    About importing a pic
    3 Posts 3 Posters 231 Views 3 Watching
      absolutebeginner
      is it possible to import a .jpg file, then to cut off a face from the photo and then make it a component?
        What do you mean by "cut off a face"?
        You can import a JPG as a texture and apply it to a face. Then you can make the textured face a component. that's how all of the textures in SketchUp work.
          If you mean. is it possible to import a photograph of a person?
          Yes.Make a Rectangle for this purpose.
          Import the image-file as a Textured material and apply it to a front of the Rectangle
          If you further mean, can I cut out the "person's face" and make it a component?
          Yes.
          Zoom into the image and draw around the edges of the part[s] you want to keep with lines - try the freehand tool...
          Once you have a complete loop around the "person's face" use the Erase tool to remove the unwanted Edges around the rest of the Rectangle.
          Now you have the "person's face" as a 2d object using the image.
          You could give it some thickness using PushPull.
          Select it [x3-click] and use the Make Component tool...
          You now have a Component that is a person's face
