    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 222.1k Views 79 Watching
    • KrisidiousK Offline
      Krisidious
      Done... Still problem persists...
      By: Kristoff Rand
        What's under the 'Owner' tab ?
          Krisidious
          By: Kristoff Rand
            Then you are screwed 😲
            I'm out of ideas... πŸ˜’
              Krisidious
              By: Kristoff Rand
                Krisidious
                By: Kristoff Rand
                  Krisidious
                  πŸ’­
                  By: Kristoff Rand
                    Krisidious
                    Yes!
                    It's a conflict.
                    Removing all plugins from the plugins folder and it works.
                    Now how can I figure out which one it is...
                    By: Kristoff Rand
                    • BoxB Offline
                      Do the old half half trick, add half of them back, if they work try the other half, when you get a half that doesn't work halve it and repeat until you have the one precious.
                        Krisidious
                        I have something running that none of you do... and David does.
                        David? What do you draw?
                        By: Kristoff Rand
                          Krisidious
                          extensions.rb...
                          By: Kristoff Rand
                            Krisidious
                            Tig says...
                            As a 'health-check' can I suggest that anyone who thinks they have a mess up looks in their ../Plugins folder for the following .rb files that ought to appear only in their ../Tools folder.
                            If they are in the wrong folder move them [back] into ../Tools; if they are duplicated then remove the Plugins folder's version.
                            Depending on your SUp version, and what optional tools you might have, you could have these .rb files...
                            Which should be in ../Tools if you have them at all...
                            The bold ones are the base-set for most setups and have been around for several versions...
                            advancedcameratools
                            date
                            **dynamiccomponents**
                            **extensions**
                            filmandstage
                            **langhandler**
                            make_pano_pm
                            rational
                            **sandboxtools**
                            shadowstringsfix
                            **sketchup**
                            SolarNorth
                            webtextures
                            Several of these have matching subfolders - e.g. 'Sandbox' within ../Tools too...
                            If you are in any doubt ask.
                            Don't delete any duplicated files you find but rather move them into a [new name='disabled'] subfolder so they don't auto-load - then you can always restore them when you've gone wrong πŸ˜’
                            By: Kristoff Rand
                              Note that with the advent of v2013 the files:
                              su_advancedcameratools.rb su_dynamiccomponents.rb su_sandbox.rb su_webtextures.rb
                              and their matching-named folders should now be in the 'Plugin' folder.
                              As installed by SketchUp 2013's installer
                              These files replace the earlier SketchUp version's similar files [named without the 'su_' prefix] which belonged in the 'Tools' folder [<=v8], BUT which sometimes got misplaced in the Plugins folder...
                              The other 'system' .rb files still reside in the 'Tools' folder in v2013 as before [i.e. sketchup.rb, extensions.rb and langhandler.rb].
                                Krisidious
                                hooray...
                                By: Kristoff Rand
                                • BoxB Offline
                                  Just curious Kristoff, did you copy plugins over from SU8 or did you clean install them all?
                                    Krisidious
                                    What do you think... 🀣
                                    You know how the sketchucation plugin store says 800 plugins? I tried each one...
                                    By: Kristoff Rand
                                    • BoxB Offline
                                      Fair enough, but I have only installed what I needed as I wanted it, stopped me having loads of crap that I had tried in the past and didn't use now.
                                      With the Sketucation plugin it makes it simple to start from scratch.
                                        And remember that if you AutoInstall a plugin from the "SketchUcation Plugin Store" and then find that you only want to use it occasionally, then you can use the Store's toolbar sibling 'SketchUcation Plugins Manager' to 'Disable' it, so then it doesn't auto-load when SketchUp starts.
                                        Later when you need to use that particular Plugin you just 'Load' it [without Enabling]... so that it 'Loads' into SketchUp for just that one session, but it remains 'Disabled' when SketchUp is restarted.
                                        If later you find that you want to use it more often, then you can 'Enable' it permanently, so it then auto-loads again whenever SketchUp starts...
                                        If a Plugin is written as an 'Extension' then you can always use the 'SketchUcation Extension Manager' to 'Enable'/'Disable' it so it is only made active 'on demand'...
                                        With v2013 the Extensions Manager's tool-details for a selected Extension show its 'Loader' file-path/name, so you can easily find that Plugin and 'Disable' it with the 'Plugin Manager', which will then stop the 'Extension' even being auto-loaded at startup - again that's tidier if it's rarely used...
                                          Krisidious
                                          Really great plugin Pascal... very powerful.
                                          By: Kristoff Rand
                                            peerman
                                            Great plugin!! I have a question though, is it possible to make the leaves and/or flowers have only one color instead of the random ones? I get a lot of different materials that I must change in order for Vray to render them in the correct color. Vray doesn't automatically apply the color to the greyscale image. Another advantage is that the materiallist keeps a bit more organized. For now I will ungroup the tree when it's in the shape I want and then change the material on the leaf component. And then to create some vray proxies!!
                                            Thanks for this plugin!!
                                            iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                                            • 16
                                            • 17
                                            • 6 / 17
