    New to Ruby - I want to write a script to...
    26 Posts 5 Posters 2.6k Views 5 Watching
      driven
      hi Keith,
      the first bits relatively easy. if you paste this into 'Ruby Console' and hit 'return' it will open and mod all the .skp's found. Personally I find 'shadows_face_sun' a bit odd looking...
      # add your folder your path replaces this
      loadFolder =  "/your/path"
      skpFiles = Dir[File.join( loadFolder, "*.skp" )]
      #open the files
      skpFiles.each {|f|
      Sketchup.open_file f;
      # do your ruby actions
      Sketchup.active_model.selection.to_a.find_all{|e|e.class==Sketchup;;ComponentInstance}.map{|i|i.definition}.each{|d|d.behavior.always_face_camera=true; d.behavior.shadows_face_sun = true}
      once there all done, you can either use Cmd "S" to save them, and if in the correct format Cmd "W" to close...
      alternatively, you could run this Applescript which will do the save and click any drop-downs that appear.
      for some reason it stalls on some windows, but if you click the error box and then 'Run' again it carries on.
      Run in Applescript Editor after all the skps are open...
      activate application "SketchUp"
      tell application "System Events"
      	tell process "SketchUp"
      		set winCount to count of every window
      		repeat with n from 1 to winCount
      			if description of window n is "standard window" then
      			set thisWindow to window n
      				try
      					if exists (click menu item "Save" of menu "File" of menu bar 1) then
      					end if
      				end try
      				delay 0.5
      				try
      					if exists (click button "Save" of sheet 1 of thisWindow) then
      					end if
      				end try
      				delay 0.5
      				try
      					if exists (click button "Replace" of sheet 1 of sheet 1 of thisWindow) then
      					end if
      				end try
      				delay 0.5
      				try
      					if exists (click menu item "Close" of menu "File" of menu bar 1) then
      					end if
      				end try
      			end if
      		end repeat
      	end tell
      end tell
      • K
        keithswd
        Driven - Thanks so much for taking the time to write that up for me.
        Unfortunately I don't think this approach will work as it seems that it opens all the files in the folder in one go? I have hundreds of files to process (although I could put them into a working folder in batches I suppose). I am going to try modifying your code to get the array of *.skp files in the folder, then sequentially load each one as a component, modify it, save it back to the folder, delete and purge the instance, and move on to the next file. It seems like that will avoid the issue of not being able to close the current model via Ruby, and will only open one component at a time.
        cheers Keith
        • K
          keithswd
          This code appears to work on a test folder of 10 .skp files. Haven't let it loose on the main folder of 500!
          model = Sketchup.active_model
          # set folder and get array of filenames
          loadFolder = "/Users/Keith/Illustration Library/Testfolder"
          skpFiles = Dir[File.join(loadFolder, "*.skp")]
          # Returns a DefinitionList
          definitions = model.definitions
          # iterate through files
          skpFiles.each do |compFile|
          	compDefinition = definitions.load compFile
          	behavior = compDefinition.behavior
          	behavior.always_face_camera = true
          	compDefinition.save_as compFile
          	definitions.purge_unused
          no error handling of course so it's a bit 'quick and dirty'.
          • Dan RathbunD
            Dan Rathbun
            Yes make backups first.
            And when it comes to file work trapping errors is best.
            I would think that the user would be prompted to overwrite the old skp file.
            You don't see a confirm MB on the Mac ?
            I'm not here much anymore.
              If you make a subfolder then you can save the reformatted SKPs into there and leave the original SKPs alone...
              That way you never change the original SKPs' data and don't need prompts etc... πŸ˜•
              • K
                keithswd
                As the code stands it runs without any prompts at all. It processed 10 files in the folder in an instant. For my purposes I'd rather manually copy files to be processed into the folder and run the script unattended, knowing I had my own backups. It's only for me to use so I c an leave it rough and ready... Might be nice to select the folder via the file open dialog, other than that I think it serves my needs
                Thanks to all for the help and encouragement.
                • Dan RathbunD
                  Dan Rathbun
                  Might be nice to select the folder via the file open dialog, ...
                  folder = UI.openpanel("Choose a skp file to set folder","*.skp")
                  if folder && folder = File.dirname(folder)
                    # do your stuff
                    driven
                    no problem Keith,
                    we need to encourage mac users who are prepared to dip into coding, we're in a minority,
                    if nothing else, there are always PC authored scripts that need a bit of ironing before they're fully mac compatible.
                    @dan wrote a good 'chunking' script for me to process a 3D text sampler that may be useful/adaptable for handling a 500 file array. I'll see if I can find the link.
                    FOUND: http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=444342&hilit=3d+text+chunk#p444342
                    PS, are you in London UK, or one of the impostors, I'm in East Dulwich?
                    • K
                      keithswd
                      Ah - I was wondering what might happen if I loaded a really huge folder - actually I have a couple of thousand file to process. Not all at once though... I will check out that link when I have more time, at first glance looks a bit scary for a novice!
                      Yes, I really am in London UK (live in W14, work SE11)!
                      • K
                        keithswd
                        Thanks Dan for the pointer to UI.openpanel, that all works fine.
                        Not sure if it is because I need to learn about chunking my array, but my routine stops every time after processing 33 or 34 files (it is always after 33 or 34 files) and then SU8 crashes. Given that such a small number of files are processed before the hang/crash, I am not sure the array size is the problem? When the script stops running, I am left with the last loaded component in the component list. If I try and and check its 'Face-Me' status, SU crashes.
