    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      tak2hata
      Hi,All.
      Now I place the new language files in language folder.
      fur_lang_farsi.txt:Persian translation by Majid.Thanks!
      fur_lang_cz.txt:Czech translation by Pepa.Thanks!
      Hi,Anton!
      Nice hair!
      I wish if I had hair like him.
      It will need too much hair spray.
      by TAK2HATA
      • majidM Offline
        majid
        Thank you for update and new interface 😍 πŸ‘
          macmac12
          thanks for the update πŸ˜„
          • OxerO Offline
            Oxer
            Thanks for the update, I have done a new translation for Spanish Language, I add new strings to the file.
            Spanish Language v2.0.4
            fur_lang_esv2.0.4.txt
            • H Offline
              hebeijianke
              Chinese translation new
              fur_lang_cn.txt
              • olisheaO Offline
                olishea
                thanks for the update. great plugin πŸ‘
                oli
                • erikBE Offline
                  erikB
                  thanks for the update, great plugin I use it regularly.
                  erikB
                    tak2hata
                    Thanks Hebeijianke and Oxer for uploading the translation files.
                    Now I'm busy ,so I will update plugin including these translation files in the end of this week.
                    Thank you very much!
                    by TAK2HATA
                      tak2hata
                      Hi,All.
                      I update to v2.0.5.
                      Include new language file for Spanish and Chinese.
                      Thanks Oxer and Hebeijianke!
                      Enjoy!
                      by TAK2HATA
                        meoa
                        Preview shows fur on the selected face but after clicking make fur, quite a number of it go off the selected face. The ones on the face are also scattered unevenly unlike the preview.
                        Is this what should happen or am i doing something wrong ?
                        Ok, sketchup just crashed. I tried it again and it seems to be fine now. Fur stays on the faces. I stil don't know what happened before and the cause.
                          tak2hata
                          Hi,meoa.
                          I need more information for your problem.
                          I can not know what happened, too.
                          Please upload your model and the picture of the fur setting and selected face.
                          Thanks.
                          by TAK2HATA
                            meoa
                            @tak2hata said:
                            Hi,meoa.
                            Thanks.
                            Sorry tak2hata, it was my mistake.
                            I deleted geometry in a component and for some reason it did not rescale or i may have moved the axes by mistake so the component size was far larger than the content(space when you edit the component). Thus, the make fur moved the components further away than the size of the content which explains why they were off the face.
                            make fur on the rectangle's surface using the component beside it
                              tak2hata
                              @meoa said:
                              @tak2hata said:
                              Hi,meoa.
                              Thanks.
                              Hi,meoa.
                              This problem is solved by yourself.
                              by TAK2HATA
                                menes
                                Hello there,
                                First thanks tak2hata for the wonderful plugin.
                                I'm trying long time now to use this for create a nice Olive tree.
                                While the plugin work perfectly for create the single element.
                                I can not in any way create the proper effect randomizing the element using the "leaf" mode.
                                any suggestion?
                                thanks
                                • srxS Offline
                                  srx
                                  Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project πŸ˜„ .
                                  fur_lang_srb.txt
                                  www.saurus.rs
                                    tak2hata
                                    I upload to v2.0.6.
                                    Include the language file for Serbian by SRX.Thanks!
                                    Hi,menes.
                                    I try it!
                                    finished
                                    component for leavs
                                    Component for leaves lay along to X-Axis(RED) with litte slope.
                                    And place it with large Z value of "direction" and "force" in fur dialog.
                                    It make like this placement.
                                    Thanks.
                                    by TAK2HATA
                                    • N Offline
                                      nektares
                                      i loved this plugin already, and now itΒ΄s even better! Arigato Gozaimasu Tak2Hata
                                        menes
                                        Thank you very much indeed! TAK2HATA
                                        Will try and let you know
                                          menes
                                          Thanks TAK2HATA
                                          You put me in the right way 😍 thank you!
                                          My values were different
                                          Main Detail
                                          type : leaf top jitter :8
                                          Density: 60.000 width jitter: 19
                                          Max n. :60.000 stiffness jitter : 50
                                          length :1 valid distance: 0,000
                                          rootwidth : 0,200 direction (x): 0,000
                                          stiffness : 1 direction (y): 0,000
                                          divide :2 direction (z): 1
                                          force (x):0
                                          force (y):0,000
                                          force (z):-30
                                          now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
                                          • thkian92T Offline
                                            thkian92
                                            Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                                            • 32
                                            • 33
                                            • 7 / 33
