    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 429.9k Views 80 Watching
      Anton_S
      @wsxqaz said:
      How do you do! This how do localization into Chinese, I can't find the related file that is the correct file
      I guess you want the Chinese translation, right?
      I will add it in the newer version 😄 ❗
        Anton_S
        @cmeed said:
        customise your work area by displaying certain tool pallettes/windows for certain jobs....much like photoshop does
        example
        custom arrangement1 - Job:organic modelling - vertex tools, artisan- are open
        custom arrangement 2 - Job:working in 2d - 2d tools- are open
        just a thought...
        Hmm, so you want to have different project panels? Great Idea!!! 👍 I will have to think about that...
        Maybe this idea may be incorporated into SketchUcation Plugin Store by Rich O Brien. His plugins manager allows you to enable/disable certain plugins. Maybe Rich could add custom arrangement templates. 🎉
        • cmeedC Offline
          cmeed
          I didn't know about richs' I'll take a look.
          cheers
          c
          • U Offline
            unearthed
            Hi Anton,
            Seconding the profiles idea: I'd use a stripped-to-nothing profile for online live-model presentations, and a normal modelling profile.
            Growplan - People ∩ Plants ∩ Place
            windows 7 64b, 4GB RAM, SU 8.0.16846
            Gimp, QGIS, Vectorworks 12, Bricscad 11
            • U Offline
              unearthed
              Thank again - that's a very time-saving plugin, and it doesn't seem to mess up my normal toolbar/menu settings.
                Anton_S
                Great 👍 💚
                  Anton_S
                  A bit better version of window settings. Its now better at updating the window and placed inside window/settings/. Can anyone check if it works on windows 7? If it would then I'll make it as a main update.
                  Edit: See first post to download
                    monmonred
                    this looks great but apparently its not working on sketchup pro 2013. please update both for 32bit and 64bit. thanks 😄
                    +Greatness may be measured on how much we have lost for the betterment of mankind+
                    • CadFatherC Offline
                      CadFather
                      i'm sure Anton can crack it, but i don't think it's that easy - the toolbars are very different from before and they don't hide in bulk that easily. i got a way to make it work, but it is a lot slower than SU8. i'll see if i can complete it and post it while waiting for master Anton.
                        Anton_S
                        You're totally correct CadFather. I fixed everything, but got stuck on the toolbar containers. When I hidden the toolbar containers the viewport window didn't seem to resize itself. I tried working around it, but the results were glitchy. 👊
                          CadFather
                          😒 shirt to say the least... that's what happened to me but this plugin is too good to miss!
                          i had a way (can't find the blessed script now) i could toggle the toolbars by name - though it wasn't as quick as the containers. it relied on Aerilius toolbar editor to compact all the scripts, otherwise there would be too many toolbar names and the toggle took forever...that way the viewport worked ok.
                          well Anton, really hope you will succeed and yet keep sane in the process!
                            Anton_S
                            😆 That's a very complicated way, but great experiment 👍
                            Thanks, I figured the SetWindowPlacement function might do the tick 😍
                            Version 2.0.3 ( May 26, 2013 )
                            • Fixed some functions
                            • Improved set_settings on Win8, I think
                            • Works on SketchUp 2013, though the show/hide toolbar containers is a bit glitchy.
                              Do not add/remove toolbars while the toolbar containers are hidden!
                            See first post to download 😉
                              CadFather
                              %(#BF0000)[phew, Master Anton is Back! 😎 👍 Thank you.]
                              works well on win7 64bit - no lag or quirks so far.
                              couple of thoughts for future dev - what do you think of a button to link the 'others' section (dialogs + floating bars), with toolbar containers - that way with one key you can hide both groups.
                              this might be impossible: removing window strips from floating bars
                              now here's a mission - shrink that flipping floating measurement bar! 😒
                                Anton_S
                                Thanks, I love good news 😍
                                +1
                                Naked toolbars 😆, sure I'll try 👍
                                Hmm, this might be a challenge... Shrink means verticaly, horizontaly, or both?
                                  CadFather
                                  Hi Anton, personally i think the measurements toolbar is way too long (so horizontally), when all i need is the numbers inside it. between me and my laptop we agree, the text part must go! (though in reality this is probably impossible)
                                  i was thinking at least if it didn't have the frame (so vertically), one could leave it floating on the screen and not let it take all that space in a toolbar(!)
                                  but this moaning is nothing new, it's the thing i dislike most. especially now that your ruby works again 😛 - my laptop screen looks it's possible best, and then i see this dark cloud floating around! 😞
                                  i'm glad you got Full Screen working so fast! 👍 ☀
                                  • renderizaR Offline
                                    renderiza
                                    Recently I created a Website using Google Sites and a Blog with Blogger to share some of my interest regarding SketchUp. Apart form talking about my personal work I also want to share other authors plugins and I though yours was good starting point.
                                    I don't have lots of traffic or content since I just began but I hope to post more content soon. Here are the links...
                                    https://sites.google.com/site/renderizastudio/_/rsrc/1371422350032/news/untitledpost/ws-icons.png
                                    Google Sites
                                    Blogger
                                    Thanks,
                                    Renderiza
                                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                      Pherim
                                      Great Plugin! Would have wished for this back in the days of my small 17'' screen... Now with my new 23'' FullHD screen this is not as useful as ist would have been otherwise, but still very nice, for example for exporting images in order to get a better view range.
                                      Works especially great with shortcuts!
                                        Anton_S
                                        It looks great 👍
                                        Hope to see much more on your website and blog ❗
                                        @pherim said:
                                        Great Plugin! Would have wished for this back in the days of my small 17'' screen... Now with my new 23'' FullHD screen this is not as useful as 1st would have been otherwise, but still very nice, for example for exporting images in order to get a better view range
                                        Thanks for the reply. YE, this plugin comes in handy for those with 800x600 screens 😆
                                        • Y Offline
                                          youjirudao
                                          你好:我来自中国,非常好的创意,很帮的插件 👍
                                          在win7-32 SketchUp 2013工具栏、浮动窗口都无法隐藏,SketchUp 8 中很好用,希望解决SketchUp2013中问题,更感谢你的付出和创意造福大家。
                                            Anton_S
                                            Welcome to the forums Youjirudao,
                                            I've tested show/hide floating toolbars on SU8 and SU13, and everything seems to work fine. Can you give me the name of the floating toolbar that doesn't hide? I will try to look into it...
                                            • Anton
                                            欢迎到论坛Youjirudao,
                                            我测试显示/隐藏浮动工具栏上SU8和SU13,一切似乎做工精细。你能不能给我不隐藏浮动工具栏的名称?我会尽量把它看...
                                            • 安东
                                            • 14
                                            • 15
                                            • 5 / 15