                        def setcompfm
                        	skpFiles = Dir[File.join(folder, "*.skp")]
                        length = skpFiles.length
                        result = UI.messagebox "Process " + length.to_s + " files?", MB_YESNO
                        if result == 6 # Yes
                        begin
                        	end #end do
                        rescue
                        	puts compFile
                        end #end begin
                        end #end if
                        end #end def
                        • Dan RathbunD
                          Dan Rathbun
                          The folder check was meant to enclose everything... but I see you have a empty folder check (which probably cannot happen because an actual file must be selected. BUT...
                          change line 7 to:
                          return unless folder && folder = File.dirname(folder)
                          REMOVE the end (line 9)
                          If you cancel the open panel, NOW your method exits (because the result of UI.openpanel will eval falsely.)
                          • Dan RathbunD
                            Dan Rathbun
                            change the name of THAT 33rd or 34th file to ".OFF" or whatever.
                            Then try again. Just eliminate the bad file scenario.
                            • K
                              keithswd
                              Thanks for the correction - I see my mistake now. However, the corrected syntax doesn't fix the crash. The folder selection works as it did before and populates the array with all the .skp files in the folder (about 200 for testing purposes), and my message box pops up and correctly reports the number to be processed.
                              However it stops on the 33rd or 34th file no matter what that file is. Each time I run the script, I move the 33/34 successfully modified files out of the folder, so I am never processing the same files twice. I don't know what might be special about the 33/34 mark, but it bails at that point.
                              Some kind of limit appears to be reached? Memory? I've no clue!
                                driven
                                not sure how to do it in ruby but in the osascript/applescript/bash I tend to use, if you don't add a distinct delay point, the process reaches some limit and errors. [That's what happening with the one I posted earlier]
                                maybe adding a puts "done" after definitions.purge_unused will allow a break before opening the next?
                                total stab in the dark
                                • Dan RathbunD
                                  Dan Rathbun
                                  (1) The iterator block.. use curly braces instead of do ... end
                                  So the block can have access to external references, such as definitions
                                  (2) Make sure the loading is done before proceeding.
                                  (3) perhaps use undo operations ?
                                  Try an iterator like:
                                    i = 0
                                    puts()
                                    skpFiles.each { |compFile|
                                      model.operation( "Update '#{File.basename(compFile)}'", true )
                                      begin
                                        if compDefinition.internal?
                                        else
                                          putc(46) # period char
                                          redo
                                      rescue => e
                                        model.abort_operation()
                                        puts()
                                        puts "ERROR saving component file;"
                                        puts "  #{compFile}\n"
                                        puts e.message
                                        puts e.backtrace if $VERBOSE
                                        puts()
                                      else
                                        i += 1
                                        if i >= 10
                                          i = 0
                                        model.commit_operation()
                                      # each skp file
                                    definitions.purge_unused if definitions.length > 0
                                  • K
                                    keithswd
                                    Thanks again for your help and suggested code. As it stands it does not modify any components. I discovered this is because it seems that even when the component file is loaded successfully, compDefinition.internal? returns false. I can only imagine that this is actually testing whether the component was created within the model or loaded from a file - in which case we are getting the expected result. I commented it out and it runs but... sadly it still bombs out at around 33 components.
                                    I really don't want to take up any more of anyone's time - this was just a little project for me to play with but it seems rather trickier than I could have forseen. But I thought you might like an update!
                                    def setcompfm
                                    return unless result == 6 # Yes
                                    i = 0
                                      puts()
                                        model.start_operation( "Update '#{File.basename(compFile)}'", true )
                                        begin
                                          #if compDefinition.internal?
                                          #else
                                          #  putc(46) # period char
                                          #  redo
                                          #end
                                        rescue => e
                                          puts()
                                          puts e.message
                                          puts()
                                        else
                                          i += 1
                                          if i >= 10
                                            i = 0
                                        # each skp file
                                    end #end def
                                      driven
                                      Hi Keith,
                                      I'm sitting at home recovering from having my ear cut off [and put back on] on Friday.
                                      So, glad for the distraction...
                                      Anyhow, heres an Automator script that has a safe test action, so won't hurt any files...
                                      I missed a filter function, in the first...
                                      1. opens each .skp in a 'pre-selected' folder in SU v2013 [should use your version if not]
                                      2. opens 'Ruby Console' and 'types' some safe for testing code Sketchup.send_action('viewIso:');Sketchup.send_action('viewZoomExtents:')clicks return
                                      3. 'Saves' the changes
                                      4. closes 'RC'
                                      5. closes the .skp
                                      6. loops to the next skp in folder... and repeats
                                      You need to open SU first with an empty new drawing... this just saves hassle.
                                      Pre-Sellect skps in a Folder.
                                      Open the workflow in 'Automator.app' by double clicking after unzipping it.
                                      Click Run, watch the show [I like the way it types for me, rather than just inserting it en-masse]
                                      If your not using v2013 you'll may need replace the SketchUp.app shown with the one on your path [I know it looks right but I did a trick to avoid using v8, so just swap it if you need to, run it once to see if it fails...]
                                      Once your happy the safe version works, edit the applescript with your SU [a 'one-liner' is probably best]
                                      try it on a subset, if it runs those, it will run hundreds as long as you adjust the timeout [in loop field] to cover it...
                                      Let me know if it works
                                      • K
                                        keithswd
                                        Hi John,
                                        The ear sounds painful! I hope you are recuperating well.
                                        Thanks for the workflow. I have got it to work, with SU loading a script automatically (which defines a function to set the current model behavior as I want it) and I call that function in console. It runs slowly compared to the all-Ruby solution - but at least it processes without crash. So I can send lots of files and leave it to run over lunch, or night!
                                        Many thanks again,
                                        Keith
