    New to Ruby - I want to write a script to...
    26 Posts 5 Posters 2.3k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      This code appears to work on a test folder of 10 .skp files. Haven't let it loose on the main folder of 500!
      no error handling of course so it's a bit 'quick and dirty'.
      Yes make backups first.
      And when it comes to file work trapping errors is best.
      I would think that the user would be prompted to overwrite the old skp file.
      You don't see a confirm MB on the Mac ?
      I'm not here much anymore.
      • TIGT Online
        If you make a subfolder then you can save the reformatted SKPs into there and leave the original SKPs alone...
        That way you never change the original SKPs' data and don't need prompts etc... πŸ˜•
          keithswd
          As the code stands it runs without any prompts at all. It processed 10 files in the folder in an instant. For my purposes I'd rather manually copy files to be processed into the folder and run the script unattended, knowing I had my own backups. It's only for me to use so I c an leave it rough and ready... Might be nice to select the folder via the file open dialog, other than that I think it serves my needs
          Thanks to all for the help and encouragement.
            Dan Rathbun
            Might be nice to select the folder via the file open dialog, ...
            folder = UI.openpanel("Choose a skp file to set folder","*.skp")
            if folder && folder = File.dirname(folder)
              # do your stuff
              driven
              no problem Keith,
              we need to encourage mac users who are prepared to dip into coding, we're in a minority,
              if nothing else, there are always PC authored scripts that need a bit of ironing before they're fully mac compatible.
              @dan wrote a good 'chunking' script for me to process a 3D text sampler that may be useful/adaptable for handling a 500 file array. I'll see if I can find the link.
              FOUND: http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=444342&hilit=3d+text+chunk#p444342
              PS, are you in London UK, or one of the impostors, I'm in East Dulwich?
                keithswd
                Ah - I was wondering what might happen if I loaded a really huge folder - actually I have a couple of thousand file to process. Not all at once though... I will check out that link when I have more time, at first glance looks a bit scary for a novice!
                Yes, I really am in London UK (live in W14, work SE11)!
                  keithswd
                  Thanks Dan for the pointer to UI.openpanel, that all works fine.
                  Not sure if it is because I need to learn about chunking my array, but my routine stops every time after processing 33 or 34 files (it is always after 33 or 34 files) and then SU8 crashes. Given that such a small number of files are processed before the hang/crash, I am not sure the array size is the problem? When the script stops running, I am left with the last loaded component in the component list. If I try and and check its 'Face-Me' status, SU crashes.
                  def setcompfm
                  model = Sketchup.active_model
                  # set folder and get array of filenames
                  	skpFiles = Dir[File.join(folder, "*.skp")]
                  length = skpFiles.length
                  result = UI.messagebox "Process " + length.to_s + " files?", MB_YESNO
                  if result == 6 # Yes
                  # Returns a DefinitionList
                  definitions = model.definitions
                  # iterate through files
                  begin
                  	skpFiles.each do |compFile|
                  		compDefinition = definitions.load compFile
                  		behavior = compDefinition.behavior
                  		behavior.always_face_camera = true
                  		behavior.shadows_face_sun = true
                  		compDefinition.save_as compFile
                  		definitions.purge_unused
                  	end #end do
                  rescue
                  	puts compFile
                  end #end begin
                  end #end if
                  end #end def
                    Dan Rathbun
                    The folder check was meant to enclose everything... but I see you have a empty folder check (which probably cannot happen because an actual file must be selected. BUT...
                    change line 7 to:
                    return unless folder && folder = File.dirname(folder)
                    REMOVE the end (line 9)
                    If you cancel the open panel, NOW your method exits (because the result of UI.openpanel will eval falsely.)
                      Dan Rathbun
                      change the name of THAT 33rd or 34th file to ".OFF" or whatever.
                      Then try again. Just eliminate the bad file scenario.
                        keithswd
                        Thanks for the correction - I see my mistake now. However, the corrected syntax doesn't fix the crash. The folder selection works as it did before and populates the array with all the .skp files in the folder (about 200 for testing purposes), and my message box pops up and correctly reports the number to be processed.
                        However it stops on the 33rd or 34th file no matter what that file is. Each time I run the script, I move the 33/34 successfully modified files out of the folder, so I am never processing the same files twice. I don't know what might be special about the 33/34 mark, but it bails at that point.
