    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 484.9k Views 153 Watching
    • LanaL Offline
      Lana
      just have the best here . thank you . 😍
      • I Offline
        itscabbage
        Erm, i'm new here. i have sketchup 8 and i've put this ruby into the plugins folder with all the other rubys, but i can't find out how to use this in sketchup?
        • mitcorbM Offline
          mitcorb
          Hi, itscabbage:
          I would highly recommend reading through the entire series of pages in this thread. Among the pages are animations, visuals etc. that can provide information on how to use the tool. If you are unable to activate it, perhaps you should check to see if it is in the proper folder. This is dependent on whether you are using Windows or Mac.
          FFD does take a little practice.
          And, if you haven't already done so, update your profile. This will enable helpers to determine specific solutions, especially with regard to operating systems.
          • gillesG Offline
            gilles
            For some reason, only the first version works for me.
            I set NxN
            width=11
            depth=11
            height=1
            subdivise=false
            First version everything is OK, scale move rotate...
            Second version, nothing moves (see ruby report)
            Tig's version, trying to move the original group just disappear? 😲 no console report.
            Any idea?
            WARNING: make_unique is a deprecated methodof Sketchup:Group Error: #<NoMethodError: undefined method*' for nil:NilClass>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:453:in calcBernstein' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:214:in initFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:213:in upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:213:in initFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:211:in upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:211:in initFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:209:in upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:209:in initFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:200:in each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:200:in initFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:151:in startFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:20 Error: #<NoMethodError: undefined method []' for nil:NilClass>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253:in applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in each'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in each'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:423:in analizeLattice'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:163:in updateFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:84:in onChangeEntity'
            Error: #<NoMethodError: undefined method []' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253:in applyMultipleFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in applyMultipleFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in applyMultipleFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:423:in analizeLattice' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:163:in updateFFD'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:84:in onChangeEntity' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253
            Sans titre.skp
              I made the adjusted version because the older versions were all causing issues, clashes with other scripts etc, the observer was very flaky...
              My version works fine for me when tested using your settings, although I don't fully understand the 'moving the group...disappear' issue 😕 what disappears ? If you move the group away from the guides it will deform differently...
              You can only have one set of FFD guide-points at a time, so is this your issue ?
              The 'second' version had the most fails so I'd expect the litany of error messages...
              • gillesG Offline
                gilles
                I set NxN parameters and clicking ok the group disappears, it is still in the outliner but nowhere in the model.
                • gillesG Offline
                  gilles
                  I also try with only SketchyFFD.rb in plugins folder, same result.
                  SU 8.0.14345
                    It works fine for me with z=1 set, provided that the geometry has some 3d-ness.
                    If I draw a grid 10x10 as a flat 2d group it does then fail !?
                    Not having written the original code [I just fixed some known issues] I am unclear why...
                    Adding a short vertical line to the grouped mesh fixes it... Capture.PNG I'll check though the code and see if I can trap for this...
                    • gillesG Offline
                      gilles
                      If I add a vertical line in the group it works.
                      Good to know.
                        Here's my update http://sketchucation.com/forums/viewtopic.php?p=36127#p36127
                        The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1...
                        Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
                        • gillesG Offline
                          gilles
                          Works great, thanks a lot TIG, have a sunny day.
                            matt.gordon320
                            Thanks! This is awesome!
                              litounba
                              Thanks Chris,Thanks Chris.
                              • guanjinG Offline
                                guanjin
                                New version, can not be achieved on the sphere deformation
                                  But did the old version ?
                                  There is little difference with this update !
                                  How are you trying to deform a sphere ??
                                  • guanjinG Offline
                                    guanjin
                                    Sorry, operational errors, thank TIG
                                    • E Offline
                                      eshertoding
                                      i can't find the "update ffd" after i move the point and close grup
                                      can't anyone explain me?
                                        libinhui
                                        thank you!
                                          tootsiejo
                                          Hi i can't see the SketchyFFD in my SKP8. it doesnt appear. how do you really install it? is there a tool? it doesnt install when i put it in the plugins folder
                                            Assuming you have indeed installed the .rb file into the Plugins folder and restarted SketchUp the tool runs from items in the right-click context-menu 'FFD...' if you have a suitable selection [group etc]...
                                            Please read the tool's instructions in the first page...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 16 / 21
