    [Plugin] ImageTrimmer
    364 Posts 58 Posters 337.7k Views 58 Watching
      Works fine for me, so please post all of your Java settings and double-check that JAR files are set to open [execute] with Java...
      The ZIP contains the input/skp/output...
      HamsterWheel%2001.zip
      • eLaCiDE
        eLaCiD
        Java settings :
          The only difference I have is the last item Java Quick Starter is unchecked in my version, BUT I'd not expect that to be an issue...
          Can you run Sketchup as an Admin and see if it helps...
          • eLaCiDE
            eLaCiD
            Nothing new.... same old story 😞
            I tried once again and got just basic file in TrimmedImages folder.
            Then, as you can see, I tried with input in RC, but TrimmedImages folder stay unchanged still only basic image.
            • picky1958P
              picky1958
              [attachment=0:26ynthtl]<!-- ia0 -->RC3.png<!-- ia0 -->[/attachment:26ynthtl]
              I had exactly the same problems. I never got it to work either 😞
                Works fine for me on two PCs and my Mac.
                • eLaCiDE
                  eLaCiD
                  [attachment=0:2sef8osi]<!-- ia0 -->RC3.png<!-- ia0 -->[/attachment:2sef8osi]
                  But somewhere there must be a Catch. I hope so πŸ˜„
                  • eLaCiDE
                    eLaCiD
                    Yes, but the problem is not noticeable when running than when not working πŸ˜„
                    • picky1958P
                      picky1958
                      [attachment=0:2de0bzyz]<!-- ia0 -->RC3.png<!-- ia0 -->[/attachment:2de0bzyz]
                      I gave up on it. I am good with computers but when it comes up to some terms, there is also a language barrier. Some things are hard to find when you get instructions in english and you are hanging around with a PC that only speaks german! πŸ˜‰
                      • eLaCiDE
                        eLaCiD
                        Yes it is a problem. Most people I know have Windows upgrade on its own local language.
                        My knowledge of English is poor, but there's no way for me to upgrade Windows on my PC to local language just for the reason you mention. πŸ˜„
                        As someone said, Hope dies last.
                        To give up is not an option πŸ˜„
                        • eLaCiDE
                          eLaCiD
                          I've been thinking a bit about this problem and the conclusion is as follows
                          When I start Image trimer from SU as I can see in status line
                          there appears one by one dot indicating that Image Trimer works.
                          In folder TrimmedImage shows up a copy of basic image.
                          Contents of files from.ini and to.ini are created with rigt paths what all indicates this part work fine.
                          But after this point, after minute or minute and a half it stops.
                          In folder TrimmedImage there is no files image[Edges].dat and image[Edges].png
                          The main question is, what heppens in that minute, according status line ImageTrimer works something.
                          Does it produce this two files image[Edges].dat and image[Edges].png or not.
                          We have two options
                          1.)
                          Files are produced but sometning has gone wrong and files can not be saved in TrimmerdImage folder
                          2)
                          Files are not produced which brings us back to the question of what then happens in that minute, minute and half.
                          On the other side when EdgeDetector.jar is triggered manualy it produce this two files in folder.
                          When EdgeDetector.jar is trigered inside RC nothing happens.
                            If you try this in the RC
                            UI.openURL("file:///"+"../full/path/to/EdgeDetector.jar")
                            what happens ?
                            • eLaCiDE
                              eLaCiD
                              what happens ?
                              Full path to EdgeDetector.jar is :
                              C:/Program Files/Google/Google SketchUp 8/Plugins/SKMtools/EdgeDetector.jar
                              In this case if this is correct
                              after enter and few seconds I got just this
                              and nothing more
                              Folder TrimmedImage is unchanged.
                                Has it then made the other files in the 'Trimmed' folder ?
                                If so we know it's both runnable and working...
                                Is there a .dat file?
                                This tells Ruby where to draw the edges that are the image's 'perimeter' ?
                                Can you PM a zip of the Trimmed folder including any .dat file to me ?
                                So why isn't it then reading the .dat file? πŸ˜•
                                • eLaCiDE
                                  eLaCiD
                                  Well, we have three situations..
                                  1.)
                                  When I start ImageTrimer from SU then
                                  in files from.ini and to.iniappears correct path
                                  And nothing more.
                                  2.)
                                  When I start manualy by click EdgeDetector.jar
                                  with the condition - there is corect path in files from.ini and to.ini
                                  and condtition - there is image.png inTrimmedImagesfolder
                                  In folder TrimmedImages next to image.pngappears image[Edges].datand image[Edges].png
                                  3.)
                                  When I start EdgeDetector.jarinside RC nothing happens.
                                  Files image[Edges].datand image[Edges].png doesn't appear in b] TrimmedImages [/b] folder
                                  Zip of TrimmedImage folder is sent over PM
                                    A .jar file won't execute through the RC unless you use UI.openURL("file:///"+full_path_to_jar), which we know works... I think - please retry and confirm this if there's any doubt...
                                    The edges dat file that is necessary is made in the set you PM'd, and it is fine - here's a zoomed out view of the 'text' - you can clearly see the 0/1 pattern matching the image outline !
                                    So why isn't it working through the main ruby code ?
                                    The .jar isn't 'executing' in the code...
                                    So there must be something wrong with either your permissions - are you an admin ?
                                    OR perhaps the Java settings are not right for some reason???
                                    Do you AND ALL others have FULL access to the TrimmedImages folder ?
                                    Perhaps you do but others like Java/Sketchup don't ???
                                    Is there FULL rights for ALL to the SKMtools folder/files and subfolders ???
                                    It's as if something is stopping the one step needed with the jar file 'opening' and making the dat file...
                                    • eLaCiDE
                                      eLaCiD
                                      On this computer is only one user acount - my, with description computer administrator.
                                      Full Java sattings I posted here before.
                                      All folder with subfolder and files in that folders have full rights for ALL
                                      The catch is somewhere here :
                                      EdgeDetector.jar works if is started manualy by click
                                      EdgeDetector.jar doesn't work from RC
                                      When it would be?
                                        If you right-click a jar file and use 'open with...' what does it say ?
                                        Try execute with Java ?
                                        The one difference in the Java Advanced settings between me/you - mentioned earlier - can you try the alternative 'off'...
                                        • eLaCiDE
                                          eLaCiD
                                          I got this
                                          • eLaCiDE
                                            eLaCiD
                                            Conclusion - Chapter 2
                                            After many attempts, I came up with something that could lead to a solution.
                                            As I am not friendly with Ruby I tried the following
                                            First. I saw that when I run ImageTrimmer from SU in TrimmedImages folder only get copy of bacic image - someimage.png
                                            Then I saw if I directly run EdgeDetector.jar in TrimmedImages folder I get two files someimage[Edges].dat and someimage[Edges].png
                                            Next I saw when I run ImageTrimmer from SU at start all existing files in TrimmedImages folder are deleted.
                                            Well then I do next :
                                            I start directly EdgeDetector.jar and I get necessery files someimage[Edges].dat and someimage[Edges].png and I copy them out from TrimmedImagesfolder.
                                            Then I start ImageTrimmer from SU (of course ImageTrimer at start delete this two files from TrimmedImages folder but I have copy of them)
                                            When ImageTrimmer are working I copy back someimage[Edges].dat and someimage[Edges].png in TrimmedImages folder
                                            And on this way plugin works. πŸ‘
                                            As I said before Hope dies last and surrender is not an option. πŸ˜„
                                            TIG, now is your turn 😍
                                            My grandad who died many years ago and never seen computor know to say something that might be in translation :
                                            You dont have to know everything, but you need to know how to handle πŸ˜„
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
