    Learning to Render (using Twilight)
    52 Posts 9 Posters 7.1k Views 9 Watching
    • BoxB Offline
      Excellent John, thanks for letting me know.
      • olisheaO Offline
        olishea
        1000x better. Great image too.
        Looks great on my mac. Not like anyone cares. I'm counting down the days til I get a real computer!! Sick to death of mac. πŸ˜„
        If you're looking for crit I suggest much more reflection to the wood textures. Gives a bit more oomph!
        oli
        • BoxB Offline
          Thanks Oli, I know what you mean about the wood, but I'm still getting my head around the glass.
          • olisheaO Offline
            olishea
            Looks pretty damn good to me. With Twilight, I have found default glass material is not reflective enough. If you increase IOR you get a better result IMO. A subtle bumpmap also works well; you can bump any flat colour by applying the bumpmap texture to your window and then link the bump and unlink the texture, then apply template as normal. You can use this to bump a flat colour, good for adding 'scratchmaps' to metal and undulations to stained glass etc.
            oli
            • BoxB Offline
              I have to admit I still haven't worked out what a bump map really is. I will get there I promise.
              I'm happy slowly working things out, doin a bit of reading and listening to others advice, I'll get there, it sticks better that way for me.
              In the mean time I'll drop this one in here too, you've probably already seen it from woodwork, but I like to have a bit of a chronology going on.
              • olisheaO Offline
                olishea
                i hope you dont mind, i just modified the levels. what are the circles on the wall?
                for wood try using Plastic>Satin template or shiny. Great scene!!
                oli
                • BoxB Offline
                  Yeah, the levels are a problem for me. Seems fine then it aint, I've calibrated and things look the same on two screens then render and it goes dark on me, but this is a learning thread so I post em anyway. I've not bothered with any post work either, would rather know how to sweep the floor before I paint the house..
                  The circles on the walls,....mmmm.... well ummm..... think it might be light bouncing around too much. I had set it up using the basic fast settings, then let it run on high while I went shopping. Came back and some twat had been blowing bubbles around in it.
                  • pbacotP Offline
                    Box,
                    Nice glass all around. The proper response is "That's dappled light refracting from objects outside. I worked on that for hours."
                    Good Luck. Peter
                    • BoxB Offline
                      You read my mind Peter. My excuse is I was watching a program about the Rijksmuseum while I was doing it so all those Dutch Masters influenced it.
                      • olisheaO Offline
                        olishea
                        πŸ˜†
                        I have found render previews look lighter than they actually are. As soon as you click save, the saved image goes dark. So good idea to check the saved image and then increase exposure and save again. I get the same issue with Twi and Thea.
                        oli
                        • BoxB Offline
                          I must say the exposure business is driving me nuts, but I'm choosing it ignore it for now as I will be replacing my screens fairly soon, Seems no matter how well I balance/calibrate these they are still very different.
                          As I will be relocating across the world again soon I will wait till then to replace them.
                          I worked out what the circles are, reflections from the distorted glass. I had lights in all the wrong places so they were throwing randomly. I placed lights in what would be the correct place in reality and who would have thunk it but you can sort of control things properly, D'oh.
                          So anyway, with a bit of plastic as you mentioned things look a bit more interesting. I'm sure on some screens this will be dull and on others washed out, but it is here anyway.
                            jpalm32
                            @olishea said:
                            :lol:
                            I second that! Took awhile to catch that for me though.
                              jpalm32
                              Now that is nice , but I really don't like floor texture at all.
                              • BoxB Offline
                                I agree on the floor John and that highlights why I was reluctant to learn rendering.
                                Each little imperfection becomes a glaring error.
                                It's not a criticism of your comment it's just the nature of the beast. You concentrate on tiny details of something and ignore the unimportant, and it's the unimportant that everyone notices.
                                I started this render to get an understanding of how the curved glass would work, throw in a few bits to make it interesting and I find myself trying to get the chess set to show up and then add some gold leaf to the secretaire oh and the window frame looks crap, hang on that's changed now that I have moved the light, should I bump up the lights inside the cabinet ................
                                Which is why I'm happy to post them, I'm content to show my flaws, errors and frustrations, it is a WIP thread after all, and I've never been afraid to look like a loon.
                                Thanks for the comments, I need them all.
                                • olisheaO Offline
                                  olishea
                                  Now that looks a million times better!! I'd say exposure is bang on there. It really is a great scene and your glass models are fantastic. πŸ‘ Which preset are you using?
                                  This frustrated me massively when I first started rendering. "Look at the building, not the crappy 2D trees I used!!" πŸ˜†
                                  It's because you are getting very close to photoreal. In a NPR image nobody cares about a repeating texture, but with a photographic render you can spot things a mile off. As time goes by your texture library will become condensed with non-repeating high res textures for example. Renders really do reveal every detail you have modelled.
                                  The materials are looking great, much more dynamic image now. After some time you'll be able to set up an interior's materials within a couple of mins. I have favourite settings for steel, wood, glass etc, they become burned in your brain!
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    I believe it's so there's more flexibility for post-processing. You can improve an underexposed image but an overexposed image is pretty much useless. In the words of Kwistenbiebel (the legend).
                                    oli
                                      jpalm32
                                      Oli, what is the purpose of the no shadow option for glass in Twilight?
                                      • massimoM Offline
                                        massimo Moderator
                                        -"architectural glass-->no shadow" template is a thin glass (no refractions) and you can use it on a single face with no thickness;
                                        -"realistic glass" template is a dielectric glass with refractions and need thickness in order to work properly.
                                        In order to understand how templates are made in TWR you can apply some templates to simple models and then export to KT.
                                        Below you can see the differences between the two materials in KT's material editor.
                                        !["architectural glass-->no shadow"](/uploads/imported_attachments/lX83_Cattura.JPG ""architectural glass-->no shadow"")
                                        !["realistic glass-->flint"](/uploads/imported_attachments/Jikd_Cattura_1.JPG ""realistic glass-->flint"")
                                        • BoxB Offline
                                          Thanks Massimo, you cleared up a lot of my D'ohs with that explanation.
                                          • massimoM Offline
                                            massimo Moderator
                                            Glad for that. πŸ˜„
                                            • 2 / 3
