    New to Ruby - I want to write a script to...
    26 Posts 5 Posters 2.4k Views 5 Watching
      driven
      @dan rathbun said:
      (2) Read the Terms of Use regarding using (or forbidding use of,) SketchUp in an "automated manner".
      You may not use the Trimble Software in any manner that could damage, disable, overburden, or impair Trimble's services (e.g., you may not use the Trimble Software in an automated manner), nor may you use Software in any manner that could interfere with any other party's use and enjoyment of Trimble Services.
      my take on this is as long as your 'offline' you are not overburdening, Trimble's services in any way, in which case you can use 'Automator.app' to sequentially open and perform actions on your files.
      If Trimble think Apple should not be allowing us to do this, then their lawyers can fight it out...
      • K
        keithswd
        Dan - thanks for the response but I don't see how it would help me. I have a large number of components (actually a purchased library of entourage images as .skp files) which are not set up to Face-Me. Each time I insert one for the first time I have to set these two properties. I then save the component back to the file so I don't need to do it for that file again, but there are a hell of a lot yet to be updated...
        I hadn't expected any issues with T&C though!
        • Dan RathbunD
          Dan Rathbun
          Oh and BTW... batch mode processing is easier on Windows as the same document window is reused, so that their is only ever ONE model file open, at a time.
          Mac SketchUp will open a new document window for EVERY file in the folder, because there is no way via the API to close model windows.
          The API does NOT have a built-in interface to simulate user keystrokes (in order to dismiss modal dialogs, etc.)
          You would have to use a 3rd-party utility. Some use Applescript on Mac.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            Yes that also makes sense to me.. but I have also had to deal with lawyers in the past, and they come from a galaxy far far away... and do not think like us mere mortals.
            YES I DO know how to do it. BUT I am wary of distributing such a utility (which I have already written to about 90% done.)
            • K
              keithswd
              I could do it Windows (via Parallels). Or perhaps process the components within a single model:
              Load component from file
              Set attributes
              Save component back to file
              Delete component instance
              Purge component
              Next
              I'll get reading the Newbie guides... Thanks again.
                driven
                hi Keith,
                the first bits relatively easy. if you paste this into 'Ruby Console' and hit 'return' it will open and mod all the .skp's found. Personally I find 'shadows_face_sun' a bit odd looking...
                # add your folder your path replaces this
                loadFolder =  "/your/path"
                skpFiles = Dir[File.join( loadFolder, "*.skp" )]
                #open the files
                skpFiles.each {|f|
                Sketchup.open_file f;
                # do your ruby actions
                Sketchup.active_model.selection.to_a.find_all{|e|e.class==Sketchup;;ComponentInstance}.map{|i|i.definition}.each{|d|d.behavior.always_face_camera=true; d.behavior.shadows_face_sun = true}
                once there all done, you can either use Cmd "S" to save them, and if in the correct format Cmd "W" to close...
                alternatively, you could run this Applescript which will do the save and click any drop-downs that appear.
                for some reason it stalls on some windows, but if you click the error box and then 'Run' again it carries on.
                Run in Applescript Editor after all the skps are open...
                activate application "SketchUp"
                tell application "System Events"
                	tell process "SketchUp"
                		set winCount to count of every window
                		repeat with n from 1 to winCount
                			if description of window n is "standard window" then
                			set thisWindow to window n
                				try
                					if exists (click menu item "Save" of menu "File" of menu bar 1) then
                					end if
                				end try
                				delay 0.5
                				try
                					if exists (click button "Save" of sheet 1 of thisWindow) then
                					end if
                				end try
                				delay 0.5
                				try
                					if exists (click button "Replace" of sheet 1 of sheet 1 of thisWindow) then
                					end if
                				end try
                				delay 0.5
                				try
                					if exists (click menu item "Close" of menu "File" of menu bar 1) then
                					end if
                				end try
                			end if
                		end repeat
                	end tell
                end tell
                • K
                  keithswd
                  Driven - Thanks so much for taking the time to write that up for me.
                  Unfortunately I don't think this approach will work as it seems that it opens all the files in the folder in one go? I have hundreds of files to process (although I could put them into a working folder in batches I suppose). I am going to try modifying your code to get the array of *.skp files in the folder, then sequentially load each one as a component, modify it, save it back to the folder, delete and purge the instance, and move on to the next file. It seems like that will avoid the issue of not being able to close the current model via Ruby, and will only open one component at a time.
                  cheers Keith
                  • K
                    keithswd
                    This code appears to work on a test folder of 10 .skp files. Haven't let it loose on the main folder of 500!
                    model = Sketchup.active_model
                    # set folder and get array of filenames
                    loadFolder = "/Users/Keith/Illustration Library/Testfolder"
                    skpFiles = Dir[File.join(loadFolder, "*.skp")]
                    # Returns a DefinitionList
                    definitions = model.definitions
                    # iterate through files
                    skpFiles.each do |compFile|
                    	compDefinition = definitions.load compFile
                    	behavior = compDefinition.behavior
                    	behavior.always_face_camera = true
                    	compDefinition.save_as compFile
                    	definitions.purge_unused
                    no error handling of course so it's a bit 'quick and dirty'.
                    • Dan RathbunD
                      Dan Rathbun
                      Yes make backups first.
