this can be solved. I personally don't own a MAC so I can't test it myself and will be very grateful if someone can let me know if it works.
                                      Thanks,
                                      Renderiza
                                        glro
                                        I was looking for a plugin to NOT record the camera position in all scenes
                                        too little to match
                                        • onzkiO Offline
                                          onzki
                                          Amazing amazing plugin, thanks so much! I like how this plugin quickly rename /renumber all my scenes in sequence. By the way, is there a way to rename selected scenes only, in bulk? For example, I select scenes 1-10 and rename them to something else, like "Ground floor scenes_xx"? Thanks!
                                          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                                            db11
                                            Four years and a bit later, yes it works on a Mac... but for some reason the web dialog load time is insanely long. At first I thought it wasn't working at all, as the dialog remained blank. I did some other stuff and came back to SU and it was populated. From that point on everything seemed to work fine.
                                            I just did a test and it took almost 3 minutes for the dialog to load, so something's not right.
                                            The plugin itself is great and a major time saver otherwise.
                                            • 2 / 2
