    [Plugin] Solid Inspector
    303 Posts 99 Posters 356.5k Views 98 Watching
      rbedoya
      Hi Thom,
      I installed the Solid Inspector into my mac, in the plugins, but when i launch SU i get the following
      Error Loading File tt_solid_inspector-1.rb
      no such file to load -- TT_Lib2/core.rb
      what might be the problem?
      • GaieusG
        Please, re-read (or at least read once) the installation instructions and download/install that library this plugin is dependent on.
          rbedoya
          I have installed the library required and i get that error.
            rbedoya
            Here is the library i have installed and the plugin
            TT_Lib2%20-%202.7.1.rbz
              Placing the RBZ file in the plugins folder doesn't work. It's a package that must be installed. Note there's a big difference between RB and RBZ files.
              Follow the installation instructions linked in the red box near the Download button.
                driven
                @rbedoya said:
                Error Loading File**tt_solid_inspector-1**.rb
                is that a copy, or are there two versions?
                on my mac it's **tt_solid_inspector.rb**,
                if so does your TT_Lib2 also a copy i.e. TT_Lib2-1
                if it is, SU won't find it...
                  Jim
                  Rather than implement this as a Tool, I wonder if it makes sense to apply a material to the offending edges and set the style to color by material. That way, I could exit the tool and explore the model at my leisure.
                    Could be added as an option. I'd still want to have an non-modifying inspection method.
                    I had originally planned to try to implement methods to fix various errors - but .. you know Time and all that. πŸ˜•
                    • xiombargX
                      xiombarg
                      Here's are two really handy tips for using this plugin, especially on complex models:
                      1. Set the solid inspector as a shortcut key so you don't have to keep using the drop down menu. You can waste half your life away using drop down menus to access frequently used tools.
                      and combined with this...
                      1. Use Jim's "Custom Toolbar" plugin and then go to the VIEW drop down menu, then go to TOOLBARS and choose "Options". Having these buttons (or setting shortcut keys) for "Show Hidden Geometry" and for "Hide Rest of Model" is indispensable for fixing complex models into solids. It will save you A LOT of time.
                        scott216
                        I'm having trouble using this plug-in. I can't get it to turn off most of the time. I'll go go the tools drop down menu and click on solid inspector to hoping to uncheck it, but it doesn't uncheck. How do I turn this off. I'm using sketchup 8.0.16845 on Mac 10.7.5
                          You turn it off by picking another tool. Since the next thing you'll likely do is open the component/group for editing to fix the problem, you could hit the space bar to get the Select tool. You could also right click and choose Edit Component and then choose the tool you need which might be the Eraser or the Select tool. Just like any other tool in SketchUp, it is active until you choose another tool.
                          • JpacJ
                            Jpac
                            Thom,
                            This is an excellent plugin and one that is a part of my 3D printing workflow. Thank you for the time and know-how you put into making it!
                            http://sketchup4sitedesign.wordpress.com/
                              πŸ˜„
                              • G
                                guilherme1978
                                Very nice, thanks.
                                • ExxosE
                                  Exxos
                                  This has saved me so much headache. I am using joint push pull on a very large ellipsoidal starship hull to make panel lines and now I can find the tiny holes quickly. Thank you.
                                  • K
                                    kurtklingbeil
                                    I am having trouble getting solid inspector going.
                                    I noticed the message about needing TTlib2, and manually installed TTlib2.8.3
                                    When Sketchup 8 starts, I get the following massages:
                                    Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
                                    no such file to load -- C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/gl_image.rb
                                    no such file to load -- C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File tt_export.rb
                                    no such file to load -- C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/TT_Geom_BezierError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
                                    There is also a LL_Lib2 not installed doo-dad offering to download TTlib2
                                    version 2.8.0. WHen I let it do its thing, and install that version,
                                    same thing.
                                    In some brief poking around, I noticed something about core.rb
                                    and when I open it it says it is compatible with sketchup 7 and untested
                                    with other versions...
                                    What is the scoop? Is SK8 OK? how about SK2013?
