    3D connexion space navigator and SU 2013
    13 Posts 8 Posters 1.8k Views 8 Watching
      cadron
      I've been unable to use my space navigator with SU 2013. Thinking i'll have to wait for a new driver update but hoping there might be a work around. Anyone else having issues? Mac osx 10.7.5
      • AdamBA Offline
        AdamB
        At the risk of pointing out the bleedin' obvious.. you have moved all the space navigator plugins to the the SU2013 plugins folder?
        Adam
          cadron
          I tried making a new folder in Library > Application Support > SketchUp 2013> Materials and Components, and put the extensions and plugins from 3dconnexion in there with no success
            Charlie__V
            Alan,
            Same problem here only I am on PC Win7 64bit.
            & yes I moved the 3Dx folder & the plugin to the 2013 Plugin folder.(from SU V8 Plugin folder)
            I even downloaded the latest 3DXware too.....It shows in the extensions and tick box is checked.
            Guess it will be up to 3D Connexion to fix.
            Charlie
              cadron
              Got a reply on the 3Dconnexion forum "You will have to periodically check the website for updates. I donot have a time frame on when the driver will be updated the programmers have to make a updated add-in.
              I tried using our 8 addin but the new version of Sketchup doesnt allow the addin to work"
              • AdamBA Offline
                AdamB
                cadron: Works completely fine on the Mac.
                But no idea why you'd put a plugin in your Material & Components folder !! 😲
                Copy the .plugin and .rb to the SU2013 Plugins folder:
                /Library/Application Support/SketchUp 2013/SketchUp/Plugins
                Adam
                  cadron
                  Thank you Adam! works
                  Created that folder on a suggestion from another forum.
                  • cheddaC Offline
                    chedda
                    By the way they have a beta version of their driver available that works with mountain lion.
                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                      tråvann
                      Same problem here, space navigator does not work with sketchup 2013, hopefully the new drivers will be up soon.
                        Charlie__V
                        Alan,
                        Charlie
                        FYI:
                        Windows 7 64 bit 3D Connexion Space Navigator Update 06/03/2013 for T.SU V2013
                        Release Version 3.17.3
                        Driver Version 6.17.3
                        Firmware Version 3.18
                        Fixes Space Navigator for T.SU V2013
                        Note: May require un-install of existing 3D Connexion Software. (I had to un-install existing 3DX software)
                        Best,
                        Charlie
                        • Bob JamesB Offline
                          Bob James
                          (www.3dconnexion.com)
                            decorarq
                            Hi I use Mac Lion but don´t exist SketchUp 2013 in my directory maybe is hide or I don´t Know how to see.
                            can you help me
                            Rodolfo Prieto
                            • charly2008C Offline
                              charly2008
                              Thanks Bob,
                              I installed the new Driver. Now it works in 2013. However, before I had to copy the new 3DxSketchUp.dll file from "Sketchup 8" into "Sketchup 2013".
                              Charly
