    SketchUp 2013 ;)
    433 Posts 101 Posters 69.2k Views 101 Watching
      @jga said:
      I've just loaded SKUP 2013 to a Win7 64 bit PC & still can't get the file image previews to work in Windows Explorer - can anyone else get theirs to view the files?
      Bring back WinXP & SKUP 7.1!
      That's a known Windows issue, 32bit apps don't get file-image on 64bit PCs.... unless you get MysticThumbs... there are several threads discussing this...
      Here's one http://sketchucation.com/forums/viewtopic.php?p=464044#p464044
        johnsenior1973
        @aerilius said:
        @chiefwoodworker said:
        So far Trimble gets a failing grade from me for its influence on SketchUp.
        In what way does Trimble show a different influence than Google? I don't see any influence.
        There's a famous saying in Germany: "You can't rebuild in 10 years what has been rotting for 40 years" (meant about the previous eastern Germany).
        I think it fits well to SketchUp. The transition to Trimble has cost a lot of time, effort and resources to rebuild infrastructure that is not yet visible to many. A lot of the foundations of SketchUp have been renewed (latest build systems, UI framework) which is the foundation for something new. While the development team has been continuously grown at a rapid rate, I'd expect visible changes to appear through the Extension Warehouse. This is the way through which Trimble and SketchUp give you new tools.
        I remember someone claiming one of the Google releases as one of these "under the hood" improvements that we'd soon be reaping rewards from. I didn't believe it then. I don't believe it now.
        Trimble have rolled out two "new releases" where the major difference has been a new logo and now a new name. Quite frankly the Trimble releases haven't been worth the download bandwidth and the time that it takes to set up plugins and toolbars.
        I don't have ANY faith that Trimble are going to make improvements. Sketchup as it is now is pretty much all SU will ever be.
        • N Offline
          numerobis
          but... no need for a 64bit version... ๐Ÿ˜†
          • pbacotP Offline
            @archheni said:
            I'm simply speechless. Do they really believe that the majority of Pro users are willing to pay for this "maintenance/ bugfix" update!?
            For the new feature of the customizable toolbar - this has been possible in the Mac version a long time ago already incl. for 3rd party tools and ruby plugins. But now it can only be customized with native tools(!). Every restart will wipe out all non-native plugins and tools.. Sorry, but this is a step back and not a new feature! Now given the speedy development of the past, one tends to assume that it might get re-addressed again as a "new feature" in SU2014..
            Does this mean no customizable toolbar (Just native tools is as good as none). The toolbars and windows in both SU and LO are the worse in any program I've seen. Who would purposely create such a mess? Now they took out the only thing that works. Before I say more... ๐Ÿ˜’
            • pugz1983P Offline
              pugz1983
              Hi Everybody,
              I've been reading the comments here and I too am disapointed with the new release.
              The thing i'm not sure of is if it's allowed to keep using previous free versions for commercial use?
              Greetings Twan
                altab
                What I am worried is not the lack of features but the changes on things that were already there. For example before you could use free license for commercial use and now you can't?... ๐Ÿ˜ข .
                Trimble have promised that there would be always a free version, they keep their promise but with this Important change (I'll still use an older version of GOOGLE Sketchup...thanks to all rubyscripters and Sketchucation)
                It is certainly a Marketing decision but "Sketchup2013/Make" seems similar to Autodesk products name ( strange considering that Sketchup has influenced some of the Autodesk products )
                  Hi Twan,
                  In my opinion, you can go ahead and use SU 6, 7 and 8 for commercial purposes, too. The new TOS is about "SketchUp Make" - which non of the above are called. ๐Ÿ˜‰
                  Edit: found this in the new SU 2013 FAQ (bolded by me):
                  As with all of our previous releases, we donโ€™t require you to update to a new version of SketchUp if you donโ€™t want to. But when we move on to a new release of SketchUp, we very rarely (read: almost never) issue updates or fixes for older versions of SketchUp. Youโ€™re welcome to continue using the version of SketchUp you have today (for what you use it for today); we just offer less (or no) support for it going forward.
                    (say I make a simple copy / past between the Folder Plugins )
                    That's what I did - and I started to play with the free version first, too.