                      And when it comes to file work trapping errors is best.
                      I would think that the user would be prompted to overwrite the old skp file.
                      You don't see a confirm MB on the Mac ?
                        If you make a subfolder then you can save the reformatted SKPs into there and leave the original SKPs alone...
                        That way you never change the original SKPs' data and don't need prompts etc... 😕
                        • K
                          keithswd
                          As the code stands it runs without any prompts at all. It processed 10 files in the folder in an instant. For my purposes I'd rather manually copy files to be processed into the folder and run the script unattended, knowing I had my own backups. It's only for me to use so I c an leave it rough and ready... Might be nice to select the folder via the file open dialog, other than that I think it serves my needs
                          Thanks to all for the help and encouragement.
                          • Dan RathbunD
                            Dan Rathbun
                            Might be nice to select the folder via the file open dialog, ...
                            folder = UI.openpanel("Choose a skp file to set folder","*.skp")
                            if folder && folder = File.dirname(folder)
                              # do your stuff
                              driven
                              no problem Keith,
                              we need to encourage mac users who are prepared to dip into coding, we're in a minority,
                              if nothing else, there are always PC authored scripts that need a bit of ironing before they're fully mac compatible.
                              @dan wrote a good 'chunking' script for me to process a 3D text sampler that may be useful/adaptable for handling a 500 file array. I'll see if I can find the link.
                              FOUND: http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=444342&hilit=3d+text+chunk#p444342
                              PS, are you in London UK, or one of the impostors, I'm in East Dulwich?
                              • K
                                keithswd
                                Ah - I was wondering what might happen if I loaded a really huge folder - actually I have a couple of thousand file to process. Not all at once though... I will check out that link when I have more time, at first glance looks a bit scary for a novice!
                                Yes, I really am in London UK (live in W14, work SE11)!
                                • K
                                  keithswd
                                  Thanks Dan for the pointer to UI.openpanel, that all works fine.
                                  Not sure if it is because I need to learn about chunking my array, but my routine stops every time after processing 33 or 34 files (it is always after 33 or 34 files) and then SU8 crashes. Given that such a small number of files are processed before the hang/crash, I am not sure the array size is the problem? When the script stops running, I am left with the last loaded component in the component list. If I try and and check its 'Face-Me' status, SU crashes.
                                  def setcompfm
                                  	skpFiles = Dir[File.join(folder, "*.skp")]
                                  length = skpFiles.length
                                  result = UI.messagebox "Process " + length.to_s + " files?", MB_YESNO
                                  if result == 6 # Yes
                                  begin
                                  	end #end do
                                  rescue
                                  	puts compFile
                                  end #end begin
                                  end #end if
                                  end #end def
                                  • Dan RathbunD
                                    Dan Rathbun
                                    The folder check was meant to enclose everything... but I see you have a empty folder check (which probably cannot happen because an actual file must be selected. BUT...
                                    change line 7 to:
                                    return unless folder && folder = File.dirname(folder)
                                    REMOVE the end (line 9)
                                    If you cancel the open panel, NOW your method exits (because the result of UI.openpanel will eval falsely.)
                                    • Dan RathbunD
                                      Dan Rathbun
                                      change the name of THAT 33rd or 34th file to ".OFF" or whatever.
                                      Then try again. Just eliminate the bad file scenario.
                                      • K
                                        keithswd
                                        Thanks for the correction - I see my mistake now. However, the corrected syntax doesn't fix the crash. The folder selection works as it did before and populates the array with all the .skp files in the folder (about 200 for testing purposes), and my message box pops up and correctly reports the number to be processed.
                                        However it stops on the 33rd or 34th file no matter what that file is. Each time I run the script, I move the 33/34 successfully modified files out of the folder, so I am never processing the same files twice. I don't know what might be special about the 33/34 mark, but it bails at that point.
                                        Some kind of limit appears to be reached? Memory? I've no clue!
                                          driven
                                          not sure how to do it in ruby but in the osascript/applescript/bash I tend to use, if you don't add a distinct delay point, the process reaches some limit and errors. [That's what happening with the one I posted earlier]
                                          maybe adding a puts "done" after definitions.purge_unused will allow a break before opening the next?
                                          total stab in the dark
                                          • Dan RathbunD
                                            Dan Rathbun
                                            (1) The iterator block.. use curly braces instead of do ... end
                                            So the block can have access to external references, such as definitions
                                            (2) Make sure the loading is done before proceeding.
                                            (3) perhaps use undo operations ?
                                            Try an iterator like:
                                              i = 0
                                              puts()
                                              skpFiles.each { |compFile|
                                                model.operation( "Update '#{File.basename(compFile)}'", true )
                                                begin
                                                  if compDefinition.internal?
                                                  else
                                                    putc(46) # period char
                                                    redo
                                                rescue => e
                                                  model.abort_operation()
                                                  puts()
                                                  puts "ERROR saving component file;"
                                                  puts "  #{compFile}\n"
                                                  puts e.message
                                                  puts e.backtrace if $VERBOSE
                                                  puts()
                                                else
                                                  i += 1
                                                  if i >= 10
                                                    i = 0
                                                  model.commit_operation()
                                                # each skp file
                                              definitions.purge_unused if definitions.length > 0
