    Batch Open-Process-Save
    15 Posts 5 Posters 967 Views 5 Watching
    • CadFatherC Offline
      CadFather
      anyone up to make a script that opens sequentially all the skp files in a folder, sets a style, puts the model to front view, fits the model to screen, purges all unused and then saves until all files are done?
      what i'm trying to do is consolidate my components library and have the thumbnails work for all files.
      (i can make a reasonable paypal donation)
        We've already had a PM exchange about this...
        I'll see if I have anything 'off-the-peg' that you can modify to suit what you want...
        Watch your PMs...
          CadFather
          Thanks TIG that would be great.. ..if i can get AE to put it together ; )
            A simple rb solution has been PMd.
            PM feedback please...
              glro
              This plugin might be helpful
              http://sketchucation.com/forums/viewtopic.php?t=48215
                CadFather
                thanks Giro, i know that one - this is to process sketchup files though and not images.
                  glro
                  skp modification and save copy
                  I have been trying for a while to write a plugin that would do what you say
                  TIG's helped me with some code, and i wrote this plugin "skp_recap.rb"
                  There is a problem, though: i don't find the way to overwrite the file with the modifications the plugin makes, so i have to save it with a different name: I added "bis" to the name of the file
                  nom_model = model.title
                  #constitue le nom du modele
                  nom_model = rep_path + "/" + nom_model + "bis"+".skp"
                  puts nom_model
                  #sauve
                  model.save nom_model
                  maybe somebody will find a clever way to avoid the "bis" trick
                    glro
                    it seems i am not the only one with this problem for saving a currently opened file with the same name
                    File Not Found
                    (www.smustard.com)
                    maybe a sketchup bug...
                      CadFather
                      thanks Giro, did you see this?
                      http://sketchucation.com/forums/viewtopic.php?f=180&t=51357
                      anyways, i'm pretty sure master TIG will probably come up with something fab yet again..
                      • gullfoG Offline
                        gullfo
                        @glro said:
                        [attachment=0]maybe somebody will find a clever way to avoid the "bis" trick
                        maybe the .save() method without a name simple saves the current model? the bug might be that calling .save() with the name causes it to assume "save as" and therefore cannot because the model is open (and a bug) causes it not to revert to "save" (like many programs like Office for example) when the current file and "new" file are the same.
                        of course another option is keep the name and simply place the output files into another folder so after the batch processing is completed you can simply move those files into the existing folder (overwriting) or whatever it is you're trying to achieve.
                        Glenn
                        http://www.runnel.com
                          The issue is that
                          model.save(name)
                          will return ' true', BUT it doesn't actually save the model if that ' name' is an open SKP - either as another SKP or it's the current-model's SKP.
                          To save a model you need to use
                          Sketchup.send_action("saveDocument:")
                          Then use other API methods to open other files etc...
                            glro
                            @tig said:
                            The issue is that
                            model.save(name)
                            yes
                            i modified the previous plugin, and now the file is saved
                            thank you TIG
                            still 2 problems i can't solve:
                            disable perspective (Sketchup.send_action("viewPerspective:" puts it on and then off...)
                            wait until the file is saved (i added a messagebox, you have to click between each file)
                            TIG gave (again) a solution for the second problem
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=39304
                            but i couldn't make it work on my computer
                            front, purge and save skps in a folder
                              matt.gordon320
                              Hi guys, is there a (relatively) easy way to edit a script like this to batch down-save models to a previous version (no changes made, only save)?
                                The save_as_version is not accessible in the current API [it might one day happen in a newer version of SketchUp...]
                                Jim Foltz wrote something for PC [using a .so] which opens the save_as dialog and mimics keystrokes to change to the previous version.
                                You could use some of its ideas to do this for say v2013 back to v8 ?
                                http://sketchucation.com/forums/viewtopic.php?p=294768#p294768
                                Links to his site...
                                  matt.gordon320
                                  Well that'll help to explain why I had such trouble trying to find it in the API docs! Thanks TIG, I'll look into that one!
