    Learning to Render (using Twilight)
    52 Posts 9 Posters 9.2k Views 9 Watching
    • mitcorbM
      mitcorb
      Hell, they're all great. I am jealous.
      • BoxB
        Well while Rich is off there with his flights of fancy and the Borg Cylinder, I'm stuck here in reality. A broken bevelled leadlite stuck in the workshop corner awaiting repairs.
        I really must sort out the colour balance, brightness etc of my monitors, I have three and these all look totally different on each. Who knows if even one of them is correct.
        • pbacotP
          Regardless of monitors, can't you turn up the exposure or add a light? This whole thread if very interesting. Shows that rendering may come easier to someone who is already an artist. Good work! Is that some sort of beveled / quilted glass in the background. What is that piece?
          • BoxB
            That's sort of what I meant about getting my monitors balance properly. The one I mainly work on is much brighter than the others, so it sort of throws my lighting to crap.
            The "Quilted" one in the background is what is know in the trade as a Convexlite. Very popular in the 60s in Australia. I made that as a tester to see how the distortion works, and how well the shaping shows up. The glass panes are heated so they soften and sag through an opening, this makes a sort of flat bubble with straight edges.
            • olisheaO
              olishea
              Yeah Box, they all look a bit dull or muddy. I think you need to calibrate your rendering monitor as you have said. Loving the work though, with some contrast adjustment and exposure tweaking they'll be gold. Get some more light coming in to see the caustics from the coloured glass, using interior+ preset works best for scenes with refraction and caustics πŸ˜‰
              oli
              • BoxB
                Oli, I've decided everyone else needs to change their settings as mine are obviously perfect. πŸ’š
                  Wow, bubble wrap doors. You should put those on Kickstarter
                  • BoxB
                    They'd certainly add a little something to your rubber room Rich.
                    • BoxB
                      Done a quick calibration of my Monitors.
                      Can anyone tell me if this looks clearer and brighter?
                        jpalm32
                        Yes! Much better!
                        • BoxB
                          Excellent John, thanks for letting me know.
                          • olisheaO
                            olishea
                            1000x better. Great image too.
                            Looks great on my mac. Not like anyone cares. I'm counting down the days til I get a real computer!! Sick to death of mac. πŸ˜„
                            If you're looking for crit I suggest much more reflection to the wood textures. Gives a bit more oomph!
                            oli
                            • BoxB
                              Thanks Oli, I know what you mean about the wood, but I'm still getting my head around the glass.
                              • olisheaO
                                olishea
                                Looks pretty damn good to me. With Twilight, I have found default glass material is not reflective enough. If you increase IOR you get a better result IMO. A subtle bumpmap also works well; you can bump any flat colour by applying the bumpmap texture to your window and then link the bump and unlink the texture, then apply template as normal. You can use this to bump a flat colour, good for adding 'scratchmaps' to metal and undulations to stained glass etc.
                                oli
                                • BoxB
                                  I have to admit I still haven't worked out what a bump map really is. I will get there I promise.
                                  I'm happy slowly working things out, doin a bit of reading and listening to others advice, I'll get there, it sticks better that way for me.
                                  In the mean time I'll drop this one in here too, you've probably already seen it from woodwork, but I like to have a bit of a chronology going on.
                                  • olisheaO
                                    olishea
                                    i hope you dont mind, i just modified the levels. what are the circles on the wall?
                                    for wood try using Plastic>Satin template or shiny. Great scene!!
                                    oli
                                    • BoxB
                                      Yeah, the levels are a problem for me. Seems fine then it aint, I've calibrated and things look the same on two screens then render and it goes dark on me, but this is a learning thread so I post em anyway. I've not bothered with any post work either, would rather know how to sweep the floor before I paint the house..
                                      The circles on the walls,....mmmm.... well ummm..... think it might be light bouncing around too much. I had set it up using the basic fast settings, then let it run on high while I went shopping. Came back and some twat had been blowing bubbles around in it.
                                      • pbacotP
                                        Box,
                                        Nice glass all around. The proper response is "That's dappled light refracting from objects outside. I worked on that for hours."
                                        Good Luck. Peter
                                        • BoxB
                                          You read my mind Peter. My excuse is I was watching a program about the Rijksmuseum while I was doing it so all those Dutch Masters influenced it.
                                          • olisheaO
                                            olishea
                                            πŸ˜†
                                            I have found render previews look lighter than they actually are. As soon as you click save, the saved image goes dark. So good idea to check the saved image and then increase exposure and save again. I get the same issue with Twi and Thea.
                                            oli
                                            • 2 / 3
