    "Side by side configuration is incorrect"
    14 Posts 4 Posters 3.1k Views 4 Watching
      d12dozr
      So I installed Sketchup on a new PC today, everything was fine, all my plugins installed no problem.
      [Windows 8, latest version of Sketchup]
      Somewhere along the line, something got messed up and now when I try to start Sketchup I get this message:
      I don't think its any of the plugins, because I renamed the plugins folder to "Plugins1" to disable it, and the problem persists. Searching around online suggests something is messed up with the Visual C++ service packs. I installed several of them to no avail. 😞
      Any other ideas?
      http://goo.gl/f7ooYh
      • KrisidiousK
        Krisidious
        Did you try this?
        (a). Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
        Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
        Type the following command, and then press ENTER:
        sfc /scannow
        The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
        Page not found
        (answers.microsoft.com)
        By: Kristoff Rand
          d12dozr
          Yes, I tried both things suggested in that answer...no luck.
          • KrisidiousK
            Krisidious
            I have you cleared the registry?
            By: Kristoff Rand
              d12dozr
              No, how's that done?
              Edit: I'm not a fan of CCleaner or any of those other programs if that's what you mean.
              • KrisidiousK
                Krisidious
                yeah, that's what I use... They are dangerous. But they do a good job of cleaning up registries. Thomthom has one for sketchup but since this is a new installation that should not be needed. I'm at a loss.
                By: Kristoff Rand
                  They do a good job of messing up stuff. I strong discourage their use!
                    Do you have problems with other RBZ files? Or just this one?
                      d12dozr
                      Sorry for the confusion Thom...this is a separate problem from the one I asked about on Github. This one is more serious...I can't even open Sketchup! 😞
                        d12dozr
                        Uninstall & reinstalling Sketchup appears to have fixed the "Side by Side" problem. Woot! πŸ˜„
                        • KrisidiousK
                          Krisidious
                          Like...
                          By: Kristoff Rand
                            d12dozr
                            Yes!
                            Thanks for pitching in, guys. πŸ‘
                            • KrisidiousK
                              Krisidious
                              I was going to ask that question but assumed you had already been doing that and that i had already been asking you things you had already done.
                              By: Kristoff Rand
                                Slimdog
                                Ccleaner kicks butt.
