    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.1k Views 76 Watching
      alexdobras
      @tig said:
      Are you making a 'group' or a 'component' - it needs a 'group'... πŸ˜•
      It won't work with 'component instances' only on two groups...
      owww sorry, i wasn't paying attention to the explenantion of the plugin. I read component instead of group.
      So everything needs to be as a group.
      Thanks TIG πŸ˜‰
        adskad
        TIG,
        I am very excited to use this plugin, but sadly, I seem to lack the skill - I have sketchup 8 pro, I have made 2 groups of edges and named them 'path' and 'profile', it seems to be working giving a "multiplying edges" message, but then - nothing. I am including a pic, but it isn't revealing much to me.
        Thank you for your time
        Adam
        • bazB Offline
          baz
          @adskad said:
          TIG,
          [attachment=2:2xkjp7xk]<!-- ia2 -->EEsad.png<!-- ia2 -->[/attachment:2xkjp7xk]
          Adam
          Dont wish to butt in, but I was having a play with tigs plugin. I duplicated your attempt, and it works fine for me....
          I notice that your left hand group seems to have a larger than necessary bounding box, do you have some extraneous geometry in there which is confusing the plugin?
          baz[attachment=1:2xkjp7xk]<!-- ia1 -->ee.png<!-- ia1 -->[/attachment:2xkjp7xk][attachment=0:2xkjp7xk]<!-- ia0 -->ee.png<!-- ia0 -->[/attachment:2xkjp7xk]
            adskad
            Baz,
            I have three lines grouped, so it looks like it may have hidden stuff, but I checked. Do you think it might be windows 64 bit that is the problem?
            Adam
            • bazB Offline
              baz
              @adskad said:
              Baz,
              Adam
              I dont know much about 64bit stuff, but I have'nt noticed anything on this forum about problems with it.
              Why not post the skp? I bet you its something in there. Or start again from scratch and see how you go. Tigs plugins are some of the best you will come across, so I think it must be something you are doing, (or not doing).
              baz
                No - SU's runs like a normal 32bit application anyway.
                  adskad
                  Can you post the simple SKP you are having the problem with...
                  With EEbyE two simple groups containing some edges/curves with interact to form a mesh - are you sure you haven't 'nest-grouped' them or something.
                  This is one of the simplest EEby... tools... πŸ˜•
                    adskad
                    I installed it on a 32 bit computer, and it works perfectly. I appreciate the help - I will re-install on my current computer and try again.
                    It is fantastic BTW - thank you TIG!
                      rv1974
                      Thank you TIG as always.
                      Some humble sugestion if I may:
                      Your scripts would gain even more popularity if you'd put concentrated set of gif's (like this for example http://www.polyboost.com/)
                        There are several movie tut's 'in progress' - meanwhile there are quite a lot of static step-by-step tut's...
                          deanlegg
                          Hi all
                          Love the plugin really good
                          2 things, I can't get the toolbar to show up, I have the outer box where about 6 icons would be but no icons
                          And could you direct me to some good tutorials
                          Cheers
                            @deanlegg said:
                            Hi all
                            Cheers
                            Have you kept all of the icon image/lingvo files [~51 of them] etc in the TIGtools subfolder inside Plugins - not having done so is the usual cause of this issue... Do a new install, extract the zip file's contents into a temporary folder - perhaps on your Desktop - keeping all the files in the appropriate subfolder. Then move or copy that subfolder and the other rb files into Plugins folder... If this fixes it then I suggest you look through the Plugins folder and tidy up any files that are in TIGtools and also incorrectly installed in there πŸ€“
                              khashayar
                              hi
                              thank you for the great great plugin. i was trying to make a tent structure with it but i couldn't do it.
                              here i attached the sketchup file. i'd be really glad if you could check it out and tell me if it's possible to make a tent out of it or ....not.
                              thanks
                              tent.skp
                                Kahashayar
                                EEbyEdges is not the right tool to make that form.
                                Try its cousin - EEbyRails - and make each side one of four meshes, as this example Capture.PNG
                                  khashayar
                                  thank you TIG. that was a big help .
                                  @tig said:
                                  Kahashayar
                                  • 66searcher6 Offline
                                    66searcher
                                    thanks TIG
                                    πŸ‘
                                    http://hamidtoliat.deviantart.com/
                                    • mitcorbM Offline
                                      mitcorb
                                      Hi, irwanwr:
                                      In answer to your question and based on the image by TIG above, this plugin "Extrude Edges by Edges" is not the one. As TIG showed in that image, you would need "Extrude Edges by Rails" and assemble the form.
                                      I also replied in your Carnival Tent posting.
                                      • I Offline
                                        Iho
                                        why it doesn't work?
                                        http://i.imgur.com/3aZXU.jpg
                                        In pictures line are two simple lines regruped in two different group.
                                          It works fine for me ?
                                          How large are your grouped arcs ?
                                            kieran28
                                            hope this doesn't sound stupid but does this plugin work on mac OS?
                                            • 9 / 10
