    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
    • gillesG
      gilles
      If I add a vertical line in the group it works.
      Good to know.
        Here's my update http://sketchucation.com/forums/viewtopic.php?p=36127#p36127
        The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1...
        Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
        • gillesG
          gilles
          Works great, thanks a lot TIG, have a sunny day.
            matt.gordon320
            Thanks! This is awesome!
            • L
              litounba
              Thanks Chris,Thanks Chris.
              • guanjinG
                guanjin
                New version, can not be achieved on the sphere deformation
                  But did the old version ?
                  There is little difference with this update !
                  How are you trying to deform a sphere ??
                  • guanjinG
                    guanjin
                    Sorry, operational errors, thank TIG
                    • E
                      eshertoding
                      i can't find the "update ffd" after i move the point and close grup
                      can't anyone explain me?
                      • L
                        libinhui
                        thank you!
                        • T
                          tootsiejo
                          Hi i can't see the SketchyFFD in my SKP8. it doesnt appear. how do you really install it? is there a tool? it doesnt install when i put it in the plugins folder
                            Assuming you have indeed installed the .rb file into the Plugins folder and restarted SketchUp the tool runs from items in the right-click context-menu 'FFD...' if you have a suitable selection [group etc]...
                            Please read the tool's instructions in the first page...
                              DaddyDDesign
                              Hello I am somewhat new to sketchup and am having a bit of trouble with the "open control points group " step of the process. After the object has the control points around it I cant seem to snap to any of them, when I click the cursor just starts to create a selection box. I'm sure I'm missing something trivial, any help would be appreciated.
                              Thanks,
                              Dave
                                You need to open the group to move the guide-points [aka cpoints] etc.
                                You should be able to double lick on one of them to open the group.
                                Failing that, use the Outliner to find it and double-click on the named entry in the Outliner dialog, it will then open to edit.
                                To close an edit of a group [or component] click away from it in empty space, or use the right-click context-menu item to close it [or the equivalent Edit menu item]...
                                • N
                                  nguyenanhducarc
                                  THank you!
                                  i love you.! ♥
                                    jemoto
                                    Hi all,
                                    I struggle a bit with this plugin; after manipulating the control points and closing the group, I cannot see an "Update FFD" menu item. I believe an earlier poster had the same issue. Can anyone help? Thanks.
                                    • john2J
                                      john2
                                      @jemoto said:
                                      Hi all,
                                      Ditto ❗ ❗ I am also facing the same problem. I just installed and tried to use this plugin.
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                      • P
                                        PeterF
                                        I am having the same problem. I have tried installing every version of the script and there is no 'Update FFD' menu button. The other FFD submenu is there though. I'm using Sketchup Make 2015. Has anyone solved this problem?
                                          Install the latest version.
                                          Then, at the risk of déjà vu read: http://sketchucation.com/forums/viewtopic.php?p=485421#p485421
                                          It all works from the context-menu - given a suitable selection...
                                          But remember that it is an old creaky plugin, from way back yore...
                                          • P
                                            PeterF
                                            Thanks for the reply. I have tried installing every version and none of them have that button. The rest of the submenu is there like I said, but when you adjust the control points, nothing happens and there is no update button.
                                            Is there a newer plugin that works better than this then? I haven't found another that can twist and warp organic shapes like this one is supposed to.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 16 / 21