                                    How is it that the uninstalled_downloader for 2.8.3 refers to 2.8.0?
                                    What is the "most current" working version?
                                    and like that...
                                    THx
                                      The error messages indicate you've not installed TT_Lib2 correctly. How about showing us a screenshot of your Plugins folder.
                                      This plugin and TT_Lib2 work just fin with SU8 and SU2013 when installed correctly.
                                      • tt_suT
                                        tt_su
                                        Sounds like you might have ended up affected by Windows UAC protection system and some files ended up in Virtual Store.
                                        Navigate to the Plugins folder in Explorer and see if there then is a Compatibility Files button. If there is any files in Virtual Store you should clean them up.
                                        • K
                                          kurtklingbeil
                                          on closer inspection, I see that the error messages all seem to relate to
                                          well, yes indeedy that file is not there
                                          a disk-wide scan for TT_Geom_Bezier finds TT_Geom_Bezier.bundle in the osx folder...
                                          Is there an easy/correct way to force a re-install of TT_lib2?
                                          Directory of c:\Program Files\Google\Google SketchUp 8\Plugins\TT_Lib2\librarie
                                          s\win32
                                          09/12/2013 05:47 PM <DIR> .
                                          09/12/2013 05:47 PM <DIR> ..
                                          01/16/2011 04:31 PM 446 tt_api-readme.txt
                                          01/15/2011 03:26 PM 28,672 tt_api.so
                                          2 File(s) 29,118 bytes
                                          2 Dir(s) 380,049,514,496 bytes free
                                          09/12/2013 05:43 PM <DIR> .
                                          09/12/2013 05:43 PM <DIR> ..
                                          06/28/2013 01:23 PM 3,474 !SketchUcation_loader.rb
                                          01/18/2013 11:30 AM <DIR> cutlist
                                          08/04/2010 01:37 AM 1,535 cutlist.rb
                                          01/09/2012 07:05 PM 1,251 engineeringtoolbox.rb
                                          09/11/2012 04:11 PM <DIR> Examples
                                          08/23/2012 04:02 AM 2,412 examples.rb
                                          06/05/2013 05:42 PM <DIR> HibouScientificSoftwareLibrary
                                          06/05/2013 05:42 PM <DIR> Khamsin
                                          05/31/2013 11:08 AM 1,755 khamsin.rb
                                          02/07/2012 03:34 PM <DIR> ldd
                                          01/25/2012 07:41 PM 11,274 ldd.rbs
                                          09/11/2012 04:11 PM <DIR> Ocean
                                          08/23/2012 04:02 AM 1,065 ocean_extension.rb
                                          09/12/2013 03:34 PM <DIR> SketchUcation
                                          04/01/2013 06:50 PM 17,857 TIG-solidsolver.rb
                                          01/19/2012 04:36 PM 2,983 tt_export.rb
                                          09/12/2013 05:47 PM <DIR> TT_Lib2
                                          04/19/2013 01:31 PM 1,876 TT_Lib2.rb
                                          09/12/2013 03:36 PM <DIR> tt_solid_inspector
                                          04/25/2013 02:00 PM 1,614 tt_solid_inspector.rb
                                          09/11/2012 04:11 PM <DIR> Utilities
                                          08/23/2012 04:02 AM 1,175 utilities.rb
                                          01/30/2012 12:16 PM 19,578 VolumeCalculator21.rb
                                          13 File(s) 67,849 bytes
                                          12 Dir(s) 380,050,038,784 bytes free
                                          01/18/2013 12:29 PM 2,231 arc.rb
                                          02/19/2013 08:00 PM 1,844 attributes.rb
                                          02/19/2013 07:59 PM 8,916 babelfish.rb
                                          04/01/2013 07:46 PM 493 bezier.rb
                                          01/18/2013 12:29 PM 660 binary.rb
                                          01/18/2013 03:28 PM 1,233 boolean_attributes.rb
                                          02/19/2013 07:59 PM 4,304 bounds.rb
