    3D cursor
    16 Posts 4 Posters 860 Views 4 Watching
      glro
      Is there a plugin that would turn the arrow type cursor into a 3D cursor, that is
      3 joining perpendicular lines
      red green blue to show where are the axes, and how they are oriented
      or a plugin that would draw these 3 lines in a corner of the screen, permanently, like autocad does
      I do use the feature that put colors on edges according to there orientation, but you have to deduce the position of the origin, and it changes the aspect of the model so much that you can't keep it on all the time...
        Windows > Preferences > Drawing > Display Crosshairs
          glro
          yes it helps, thank you
            glro
            it helps but it is not sufficient to know the positiv direction of the axis
            i found this: typing
            result = Sketchup.send_action "selectAxisTool;"
            in the ruby console brings 3 colored arrows with a direction on each
            then the positiv directions are obvious
            • KrisidiousK Offline
              Krisidious
              Upgrade to 2013 and you'll have a colored axis for your rotate view tool.
              for some reason the screenshot won't grab the cursor. so here it's something like this.
              By: Kristoff Rand
                glro
                [attachment=0:1mw5ie7a]<!-- ia0 -->Untitled-1.jpg<!-- ia0 -->[/attachment:1mw5ie7a]
                big improvement... thank you for the information
                it will help to rotate
                and what about the cursor for translation? is it in color also?
                  Kristoff, you mean the Orbit tool, don't you? That's what shows in your screen shot.
                  The Move tool itself doesn't show any direction reference. Once you start moving the object you get the trailing line in the color of the axis to which the move is parallel just like always. The protractor of the Rotate tool changes color based on axis just as it always has, too.
                    Krisidious
                    Indeed... Orbit. But that's what the center mouse button is right? an orbit?
                    By: Kristoff Rand
                      Yes. And the cursor converts to that tool but it isn't rotating the model. 😉
                        Krisidious
                        That's why I said rotate view. 😉
                        By: Kristoff Rand
                          Hopefully the OP doesn't confuse Orbit and Rotate. 😉
                            Krisidious
                            using the actual name of tools is highly over rated...
                            By: Kristoff Rand
                              😆 My wife thinks so, too.
                                Krisidious
                                Did you just call me a girl?
                                By: Kristoff Rand
                                  Not at all. Between us we are making sure this thread has been well and truly hijacked, though.
                                    glro
                                    concerning global axis...
                                    blue axis is not a problem
                                    i have seen a plugin that changes the cursor using a bmp file; i don't remember the name;
                                    it could be a solution, since a flat cursor could show red and green directions
                                    how to change the cursor using a bmp or jpg file?