                        Some kind of limit appears to be reached? Memory? I've no clue!
                          driven
                          not sure how to do it in ruby but in the osascript/applescript/bash I tend to use, if you don't add a distinct delay point, the process reaches some limit and errors. [That's what happening with the one I posted earlier]
                          maybe adding a puts "done" after definitions.purge_unused will allow a break before opening the next?
                          total stab in the dark
                            Dan Rathbun
                            (1) The iterator block.. use curly braces instead of do ... end
                            So the block can have access to external references, such as definitions
                            (2) Make sure the loading is done before proceeding.
                            (3) perhaps use undo operations ?
                            Try an iterator like:
                              i = 0
                              puts()
                              skpFiles.each { |compFile|
                                model.operation( "Update '#{File.basename(compFile)}'", true )
                                begin
                                  if compDefinition.internal?
                                  else
                                    putc(46) # period char
                                    redo
                                rescue => e
                                  model.abort_operation()
                                  puts()
                                  puts "ERROR saving component file;"
                                  puts "  #{compFile}\n"
                                  puts e.message
                                  puts e.backtrace if $VERBOSE
                                  puts()
                                else
                                  i += 1
                                  if i >= 10
                                    i = 0
                                  model.commit_operation()
                                # each skp file
                              definitions.purge_unused if definitions.length > 0
                              keithswd
                              Thanks again for your help and suggested code. As it stands it does not modify any components. I discovered this is because it seems that even when the component file is loaded successfully, compDefinition.internal? returns false. I can only imagine that this is actually testing whether the component was created within the model or loaded from a file - in which case we are getting the expected result. I commented it out and it runs but... sadly it still bombs out at around 33 components.
                              I really don't want to take up any more of anyone's time - this was just a little project for me to play with but it seems rather trickier than I could have forseen. But I thought you might like an update!
                              def setcompfm
                              return unless result == 6 # Yes
                              i = 0
                                puts()
                                  model.start_operation( "Update '#{File.basename(compFile)}'", true )
                                  begin
                                    #if compDefinition.internal?
                                    #else
                                    #  putc(46) # period char
                                    #  redo
                                    #end
                                  rescue => e
                                    puts()
                                    puts e.message
                                    puts()
                                  else
                                    i += 1
                                    if i >= 10
                                      i = 0
                                  # each skp file
                              end #end def
                                driven
                                Hi Keith,
                                I'm sitting at home recovering from having my ear cut off [and put back on] on Friday.
                                So, glad for the distraction...
                                Anyhow, heres an Automator script that has a safe test action, so won't hurt any files...
                                I missed a filter function, in the first...
                                1. opens each .skp in a 'pre-selected' folder in SU v2013 [should use your version if not]
                                2. opens 'Ruby Console' and 'types' some safe for testing code Sketchup.send_action('viewIso:');Sketchup.send_action('viewZoomExtents:')clicks return
                                3. 'Saves' the changes
                                4. closes 'RC'
                                5. closes the .skp
                                6. loops to the next skp in folder... and repeats
                                You need to open SU first with an empty new drawing... this just saves hassle.
                                Pre-Sellect skps in a Folder.
                                Open the workflow in 'Automator.app' by double clicking after unzipping it.
                                Click Run, watch the show [I like the way it types for me, rather than just inserting it en-masse]
                                If your not using v2013 you'll may need replace the SketchUp.app shown with the one on your path [I know it looks right but I did a trick to avoid using v8, so just swap it if you need to, run it once to see if it fails...]
                                Once your happy the safe version works, edit the applescript with your SU [a 'one-liner' is probably best]
                                try it on a subset, if it runs those, it will run hundreds as long as you adjust the timeout [in loop field] to cover it...
                                Let me know if it works
                                  keithswd
                                  Hi John,
                                  The ear sounds painful! I hope you are recuperating well.
                                  Thanks for the workflow. I have got it to work, with SU loading a script automatically (which defines a function to set the current model behavior as I want it) and I call that function in console. It runs slowly compared to the all-Ruby solution - but at least it processes without crash. So I can send lots of files and leave it to run over lunch, or night!
                                  Many thanks again,
                                  Keith
                                  • 2 / 2
