    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 480.4k Views 153 Watching
    • guanjinG Offline
      guanjin
      @tig said:
      @guanjin said:
      @tig said:
      Here's my update http://sketchucation.com/forums/viewtopic.php?p=36127#p36127
      The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1...
      Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
      New version, can not be achieved on the sphere deformation
      But did the old version ?
      There is little difference with this update !
      How are you trying to deform a sphere ??
      Sorry, operational errors, thank TIG
      • E Offline
        eshertoding
        i can't find the "update ffd" after i move the point and close grup
        can't anyone explain me?
          libinhui
          thank you!
            tootsiejo
            Hi i can't see the SketchyFFD in my SKP8. it doesnt appear. how do you really install it? is there a tool? it doesnt install when i put it in the plugins folder
              Assuming you have indeed installed the .rb file into the Plugins folder and restarted SketchUp the tool runs from items in the right-click context-menu 'FFD...' if you have a suitable selection [group etc]...
              Please read the tool's instructions in the first page...
                DaddyDDesign
                Hello I am somewhat new to sketchup and am having a bit of trouble with the "open control points group " step of the process. After the object has the control points around it I cant seem to snap to any of them, when I click the cursor just starts to create a selection box. I'm sure I'm missing something trivial, any help would be appreciated.
                Thanks,
                Dave
                  You need to open the group to move the guide-points [aka cpoints] etc.
                  You should be able to double lick on one of them to open the group.
                  Failing that, use the Outliner to find it and double-click on the named entry in the Outliner dialog, it will then open to edit.
                  To close an edit of a group [or component] click away from it in empty space, or use the right-click context-menu item to close it [or the equivalent Edit menu item]...
                  • N Offline
                    nguyenanhducarc
                    THank you!
                    i love you.! β™₯
                      jemoto
                      Hi all,
                      I struggle a bit with this plugin; after manipulating the control points and closing the group, I cannot see an "Update FFD" menu item. I believe an earlier poster had the same issue. Can anyone help? Thanks.
                      • john2J Offline
                        john2
                        @jemoto said:
                        Hi all,
                        Ditto ❗ ❗ I am also facing the same problem. I just installed and tried to use this plugin.
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          PeterF
                          I am having the same problem. I have tried installing every version of the script and there is no 'Update FFD' menu button. The other FFD submenu is there though. I'm using Sketchup Make 2015. Has anyone solved this problem?
                            Install the latest version.
                            Then, at the risk of dΓ©jΓ  vu read: http://sketchucation.com/forums/viewtopic.php?p=485421#p485421
                            It all works from the context-menu - given a suitable selection...
                            But remember that it is an old creaky plugin, from way back yore...
                              PeterF
                              Thanks for the reply. I have tried installing every version and none of them have that button. The rest of the submenu is there like I said, but when you adjust the control points, nothing happens and there is no update button.
                              Is there a newer plugin that works better than this then? I haven't found another that can twist and warp organic shapes like this one is supposed to.
                                Works perfectly in the 2015! πŸ˜„
                                Else you have FredoScale by Fredo6 who makes the same! πŸ˜‰
                                  PeterF
                                  Ok never mind. I installed it again for the 5th time and it works for some reason!
                                  • F Offline
                                    Fabtins
                                    Fantastic tool sir!
                                    I've just started using it. Its working amazingly well but when i open(double click) the control point group to alter control point locations for deformation, the object i'm working on vanishes leaving only the control points behind. The transformation done is taking place but I only see it on the object after i click close group. Can you help me figure what i'm doing wrong? I've attached the screenshots for reference.
                                    step 1
                                    step 2
                                    step 3
                                    step 4
                                    step 5
                                    step 6
                                    step 7
                                      When you edit a Group or Component you can set the rest of the model to be 'hidden', OR not.
                                      See:- View > Component Edit > Hide Rest of Model - toggle it ON/OFF
                                      Sometimes hiding the rest of the model is useful, but sometimes you want to see it - as in this case !
                                        You can also use the Structure function for easy use of this plugin! πŸ˜‰
                                        Click on the image for see animation!
                                          Structure [FR] == Outliner [EN]
                                          πŸ˜‰
                                            muten86
                                            thanks
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 17 / 21
