    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 217.8k Views 79 Watching
      And remember that if you AutoInstall a plugin from the "SketchUcation Plugin Store" and then find that you only want to use it occasionally, then you can use the Store's toolbar sibling 'SketchUcation Plugins Manager' to 'Disable' it, so then it doesn't auto-load when SketchUp starts.
      Later when you need to use that particular Plugin you just 'Load' it [without Enabling]... so that it 'Loads' into SketchUp for just that one session, but it remains 'Disabled' when SketchUp is restarted.
      If later you find that you want to use it more often, then you can 'Enable' it permanently, so it then auto-loads again whenever SketchUp starts...
      If a Plugin is written as an 'Extension' then you can always use the 'SketchUcation Extension Manager' to 'Enable'/'Disable' it so it is only made active 'on demand'...
      With v2013 the Extensions Manager's tool-details for a selected Extension show its 'Loader' file-path/name, so you can easily find that Plugin and 'Disable' it with the 'Plugin Manager', which will then stop the 'Extension' even being auto-loaded at startup - again that's tidier if it's rarely used...
      • KrisidiousK Offline
        Krisidious
        Really great plugin Pascal... very powerful.
        By: Kristoff Rand
          peerman
          Great plugin!! I have a question though, is it possible to make the leaves and/or flowers have only one color instead of the random ones? I get a lot of different materials that I must change in order for Vray to render them in the correct color. Vray doesn't automatically apply the color to the greyscale image. Another advantage is that the materiallist keeps a bit more organized. For now I will ungroup the tree when it's in the shape I want and then change the material on the leaf component. And then to create some vray proxies!!
          Thanks for this plugin!!
          iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
          • ppoublanP Offline
            ppoublan
            Yes I understand.
            Currently I'm creating 8 small variations of the chosen color to make leaves/flowers each a little bit different. These materials are randomly applied to each component.
            I will add in the futur the option to apply only one material.
            Until this is implemented, you can edit the component, and appy your color/material directly to the faces, this will overwrite the color applied to the component. So this way you will not have to change each color.
            Yours
            Pascal
              peerman
              Pascal, Thanks for the quick reply!! I will try it out today.
              • plot-parisP Offline
                plot-paris
                Looks very promising! I especially like the wind-force... Autumn is coming!
                • majidM Offline
                  majid
                  Great plugin, just to show my respect πŸ‘ πŸ‘ πŸ‘
                  • OxerO Offline
                    Oxer
                    You can obtain very realistic trees, thanks again!! πŸ‘
                    Playing with Vine Tree, I have changed the leafs for high details leafs with new texture and I add more details to the flowers, rendering with Thea.
                    Texture trunk changed.
                    • ppoublanP Offline
                      ppoublan
                      [attachment=1:2v25delg]<!-- ia1 -->Parras2.jpg<!-- ia1 -->[/attachment:2v25delg]
                      [attachment=0:2v25delg]<!-- ia0 -->Parras.jpg<!-- ia0 -->[/attachment:2v25delg]
                      Waouah ! Thanks for sharing your results.
                      I'm working on the web UI interface. Just started so it will need some time, but will be easier to play with parameters. I will ask to those who created great trees to share them in order to include it into the next release (if volonteers of course).
                      Yours
                      • X Offline
                        xyz11811
                        For me, this plugin seems conflict with another plugin " SCF Powerbar". Anyone has the same problem? Big thx!
                          Krisidious
                          I'm not... Try looking if you have the file extensions.rb or sketchup.rb in your plugins folder. If so delete it.
                          By: Kristoff Rand
                            Please don't use SCF-Powerbar [it's not anything to do with SCF officially] or even have it installed...
                            http://sketchucation.com/forums/viewtopic.php?p=112024#p112024
                            It installed old files in the Plugins folder when the SketchUp-installed newer ones were needed in Tools !
                            Double check you have none of those in Plugins [e.g. sketchup.rb, extensions.rb]
                            It was removed last year - it caused too many problems...
                            It was a known 'rogue' long before that...
                            Find its rb file in Plugins and remove it.
                            Get in touch with [PM] its author, CADfather, if you need more advice...
                              Krisidious
                              I cannot give up my SCF PowerBar... It has a paste in place button TIG. A Paste in Place Button! I haven't run into any issue with it that I know of.
                              Oh wait... That's SCF Standard with the past in place. I don't use Power Bar as much. I use the drop, component stringer and line extrude on it though.
                              By: Kristoff Rand
                                BUT hopefully you have NOT got the 'rogue files' that ill-advisedly come with it, inside its ZIP - like sketchup.rb and extensions.rb - which it stupidly puts into the Plugins folder, when SketchUp already puts newer versions of them into the Tools folder as it itself is installed [any versions in those system scripts in the Plugins folder take precedence when loading, and can thereby break SketchUp in unexpected/subtle ways]... πŸ˜’
                                • Alan FraserA Offline
                                  Alan Fraser
                                  There's a Paste in Place on the Edit menu. I put in a Feature Request for it (in V4, I think) because I'd been using it in Corel for years...and we got it. πŸ˜„
                                  3D Figures
                                    mwm5053
                                    Just got on the bandwagon here and works great
                                    Thanks Pascal
                                    THis a quicky in KT
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                    • X Offline
                                      xyz11811
                                      I del those 2 files. Now everything looks great! β˜€
                                      • N Offline
                                        notareal
                                        @krisidious said:
                                        Yes!
                                        It's a conflict.
                                        Removing all plugins from the plugins folder and it works.
                                        Now how can I figure out which one it is...
                                        Even this was a conflict. It's also possible that something gets tossed in virtual store (by improper permissions at plugin -folder). So it's good to use thomthom's VirtualStore Check http://sketchucation.com/forums/viewtopic.php?t=48399 too
                                          Krisidious
                                          Yes Alan there is one on the edit menu, but I hate using menus. I have 6 square foot of screen... I like toolbars. The SCF Standard has a Paste in Place button on it with the copy, paste, cut features.
                                          By: Kristoff Rand
                                            Krisidious
                                            yes, Thanks TIG... I'm finally rid of them.
                                            By: Kristoff Rand
                                            • 16
                                            • 17
                                            • 7 / 17
