    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 71.7k Views 16 Watching
    • renderizaR Offline
      renderiza
      New Update!
      1.0.1 Beta:: 4/19/2013
      * Set:: SCENE - Allows you to set specific scene to any component.
      * ::GOSU:: - Now recognize between URL & SCENES
      Hi, I am excited to release this new update for ::GOSU:: and hope you like it!
      This new tool called Set:: SCENE allows you to link any component to a scene so that when you click it the scene will activate. Hope you find cool uses for this that will help ypu modeling, showcasing and what not.
      Here is New Video explaining the new feature...
      And here is the old video just in case...
      http://www.youtube.com/watch?v=5ZnhhHra7ac
      Cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        New Update GOSU v1.0.2 Beta:: 4/20/2013
        * Set :: Layer - Allows you to set a specific layer to any component.
        * If ::GOSU:: is active and component have layer set to it that layer will be active.
        * If ::GOSU:: is active and you double click component with layer set to it then that layer will be isolated on & off.
        * Tool will be desactivated if 'Escape' key is pressed.
        Hi, this new update add a Layer tool that will hopefully be useful to have.
        Enjoy
          renderiza
          GOSU v1.0.3 Released!
          Please look at first post for details.
          Cheers!
          • iichiversiiI Offline
            iichiversii
            That is fantastic, I'm all over this already, Cheers R
            Bring on the Rain...
              If I well understand (for a PC user) it's a simulation of Microsoft Windows system inside SU ? 😄
              An Windows UI 3D ? 💭
                renderiza
                I am happy that you are using this plugin "iichiversii"! 💚
                GOSU tries to integrate tools that are indeed often used by "Microsoft Windows system" I guess you can say.
                For the Windows UI 3D I guess that you an simulate this experience by using the Set:Scene and create your own UI 3d navigation kind of system.
                Thank you both for the comments...Cheers!
                  iichiversii
                  R I'm very impressed with this and see alot of potentional in it, ideas are flowing, never would of taught of it myself, I applaud you on a great plugin, well done and look forward to updates, seriously, well done.
                    renderiza
                    Thanks its really nice to read compliments like that... 💚
                    New Video for GOSU v1.0.3
                      Litchi
                      Thanks for your present!
                      I would like to know whether we can be completely removed my settings
                      “Pause”is just only pause
                        renderiza
                        Hi, thanks for your comment!
                        Let me see if I understood correctly...
                        You want a tool that removes the Set:: Options that you previously added, more like reset everything button?
                        or
                        You suggesting for the pause button to be removed?
                        Again thanks!
                          Litchi
                          or
                          Again thanks!
                          I'm sorry,My English is not good……
                          I mean if we can add a new function "Reset",remove my settings(Can select all or selected components)
                          thanks! 😄
                            renderiza
                            thanks! 😄
                            I got it now and don't worry English is not my 1rst language as well. 👍
                            This is what I have in mind for next update...
                            Clear:: Selected
                            Clear:: All
                            Will remove settings on all or selected components but before doing so a messege will pop asking "Are you sure?".
                            In the mean time just in case all of the setting values are stored on component is name. You can access that by opening "Entity Info" window. There you can manually remove it or you can use Set:: URL and erase the content there I believe.
                            Cheers!
                              Litchi
                              thanks! 😄
                              Clear:: Selected
                              Clear:: All
                              Cheers!
                              that's great,thanks!
                              I look forward to your new works!
                                renderiza
                                GOSU v1.0.4 Released!
                                1.0.4:: 4/23/2013
                                *Set :: Name - Allows you to set a specific name to any component.
                                *Set :: Empty - Allows you to clear the name of any component.
                                *Reset Button - This will remove the 'Set:: Attributes' of every component
                                Again thanks for the comments & suggestions!
                                  Litchi
                                  [attachment=0:3i6adbg9]<!-- ia0 -->dlg-1.jpg<!-- ia0 -->[/attachment:3i6adbg9]
                                  1.0.4:: 4/23/2013
                                  Thanks,Your work with remarkable efficiency!
                                  Do you agree with me to reprint your files to other forums?
                                  I promise I will retain the original URL and the name of the author
                                  I want to share it with more people
                                  Again thanks !
                                    renderiza
                                    Again thanks !
                                    I will be happy if you shared this with other people on other forums. 👍
                                      TECHDAVE02
                                      Am I right that GOSU will only do 1 function at a time??
                                      If so what about a right click sub menu to choose function???
                                      My pause button is not working
                                      rest works great so far.
                                        renderiza
                                        Gosu can do multiple functions in some cases since it uses the same component name for all "Set::" parameters. The "Set:: Scene" and "Set:: Layer" are the ones that can be repeated with another "Set::" option withoud any issues...Let me give you an example;
                                        Example A
                                        1. Set:: URL = http://www.sketchUcation.com
                                        2. Set:: Scene = http://www.sketchUcation.com
                                        3. Set:: Layer = http://www.sketchUcation.com
                                        ^^When you use ::Gosu:: it will active URL,Scene and Layer at the same time.
                                        Example B
                                        1. Set:: Sound = C:\Users\name\Desktop\folders\audio.wav
                                        2. Set:: Scene = C:\Users\name\Desktop\folders\audio.wav
                                        3. Set:: Layer = C:\Users\name\Desktop\folders\audio.wav
                                        Note: Again notice how Set:: Scene & Set:: Layer can be combine with other "Set::" Options.
                                        This is great idea I will try to add it on next version...thanks!
                                        What the Pause button is supposed to do is deactivate tool be leave the web dlg window instead to closing it like the close button do. If this does not work try hitting 'Esc' key or Select another tool like the Select tool. I will see if I can find the issue...thanks.
                                        Cheers!
                                          smicha
                                          I just watched a video tutorial - your plugin is great!
                                            renderiza
                                            Thank you sir for does kind words! 👍
                                            • 1 / 4
