    Export DWG taking too long - URGENT
    17 Posts 11 Posters 18.1k Views 11 Watching
      syits
      fernanda, what happened to you on that presentation? πŸ˜„
      now i'm facing the same problem πŸ˜„ and i'm already freaking out.. i think my computer is too slow 😒
      • P
        povoom
        I know this was an old post but all reply was not helpful.
        • GaieusG
          Ah well, since Fernanda did not come back with any more usable info (like an skp file for instance), "help" had to stop where info stopped.
          Thanks for your interest though. πŸ˜‰
            amis
            I got the same problem. 2d-export takes very long time. I tried to copy some components into new file and make 2d-export, so it passed much faster. Here's Model Info:
            Edges 410152
            Faces 148372
            Components 1542
            Groups 438
            Section Cuts 1
            Layers 14
            Materials 35
            Size: 14 926 670 bytes
            What may be wrong with my file (settings)?
            • jim smithJ
              jim smith
              I have the same problem with a small church community center (designed for the island of Roatan Honduras, see attached scene with model info) I was using the model to generate DWG elevation files and it just would not work. left it overnight and still no notice of completion. Just too many edges and faces!!
              The killer I think is the french door/shutter component. It was just what I needed for this Caribbean chapel, but really bloated the model. If I take the shutters out it exports quickly. I stripped the model of all people, interior elements that don't show, backdrops etc. and left the shutters (which I probably could have drawn in autocad more quickly). The export time "reduced" to 2/3 hours .per elevation It is easy to get carried away with such detail. My work around was to just set it to export and go have dinner or work on something else while the elevations crank out.
              If nothing else, it was a good learning experience. πŸ˜†
              "Out of clutter find simplicity,
              from discord find harmony,
              In the middle of difficulty lies opportunity"
              Albert Einstein
              • olisheaO
                olishea
                seems excessive 2-3 hours for an ele?
                oli
                • DanielD
                  Daniel
                  Could this be a problem with the computer itself (graphics card, insufficient memory)? Jim's model doesn't look that complicated. I agree with OIliver; 2-3 hours seems too much.
                  My avatar is an anachronism.
                  • jim smithJ
                    jim smith
                    The model size is deceptive, checks in at 31 MB with 2.2M edges. The computer is fairly powerful - ASUS laptop with core i7, 8 GB ram, nvida gtx 560m 2GB. I get a jpeg in a short time, just forever on the DWG
                    Albert Einstein
                    • K
                      kaas
                      ..... I get a jpeg in a short time, just forever on the DWG
                      Just an idea but have you tried exporting the 2d elevation in Layout instead of Sketchup?
                      • KrisidiousK
                        Krisidious
                        Something tiny has tons of detail... I suggest using Goldilocks 2.0 to find the heavy parts of the model.
                        By: Kristoff Rand
                        • jim smithJ
                          jim smith
                          have not tried but will give it a shot---thanks
                          Didn't think about Goldilocks, but will give it try.
                          This is a :pro bono" project and I work on it in spurts in between the other jobs, so as soon as I can get back to it I will post results.
                          Thanks for the advice.
                          Albert Einstein
                          • P
                            perinicola
                            I've the same problem here, and try everything... I'll say only that being unable to have a vectorial dxf in houars and getting a 5200pixels' jpg in 5 second means only one thing: something is messed up with the exporter.
