    Plugin suggestion please
    3 Posts 2 Posters 165 Views 2 Watching
    • grizzlerG Offline
      grizzler
      Hello everyone.
      I'm hunting for a plugin that will unfold sheet metal models. I've just downloaded one called "flattery" after reading good things about it online, but I'm not sure if it only works on Macs as I get errors as soon as I try to extract it. Please can you suggest a good alternative?
      Thank you.
        'Flattery' works on PC [and probably MAC].
        Are you extracting/installing it properly ?
        It is an Extension and needs activating etc ?
        Also look at:-
        Jim's simple "jf_UnfoldTool.rb" http://sketchuptips.blogspot.com/2007/08/plugin-unfoldrb.html
        and MattC's "AutoUnfold.rb" http://sketchucation.com/forums/viewtopic.php?f=323&p=342121#p342110
        There's also the similar "unfoldtool.rb" by anon, that I have but can't remember where from...
        • grizzlerG Offline
          grizzler
          Also look at:-
          The error was something to do with "encryption", I just reinstalled it, clicked "OK" a bunch of times and it seems to be fine ๐Ÿ˜„
          Thanks for replying as I'd probably have given up on it otherwise.
