    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 66.8k Views 19 Watching
      mics_54
      Nice blog! You have so many plugins! You now have the dubious distinction of being in my favorites under SU Ruby!
      • KrisidiousK
        Krisidious
        He's addicted to the coding challenge... He cannot resist a challenge.
        By: Kristoff Rand
        • O
          OSN58
          @sdmitch said:
          Please open the Ruby Console and then run the plugin. An error is occurring and this will tell me what it is.
          I have this error
            mwm5053
            Try downloading and installing again you shouldn't be getting that.
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
              mics_54
              LUCKY ME ! 😍
              • T
                trimguy66
                Thanks for all the replies !!
                I uninstalled the plugin, and then reinstalled, by saving to my desktop and then dropping in to my plugins folder. I am still getting the same results.
                I am running Windows 7 / SU 8
                I haven't tried removing all my other plugins, and restarting SU yet.
                I am hoping that the ruby console will shed some light on my problem, before I go through removing all the plugins.
                Thanks,
                Wayne
                  Wayne
                  You have helpfully posted the RC error message BUT you have scrolled it, so the most important lines telling us what has just happened are missing. πŸ˜’
                  Could you recreate the error and post the entire error message again.
                  Once we know what the error says then sdmitch can probably go πŸ’­ and see what to trap/fix...
                  I doubt very much it is a clash - more likely a simply coding error that occurs when particular parameters are chosen for a certain form of face etc... I'd expect it to be relatively easy to fix once the full RC error is known
                    Don't worry about the RC message...
                    I now see that an RC screenshot that was posted earlier shows the error to be in line #433...
                    pts<<p.offset(xa,dx/2).offset(ya,-dy).offset(za,(dx*@tpcnt+0.01)***sign**(v.z))
                    The method ' sign' is not defined in the tool's code and it's not a standard Ruby method either BUT it is defined in DC stuff... so perhaps users with the DC extension loaded will get it working OK anyway... or maybe another tool that not all users have is making it ? No unencrypted script is making it, so it must be an rbs file ?
                    It is only called once in the whole file...
                    The way to find the 'sign' of a value would be work for everyone as:
                    ...*((v.z)<=>0)
                    OR you could add a new method into this tool's code, so if you use it more than once
                    def sign(n=0)
                      return n<=>0
                    Usage: *sign(n)
                    Sdmitch to fix !
                    It's easily sorted...
                    • T
                      trimguy66
                      Tig,
                      Thanks for your response, but I must admit coding is greek to this carpenter, I did attach a shot of the ruby console,scrolled in the proper position, in case it helps any.
                      I also added a shot of my plugin folder, to see if anything in there would help.
                      Thanks for everyone's help
                      Wayne
                        That is the 'sign' error.
                        Which means for some reason you do not have the 'sign' function added to Ruby by some other tool...
                        It's easily fixed by editing the script at line #433.
                        I have PM'd you [and Sdmitch] a working copy...
                        BUT Sdmitch ought to fix it officially and post an update...
                        • sdmitchS
                          sdmitch
                          Sorry about the sign function problem that some have experienced. It never was a problem for me.
                          A new version with TIG's fix has been posted.
                          http://sdmitch.blogspot.com/
                          • T
                            trimguy66
                            Thank You sdmitch and TIG, the updated plugin work perfectly. 😍
                            This place is such a wealth of knowledge and sharing!!!
                            Now off to sdmitch's blog, to check out some of the very cool sounding plugins........
                            Have A Great Day!!!!!
                            Wayne
                              Glad it's fixed. πŸ˜„
                              πŸ˜• I've never come across this ' sign()' method before, although I can confirm that I have it auto-loaded into my Sketchup Ruby, even without DCs loading, and there's no 'sign' of it in any RB scripts I have that I've grepped - so I suspect an unidentified RBS file adds it, and if a user doesn't have that loading then they are screwed...
                              I'd be interested to learn where ' sign()' originates...
                              Meanwhile using the 'comparator' n<=>0 returns either 0, 1 or -1: which, when used with * effectively uses the 'sign' of the number 'n' in a calculation, without passing its real numerical 'value'.
                              • sdmitchS
                                sdmitch
                                I'm really not 100% sure where I found the sign function but I believe it was in the Ruby Console. Apparently I typed something like sign(-5) and it returned -1 so I assumed that it was a common function. I do have Ruby 1.8.6 installed so maybe that's why it works for me.
                                  I too get sign() in the RC... but with a standard SUp-Ruby only installation and DCs etc disabled I still get it.
                                  And it's not deined in any .rb files I have loading...
                                  So I must assume that there a .rbs file loading from somewhere that adds the global method...
                                  The alternative 'standard' way of n<=>0 is easy enough though...
                                  Another one that sometimes trips up scripters is group.definition [which is needed for adding instances of a group into another entities context etc, when 'copying' or 'moving' it to mimic Copy/Cut/Paste_In_Place...] - the method component_instance.definition does return the component's definition and some 3rd party tools add group.definition to the mix... but if you use that method and the recipient of your script hasn't got the other 3rd party script that adds it, then they'll get errors. The 'safe' way is to use group.entities.parent which returns that group's definition properly...
                                  • gullfoG
                                    gullfo
                                    this is a very cool script! 😍 attached are a couple of examples of it in use. couple of things - the header spacing looks like there is overlap. also, after using the tool it's somewhat arbitrary if the dialog comes back or not πŸ˜• in example #1 i'd also tried to use it on a floor and on a ceiling. it's mostly there. in example #2 i tried to use it for a "soffit" and the vertical bits work as expected but the horizontal ones (like #1) are not computing right. this is definitely a great bit of work however it ends!
                                    face 2 frame example 1.skp
                                    face 2 frame example 2.skp
                                    Glenn
                                    http://www.runnel.com
                                    • sdmitchS
                                      sdmitch
                                      Given the fact that the plugin was designed for vertical walls, I'm not surprised that it had a problem with floors and ceilings.
                                      The apparent overlap of the headers is the 3/4" plywood spacer between the headers.
                                      • KrisidiousK
                                        Krisidious
                                        Yes that was my addition... Here in America on the jobs that I've worked we use Plywood in our headers.
                                        http://biytoday.com/header.jpg
                                        By: Kristoff Rand
                                          mics_54
                                          I haven't laminated headers in a decades...energy efficiency dictates 4x10 or 4x12 headers with 2 inches of foam insulation or spray foam on fully sheathed structures.
                                          • KrisidiousK
                                            Krisidious
                                            Rich Boy... 🀣
                                            By: Kristoff Rand
                                            • 2 / 4