                    Be careful not to overwrite any native SU files in the Plugins folder however.
                      Does a plugin for the V6, 7, 8 free is compatible to the 2013 free or I must reload it with the new system?
                      so some thousand ๐Ÿ˜„
                      (say I make a simple copy / past between the Folders Plugins )
                        And that is working ? ๐Ÿ˜„
                          More or less. ๐Ÿ˜‰
                            Aerilius
                            Inline-reply: And yes, I mean not hobbyist scripts but Trimble extensions. Why should not Trimble add their tools via their own API (how a well-architectured software is supposed to work)?
                            And: A multi-line Ruby console with unit tests has been added by the SketchUp team, whether you want it to be true or not.
                              Thank for this mitigated answer! ๐Ÿ˜„
                              • KrisidiousK Offline
                                Krisidious
                                Yeah they say not to do it but I'm lazy like that. And I enjoy breaking things.
                                Revizto didn't migrate properly, They're fixing it now.
                                Jim's old custom toolbar plugin doesn't work.
                                Extrusion tools supposedly didn't work but mine came over fine, I updated it like TIG said anyway.
                                I had to open and close sketchup after plugins were copied over and I had to checkmark plugins twice to make sure they popped up.
                                I have of course not used all my plugins though...
                                By: Kristoff Rand
                                  Well, Jim's custom toolbars plugin does not seem to work. I have not tested all my plugins but what I tested do work. Fredo's Round Corner (on my Win 8 system) only works if I set SU to run as administrator - but then it works.
                                  But why are you interested so much, Pilou? You'll stick to version 6 anyway, won't you? ๐Ÿ˜„
                                    Krisidious
                                    Another kool small feature of SU 2013 is that when you click off of SU, like on your desktop, all of your toolbars minimize so you can see what you're doing. Then when you click back on the main SU window they pop back up. Nice.
                                    By: Kristoff Rand
                                    • F Offline
                                      frv
                                      This is what Hitler said about the Adobe license change recently;
                                      http://www.youtube.com/watch?feature=player_embedded&v=67Iw9q2X9cU
                                      So, whatever the rage I am expecting most here will upgrade, and the cost for a pro upgrade is rather "manageable".
                                      I have a feeling that like the first OSX before the upgrade is just minor when looking at the end user experience. But maybe, and I hope so, more fundamental in terms of the underlaying code. Sketchup has served us well but sooner or later something needs to change more radically to keep up with the neighbors. Sketchup is too slow, too basic to stay were its at.
                                      A positive way to think about this upgrade is the idea that things are changing "under the hood". The team might be readying Sketchup for real and more CAD directed development later on. Lets hope so. I have a feeling some insiders, more involved and knowledgable people do point in that direction.
                                      I am not expecting a makeover for the suggested upgrade price. As an OSX user I find the material panel is no longer workable compared to any of the competition. It looks to me as if the development team at Trimble have never assigned a single material in a file with over 15 materials on an OSX system. If they had they would have fixed it or warn potential buyers that the panel is "under construction". With this in mind I feel very much like most of the posters disappointed about SU2013. I wish development would move on finally with Sketchup itself and drag itself out of the different alleys it seems to get stuck (layout, google earth) .
                                      Francois
                                      • W Offline
                                        wyatt
                                        @wyatt said:
                                        I haven't seen any discussion regarding the cost to skip 2013 and upgrade from SketchUp Pro 8 to SketchUp Pro 2014. Will it be $95 or would one have to buy another full $590 license to skip a release cycle?
                                        The upgrade from SketchUp Pro 8 to SketchUp Pro 2013 is $95 plus state tax.
                                        Sorry, but that wasn't my question. I want to know what to expect to pay if I skip 2013 and go directly from 8 to 2014. Would I pay an upgrade fee or whole new license fee?
                                          dirkkkk
                                          Cool new site, interesting the sort of appstore for te plugins ๐Ÿ˜„
                                          bummer whit the buttons on the new sketchup version.. I would have preferd if the icons would stay the same.
                                          Greetingz
                                          Dirk
                                            Krisidious
                                            $590.00 US
                                            By: Kristoff Rand
                                            • 21
                                            • 22
                                            • 7 / 22