                                          01/23/2011 11:31 PM 2,803 CHANGELOG.txt
                                          01/18/2013 12:29 PM 626 color.rb
                                          04/19/2013 12:40 PM 12,092 core.rb
                                          01/18/2013 12:29 PM 8,084 cursor.rb
                                          09/12/2013 05:47 PM <DIR> cursors
                                          01/18/2013 12:29 PM 1,667 debug.rb
                                          01/18/2013 12:29 PM 1,128 deferred_event.rb
                                          01/18/2013 12:29 PM 3,535 definition.rb
                                          01/18/2013 12:29 PM 6,796 dimension.rb
                                          04/03/2013 11:00 AM 2,784 draw_cache.rb
                                          03/25/2013 01:50 PM 16,240 edges.rb
                                          03/25/2013 01:50 PM 4,266 entities.rb
                                          06/05/2013 03:29 PM 88 extension_info.txt
                                          03/25/2013 01:51 PM 3,652 faces.rb
                                          03/25/2013 01:51 PM 6,177 geom3d.rb
                                          03/25/2013 01:30 PM 48,638 gizmo_manipulator.rb
                                          03/25/2013 01:52 PM 18,667 gl_image.rb
                                          03/25/2013 01:32 PM 20,205 gui.rb
                                          03/25/2013 01:33 PM 685 image.rb
                                          03/25/2013 01:56 PM 11,211 inputbox.rb
                                          04/01/2013 08:10 PM 1,936 instance.rb
                                          04/03/2013 10:32 AM 658 integrity_list.dat
                                          03/25/2013 01:35 PM 1,264 javascript.rb
                                          03/25/2013 01:53 PM 2,930 json.rb
                                          01/18/2013 12:29 PM 693 length.rb
                                          09/12/2013 05:47 PM <DIR> libraries
                                          01/18/2013 12:29 PM 3,552 locale.rb
                                          03/25/2013 01:36 PM 6,665 materials.rb
                                          01/18/2013 12:29 PM 1,552 metaclass.rb
                                          03/02/2013 05:17 PM 2,888 modal_wrapper.rb
                                          03/25/2013 01:38 PM 3,980 model.rb
                                          03/25/2013 01:38 PM 3,947 point3d.rb
                                          03/25/2013 01:39 PM 1,758 point3d_ex.rb
                                          02/19/2013 07:57 PM 9,595 profiler.rb
                                          03/25/2013 01:40 PM 4,350 progressbar.rb
                                          03/25/2013 01:40 PM 5,350 ray.rb
                                          08/29/2010 02:43 AM 235 README.txt
                                          03/25/2013 01:40 PM 629 selection.rb
                                          01/18/2013 12:29 PM 2,830 settings.rb
                                          03/25/2013 01:41 PM 2,195 simpletask.rb
                                          03/25/2013 01:42 PM 2,528 sketchup.rb
                                          01/18/2013 12:29 PM 923 system.rb
                                          03/25/2013 01:46 PM 819 toolbarwindow.rb
                                          03/25/2013 01:45 PM 741 toolwindow.rb
                                          01/18/2013 12:29 PM 704 uvq.rb
                                          02/19/2013 07:58 PM 7,201 uv_plane.rb
                                          01/18/2013 12:29 PM 3,782 version.rb
                                          10/11/2011 12:59 PM <DIR> webdialog
                                          01/18/2013 12:29 PM 3,644 webdialog_patch.rb
                                          04/01/2013 07:46 PM 11,220 win32.rb
                                          03/25/2013 01:48 PM 17,093 window.rb
                                          55 File(s) 294,687 bytes
                                          5 Dir(s) 380,050,038,784 bytes free
                                          • tt_suT
                                            tt_su
                                            First of all, check the Virtual Store which I mentioned in my previous post. If there is anything there it is likely to mess things up.
                                            Then, once you have ensured there is no Virtual Store files, then you close all instances of SketchUp and then remove the TT_Lib2 files.
                                            After that you have a clean slate and you can install the RBZ via Preferences > Extensions - or use the Extension Warehouse.
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
