    Exporting Sketchup Camera into other programs (Modo and Vue)
    8 Posts 6 Posters 2.8k Views 6 Watching
      ALFAMAX
      Hi All (Sketchupcationites?)
      I finally got myself registered to this great site. I'm starting a one man Arch Viz studio. I use a number of software that I keep on adding to my workflow. I have Sketchup Pro as my primary modeller and I render in Vray. I also have Vue 9 complete and Modo 501 which I'm still trying to get comfortable with. I want to get all these programs to "play nice" together. The one thing that I still haven't had any luck in resolving is matching the Sketchup camera view in modo and vue. I want to have the flexibility of overlaying the Sketchup lines on the output from these programes. The camera doesn't get exported into modo when using the .obj format. I tried to match the Sketchup camera values and entered them into a modo camera and the view is off even when I match the exact location, focal length etc. The view is off in Vue even when I use the SketchuptoVue plugin. If anyone can offer any assistance regarding this issue, I'd really appreciate it. Thanks
        daarboven
        You can export cameras in the .3ds format (requires pro). Find it under "options" during export
          ALFAMAX
          Thanks for the response daarboven. I've tried the .3ds format. Coming from a 3dmax background, I'm very familiar with it. The problem with this format is that the cameras are facing the wrong direction and you can't see the cameras once I import them into modo. Is there a bug in modo? The 3ds format also has a face import limitation that basically caps my workflow. Textures are missing from the models I import so I have to re-texture them in modo. In modo I like to have my z-axis as the up axis as my preference. In modo the default up axis is the y-axis for some strange reason so every time I import a .3ds file I have to rotate it which is a bit of a drag. The .obj file format doesn't have these issues but it is missing a camera export option. I like rendering in Sketchup using Vray but because Shetchup is a 32bit program it has it's limitations on scene size. I have a 64bit system and I want to take advantage of modo's 64bit rendering speed since it has no limitations. If any one models in sketchup but renders in either modo or vue I would really like to know your workflow. Thanks
          • DanielD Offline
            Daniel
            Cornucopia3D sells the sketchup to vue plugin:
            http://www.cornucopia3d.com/purchase.php?item_id=8911
            I haven't used it myself. Somewhere in the Extensions and Applications forum there is a thread that discusses it.
            My avatar is an anachronism.
            • renderizaR Offline
              renderiza
              I found this plugin that export camera values so that view matches exactly both in SketchUp & Vue.
              http://www.pushpullbar.com/forums/showthread.php?10974-Sketchup-to-Vue-camera
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
              • soloS Offline
                I posted it also on these forums but just cannot find it.
                  Search camera2vue in the plugin store tool
                  Filter camera
                    ALFAMAX
                    I use SketchupPro 8. That plugin doesn't work with this version of Sketchup. On a side note, Solo I've seen some of your working using Vue and I'm very impressed. I tried rendering using Vue and I was unsatisfied with the long render times and poor quality end result therefore I have yet to use it for a commercial project. Can you provide me some do's and don't s when it comes to lighting an exterior scene in Vue. I want decent quality and reasonable render times. I'd really appreciate that. Thanks
