    Sketchup 2013 Plugins with missing toolbars...
    10 Posts 7 Posters 6.2k Views 7 Watching
      brunolopes3Dartist
      Hello,
      I've recently did a fresh install of sketchup 2013 and are some essentials plugins that I can't live without.
      And after install, the toolbar is active but not visible.
      I'll use this thread to track the plugins with invisible toolbars and giving errors.
      Updape - 2013-05-27
      EdgeTools (thomthom) - OK! (check the first 5 replys for the solution)
      Quadface tools (thomthom) - OK! (check the first 5 replys for the solution)
      Selection toys (thomthom) - OK! (check the first 5 replys for the solution)
      Architect tools (thomthom) - OK! (check the first 5 replys for the solution)
      UvToolkit (thomthom) - OK!
      Round Corner (Fredo6) - OK!
      Joint Push Pull (Fredo6) - OK!
      [b]Extrusion tools (TIG) - OK! (check the first 5 replys for the solution)
      1001 bit Pro - OK!
      2D Tools (TIG) - OK! (check the first 5 replys for the solution)
        One thing which people report to work for them is to detach the toolbars they can see - then eventually you will find the missing toolbars underneath.
        • KrisidiousK Offline
          Krisidious
          checkmarking everything and then restarting SketchUp worked for me. You may have to go in and checkmark them again once you reopen.
          By: Kristoff Rand
            brunolopes3Dartist
            Thanks for the reply...Thomthom and Krisiddious, that worked, they are visible, by I can't detach them, move them, and if I dock or active another toolbar they disapear again 😞
            • BoxB Online
              Once you can see the toolbar, double click on it and it will release from the menu bar.
                brunolopes3Dartist
                WOW...Box, that worked...very nice...but very very odd 😞
                • I Offline
                  interverne
                  Thanks so much gentlemen..The hidden tool bars were stacked on top of one another in the top corner. Double clicking on top of each successive one on top (undocking it) relieved to toolbar underneath...
                  • TIGT Online
                    I have had one XP user reporting this issue, where a new toolbar remained 'invisible' when it was checked 'on' BUT it was nowhere to be found - not docked in the top-bar below another toolbar, or on any other bar for that matter...
                    In that case I recommended the registry-hack...
                    Then on SketchUp's startup that should make that toolbar appear docked properly in the top-bar... BUT in this XP case it now docked the toolbar below another toolbar on the top-bar... and then the usually effective drag-off+double-click fix worked πŸ˜’
                    See the separate threads on this... πŸ˜•
                    This painful issue is is begging of a quick fix 😞
                      Krisidious
                      Have you upgraded to Windows XP SP3?
                      By: Kristoff Rand
                      • H Offline
                        hajar
                        thank you very much guys, i had same problem now it's solved!
